Webcore on Hubitat or Rasberry pi
Still on Smartthings going to move over first of the year. I've read that some install Webcore on a pie I'm thinking that It can also be installed on the Hubitat hub as well. So Y use a pie.
Also with the Smartthings hub, there are several versions When I purchase do I have to look for that as well with the Hubitat hub
Rick
Welcome!
There are two components to webCoRE: The dashboard and the pistons. The dashboard just lets you create/edit the pistons. The pistons run locally on Hubitat. The dashboard runs either on the web (dashboard.webcore.co) or on the Raspberry Pi.
I use the web dashboard just like I did when I was on Smartthings. The biggest caveat in my mind to this is if something ever happens to the dashboard site/host, I can't edit my pistons until I figure out how to get the dashboard running locally on a pi.
Assuming you’re referring to the hub itself, not WebCoRE (which was always free, AFAIK).
There’s only one current version of the Hubitat Elevation hub, which is known as hardware revision C7.
I should also add... When you get around to getting everything set up on the Hubitat, install the Hubitat Package Manager early on. Then you can easily install webCoRE and its dependencies from there and keep it up to date. You'll also be able to install a lot of other community integrations as well.
I was able to import around 50 pistons when I made the jump from Smartthings. I did have to open each of them and redefine the devices they referenced to the "new" device on Hubitat (since they no longer existed on ST), but that was easy compared to recreating all my existing automations either in Rule Machine or webCoRE.
As an Ex-SmartThings user can recommend this hub. I use WebCoRE as well for the more complex things (only because I haven’t learnt rule machine well enough).
AverageJoe90 just curious, I'm moving to Hubitat because of Smartthings new platform and the shutting down of WebCore automation. Why did you jump ship
Also is there any advantage to hosting or running WebCore on a pie
The advantage is that the dashboard would also be local, which would eliminate the need for internet when editing pistons. (The pistons already live and run locally.) The disadvantage is that you'd have to install the dashboard on the pi, get it working and maintain it.
Thanks, everyone. Good info
Rick
I was getting annoyed with the constant outages making my smart home completely unusable. Lack of local processing, it’s amazing how quick everything works on Hubitat and the announcement of the removal of DTH was the final straw so jumped ship, the owners also engage all the time on these forums.
Looks like @Equis answered the WebCoRE question :+1:
You won't regret it, @user3509!
I jumped over from ST a few months ago and zero regrets. Everything on HE and webcore working perfectly and more quickly, after correcting small issue with HE/ST versions handling date/time for timezones differently, and twc weather not supported on HE. Started converting several of my pistons to HE's rule machine, but have not noticed any difference in performance. All way better than ST's laggy web interface.
No need to wait til Jan...just do it! Just took me a couple hours to move 90% of my physical devices over, the rest of the day to deal with a few z-wave pairing issues (f-ing i-Blinds!), and the rest of the weekend to recreate virtual devices and webore/rules automatons I had before. My setup has around 80 physical plus virtual devices and around 30 automations, and integrations with Rachio, Flume, EcoBee, Actiontiles and data logging to google sheets. I was afraid converting all this would result in more bugs that were going to take longer to fix, but with this community's help, most of it up and running after a weekend, and just a few weeks to tie up some loose ends and move on to building the system out further (including Emporia Energy monitor, and some new rules using Emporia and Flume triggers/conditions that weren't possible on ST). I think all the best Groovy developers that helped make ST what it was, are on HE now. Some key pieces here from my ST setup were @sandood's ecobee suite and @krlaframboise simple event logger, but many more cool things I've found in built-in and community drivers I'm using now (+1 for HPM package manager, if it's not built in, chances are you can find what you need there - only a few items I've had to copy/paste code or Github URLs.).
As @Equis mentions, only painful part for webcore is going through each piston and selecting all the new devices on HE hub. When you restore backup pistons from ST version, all the devices show up with a unique, but not user-friendly code, My only tip to my former self would be to print each of my more complicated pistons with the ST device names I recognize to ease this step. I didn't make any mistakes, but there were a few cases I really had to work through the logic again to make sure I was picking the right physical and virtual devices.
I am not an "everything needs to be local" guy, and zero issue with editing on the web, but love the faster local piston execution on HE. It is definitely noticeable. IMHO if you want to host webcore on Pi, it can wait if you are happy with how it worked on ST.
Welcome to HE community, and hope your conversion goes as smoothly as mine.
I just the hub a year ago and WC is amust setup. Do the HPM as suggested earlier and possibly BPT's bundle manger as well (he has a lot of code).
The one thing that made my jump easier was setting up the ST hub as part of hub mesh with HE.
This allowed me to have all my ST devices available for pistons. I then migrated devices and their associated pistons a few at a time until I had nothing left on ST.
I had 2 older Fibaro Z-Wave devices with temp probes that would not play with any drivers on HE so the ST hung around for a while until I found a suitable replacement.
These days, it is no longer possible to install any new Groovy Apps/DTHs to one's ST account's Groovy IDE. ST has basically made the Groovy IDE Read-Only with respect to code. Soon, they will shut it down completely (target date is 12/31/2022.)
I unpaired everything from ST and never looked back!
That brick has already sucked enough of my life away.
Thanks Guys for the info. I cant change over until the new year. As for backing up pistons. Ive read that some use the backup feature in WebCore and back all pistons up at once. I have read other posts that use the Green snapshot of the piston and use the individual code to restore that piston
What is the best way to restore after WebCore is shut down in smartthings
I backed them up and downloaded the .zip file. The ST pistons will still be accessible in your webCoRE dashboard, so I didn't feel the need to write down all the codes. You can upload the zip file, but I found it just as easy to copy the pistons over from ST and change them as I went. Again, you can have the ST piston open in another tab to reference the devices that you need to update in the Hubitat one.
Some pistons did require a little rethinking. I had a ST piston that turned my landscape lights off, but I had to add a loop and wait to ensure that they all got switched off. ST didn't like to turn them all off if I just sent one command. That loop and pause got eliminated on Hubitat.
There was something else that I had to use a wait command to accommodate the cloud-based lag. That just wasn't necessary on Hubitat when things get executed so fast locally.
I had good intentions to move stuff over from ST in groups to minimize, but found that everything was so intertwined that I just decided to go for it. I still tried to prioritize for WAF but I had about 95% of everything paired and pistons running in about 2 days. I have just under 100 devices and 50 active pistons.
If I remember right, once you unpair each device from ST it shows up as random coded name on the ST piston too. It is not so useful if you don't remember which device is which in the code.
If you have some more complex pistons, I would recommend saving screenshots/un-anonymized of everything that might be confused before unpairing devices. Restoring from backups worked perfectly. If you have one backup file for all, it will still let you pick one-by-one each piston you want to restore. Just need to remember which device goes where.
I would also recommend you hold off until the new year. Hubitat just announced that there will be some great news for Webcore users on December 31. Maybe Webcore will become a built-in app. Maybe the dashboard will be hosted on HE. We don’t know yet, but if I were you I would definitely wait until the new year just to avoid the possibility of having to migrate or redo things once the news have been announced.
Edit: From Facebook:
I am pretty sure that this is the news (see below.) It is an optional way for existing SmartThings users to use a Hubitat hub to run webCoRE. SmartThings has announced that Groovy SmartApps will stop working on December 31st. Thus, the news from @bobby mentioning that the 31st is not the end.
I guess that I will wait to see. A webCoRE announcement is exciting to me. An ST announcement, not so much. I only have an old Samsung vacuum robot still tied to that system.
On the flip side, I appreciate that it is savvy business for HE to reach ST users and reduce barriers.
To be clear, the post you linked to regarding HubiThings Replica is wholly unrelated to that pending announcement. HubiThings Replica is intended for those who need or prefer to use SmartThings in one capacity or another, but want the many additional benefits of using Hubitat—webCoRE and Rule Machine amongst them. Replica simplifies making that connection, so that people no longer have to bend over backwards to make it happen.
It is exciting to hear that something is happening with webCoRE. I’ve always been a big fan, but have occasionally been frustrated with its unresolved quirks.
