I have a Scene that turns on 3 Zigbee bulbs at minimum power, and ensures 2 other lights in the room are off. The hope is to turn the lights on at minimum power when waking up.
If I use the Scene in the morning... the 3 bulbs come on at full power. If I re-activate the Scene, the bulbs then dim to the expected brightness level. This happens if I activate the Scene from a dashboard button or a Zigbee button via the Button Controllers app.
At other times in the day, the scene seems to work, though I have not tested exhaustively.
I could understand commands not getting to the bulbs at all, or only some bulbs coming on.... but all of them coming on at the wrong brightness is strange.
These are Sengled bulbs and pre-staging is turned off.
The device settings for the scene are below. Any ideas? This kind of sucks because the one button I really want to work is the dim lights in the morning button!
EDIT TO ADD
I have a repro for this and the behavior does not seem desirable.
Consider the group of Sengled bulbs in the Scene--
- The Scene I am invoking sets some bulbs to CT 2400, power 1/100. Others are set to OFF.
- The bulbs that are meant to be off when the Scene is activated behave properly, turning off or staying off.
- If any bulb in the ON group was in RGB mode before being turned off prior to scene activation, when the Scene is activated, that bulb will select the right CT, but it comes on at power 100, not power 1.
- Bulbs that were in CT mode when powered off will power on at the low power level called for in the Scene.
In other words, if a light was in RGB mode and then turned off, it comes on too brightly when turned back on in CT mode.
I also discovered that in the Device panel, issuing direct commands, the level would jump unexpectedly.
Set CT 2400, Level 1 with Device buttonsSet an RGB color with the Device button--Level also increases to 100. Shouldn't it stay at 1?Strangely, setting an RGB color at Level 1 and then setting a CT did not result in a Level increase... so in this context it is the opposite of my Scene problem.
