I've noticed recently (within the past few weeks) that after saving a piston and "Finishing up..." is displayed, the editor doesn't drop me back into the main area that shows all of the pistons. I have to click on "cancel" or "save" multiple times get that to happen.
I suggest for both of these:
Hi,
I'm trying to host my own local WebCoRE server on a Synology DS220+. I'm running into an infinite URL rewriting loop, where it keeps redirecting me when I try to access the site. Has anybody been able to get this running on a Synology?
Interesting. Could you tell me the benefits (assuming you get it sorted ), and where I could find more info? A quick google didn't find much??
I had it working on a different brand's NAS, then I upgraded to a Synology and I can't get it working on that. It was really easy on the other one...
For all those who want to host a WebCoRE server on Synology, I finally got it working. Here's how to do it:
- Install Web Station and Apache 2.4.
- Clone the hubitat-patches branch of the WebCoRE github repository underneath the /web folder.
- Execute
sudo -R chgrp http webCoRE
andsudo -R chown http webCoRE
. - Set up a virtual host using Apache 2.4 as the backend. Point its document root at /web/webCoRE/dashboard.
- Log out all browsers from the dashboard.
- Re-register the browser and log back in.
- Do a hard reload and dump cache.
- If the pistons don't display properly, log out and repeat steps 5 and 6 until it works. (This did it for me... I'm not sure when it started working)
Hello, I am having this exact same issue. Can you share what you changed line 4 in index.html to?
TIA!
Here you go. I think it was just a forward slash by default.
I normaly don't have the logs turned on in WC but I happened to be tracing the failing Speak command where the volume value doesn't work.
I found scores of these lines in the logs every night now.
I don't use most of the commands the Warns point to except the Blink drivers MotionDetection.
Maybe these are from the @snell driver?
Here is about 1/3 of the Warns:
app:122022-12-17 22:42:22.469warnStrange command toggleSoundMode with commands [n:toggleSoundMode, p:[null], cm:true] has nulls
app:122022-12-17 22:42:22.467warnStrange command togglePictureMode with commands [n:togglePictureMode, p:[null], cm:true] has nulls
app:122022-12-17 22:42:22.431warnStrange command toggleInputSource with commands [n:toggleInputSource, p:[null], cm:true] has nulls
app:122022-12-17 22:42:22.429warnStrange command showMessage with commands [n:showMessage, p:[null], cm:true] has nulls
app:122022-12-17 22:42:22.383warnStrange command toggleSoundMode with commands [n:toggleSoundMode, p:[null], cm:true] has nulls
app:122022-12-17 22:42:22.381warnStrange command togglePictureMode with commands [n:togglePictureMode, p:[null], cm:true] has nulls
app:122022-12-17 22:42:22.379warnStrange command toggleInputSource with commands [n:toggleInputSource, p:[null], cm:true] has nulls
app:122022-12-17 22:42:22.377warnStrange command showMessage with commands [n:showMessage, p:[null], cm:true] has nulls
app:122022-12-17 22:42:22.037warnStrange command SystemDisarm with commands [n:SystemDisarm, p:[null], cm:true] has nulls
app:122022-12-17 22:42:22.035warnStrange command SystemArm with commands [n:SystemArm, p:[null], cm:true] has nulls
app:122022-12-17 22:42:22.033warnStrange command MotionDetectionEnable with commands [n:MotionDetectionEnable, p:[null], cm:true] has nulls
app:122022-12-17 22:42:22.031warnStrange command MotionDetectionDisable with commands [n:MotionDetectionDisable, p:[null], cm:true] has nulls
The SystemArm/SystemDisarm and MotionDetectionEnable/MotionDetectionDisable are from my Blink drivers, as was brought up in another thread.
Apparently they are "benign" because I am using the parameter area with the commands to be able to put descriptions on the device's page, but no actual parameters are being used. I do not have commands for "showMessage" or those "toggle" ones though, so those must be from other drivers.
thanks. Certainly, sound, picture and input aren't yours.
Logs are off now so I guess what I don't know can't hurt me
Well my logs are off but I'm getting hundreds of these daily. Ever since the last WC update a few days ago possibly? Never seen this action in the many years of running WC.
Can I downgrade WC to check and see if this is the issue? I'm using HPM so I would need the old source link.
@nh.schottfam
app:122022-12-20 08:56:16.583warnStrange command SystemArm with commands [n:SystemArm, p:[null], cm:true] has nulls
app:122022-12-20 08:56:15.458warnStrange command toggleSoundMode with commands [n:toggleSoundMode, p:[null], cm:true] has nulls
app:122022-12-20 08:56:15.456warnStrange command togglePictureMode with commands [n:togglePictureMode, p:[null], cm:true] has nulls
app:122022-12-20 08:56:15.454warnStrange command toggleInputSource with commands [n:toggleInputSource, p:[null], cm:true] has nulls
app:122022-12-20 08:56:15.451warnStrange command showMessage with commands [n:showMessage, p:[null], cm:true] has nulls
app:122022-12-20 08:56:15.406warnStrange command toggleSoundMode with commands [n:toggleSoundMode, p:[null], cm:true] has nulls
app:122022-12-20 08:56:15.404warnStrange command togglePictureMode with commands [n:togglePictureMode, p:[null], cm:true] has nulls
app:122022-12-20 08:56:15.402warnStrange command toggleInputSource with commands [n:toggleInputSource, p:[null], cm:true] has nulls
app:122022-12-20 08:56:15.401warnStrange command showMessage with commands [n:showMessage, p:[null], cm:true] has nulls
ok, I push an update to allow quiet this down.
Update pushed out that should allow quieting of logs (controlled by debug level logging)
Also updates IDE modules for how custom device commands and parameters are handled
The IDE changes are on staging.webcore.co or in the repo
I have just read the announcement webCoRE: A beautiful story continues beyond December 31st 2022 and have a few questions. #1: will development stop on the custom app we've been using all these years? #2: And will we loose access to the groovy source code like all the built in apps on the Hubitat hub? #3: Is Hubitat assuming control over dashboard.webcore.co? #4: Will we still have the ability to run the web interface locally?
IMHO Having webCoRE separate from the hub has given it more stability in that webCoRE is fully developed and changes infrequently. No disrespect to the Hubitat team, but it seems with every release things break, especially with Rule Machine. It would not be a good thing if that started to happen to webCoRE
No, the ongoing maintenance will continue to be in the hands of our community, especially @nh.schottfam and @ipaterson who have done a fantastic work to continue what Adrian has started in 2016. Any updates and bug fixes to the source code will come with the platform releases.
No, the source code will remain open.
We will be hosting the cloud infrastructure so that Adrian doesn't have to pay for the thousands of active users from his own pocket.
Nothing changes.
Good move @bobbyD . I hope this question doesn't start a whole "which is better" debate. I used RM when @bravenel first offered it on ST and switched to CoRE, then webCoRE, after Bruce pulled RM. And have been happily RM'ing here on HE ever since. Bruce has addressed in the past the relative niches for each engine. My question:
Once the object code is running on Hubitat, for a given task (or piston as it were), is there any execution efficiency gain or loss by using webCoRE vs RM?
Choice is good as JD used to say. Rule Machine will always be 100% local. webCoRE, while execution is local, building the rule is still cloud based.
The webCoRE vs Rule Machine debate has always been in the building of rules flow. Some prefer Adrian's workflow, while others feel more comfortable with Bruce's workflow. Execution efficiency is less relative +/- a few milliseconds here and there is negligible when you use the power of local processing that Hubitat Elevation offers.
If we install the Community version, is there a migration path to the built-in version when it's available? Or does there even need to be?
