webCoRE Presence Sensor -- [PROBLEM]
We have seen a number of users who have installed webCoRE Presence Sensor and had serious problems with their hub. Problems include excessive errors, sluggish performance of overall system, etc. We don't pretend to know why this is happening, or what can be done about it. Our advice: don't use webCoRE Presence Sensor until someone figures out why this is misbehaving so badly. If you have webCoRE Presence Sensor installed, we recommend that you remove it.
Bruce,
Could you give us an idea how long this has been happening and maybe some examples of the excessive errors etc? I've been using the WebCoRE Presence Sensor app almost from the beginning. I have no issues and it has worked very well up until 1.1.2.121.
Kind regards,
Michael
OK, then take it this way: IF you have webCoRE Presence installed AND you are experiencing sluggish performance or other hub problems, consider removing webCoRE Presence to see if this might be the source of your problems.
Does the Webcore Presence still work? If so, what device driver did you use?
