webCoRE for Hubitat Updates
I also run a local server, and I'm having a different problem after doing all of that.
I updated my repo, restarted Apache, logged out, logged back in, and it works on my desktop but not on my phone. When I open a piston from my phone, none of the conditions show any devices, but from my computer, it works fine.
For example, if I have a condition "If Device1's battery changes then...", that shows up fine on my computer, but on my mobile device, it shows as "If then...".
On your mobile device;
logout of webCoRE
clear the cache of whatever browser you are using.
log back on to webCoRE
Thanks @nh.schottfam, I tried it our and it's working now. Such a great work.....
That's exactly what I did. Didn't work.
I just got an update. I did the clear piston caches and I still have the old global variables. Is it normal ?
Same here on my phone.
Update:
Now I cleared the cache of the app again and now it seems to work
What do you mean by this?
First I cleared the data with the Android Chrome app. Then I cleared the entire cache of the Chrome app. Which worked for me. Long press the Chrome icon and go to "Storage & cache" and "Clear cache". That helped in combination with logout and re-login.
Hope that helps
That worked, thanks.
There is a bug fix update pushed out, to address a NP issue, and a variable access issue (both are intermittent, but have hit a few people).
There is no additional UI changes in this bug fix.
HPM should notify of the update.
Hi @nh.schottfam , hope you are great.
Now I am seeing on the UI a message no my nested IFs. THinking on how I write my pistons, I ask the following:
I have a switch and an IF statement (IF SwitchX is on then) and this switch represent "automation". So I put my entire routine inside that IF and if I want to "disable" the routine I just need to turn OFF that switch and to anable, I turn it ON. What would be a good way of doing this? Am I doing it the right way?
I hit a bug this morning where a while loop that used to end properly ran infinitely. Sample piston below. Does this update fix that issue?
Try changing the outermost "if" statement to an "only when" filter.
you might want to look try:
  • adding the switch is on to each nested if statement (and un-nest the the if statements with 'changes' in them. That would move the trigger comparisons to out level (left to right) vs. nested.
  • extra credit for keeping the trigger comparison first in the ifs that are 'AND'.
You want the if statements with 'changes' in them to be crossed on each execution (so that 'changes' can be tracked). What is currently happening is 'changes' is only tracked when the switch is on, which may sound right, but on first runs after switch becomes on may be wrong...
What do you mean by filter?
What if using the switch to pause/resume the piston - I could create a piston that pause/resume pistons regarding that automation switch. Is it healthy? Increases processing?
It is ok to have a switch control the execution of the piston. In this short piston you are subscribed to the events being tracked by 'changes' so if you watch the piston it is waking up when those things change, it just runs the first if statement then exits.
Having it run 2 if statements (if you follow my earlier suggestion) vs. one is negligible to additional overhead.
I would suggest follow this tip:
I meant that if you click this button in the editor:
You will see a bunch of "only when" blocks pop up on the screen. Put your outermost "if" condition in the "only when" block that's above the "execute" statement, then you can move your two inner conditions to top level.
What about groups of condidtion+triggers? I am using groups like the one below - disregard the "automation switch at the beginning which I will take out and include on each conditions bellow. Like this is a problem of overhead?:
Upgrade failed then,
Error Occurred During Installation
An error occurred while installing the package: Failed to upgrade app https://raw.githubusercontent.com/imnotbob/webCoRE/hubitat-patches/smartapps/ady624/webcore-piston.src/webcore-piston.groovy. Please notify the package developer..
After doing a repair on my C4,
One of my C7's went through ok, I'll hold back on my other C7
