Weak Zigbee channel found
Updated C8 Pro to latest 2.3.9.196 platform and immediately got this new "Weak Zigbee channel found" warning. Current C8 Pro zigbee channel is 20 @ power 8:
This setting was present from day #1 after upgrading C8 to C8 Pro at a time when C8 Pro was announced. I am in a BIG apartment building with gazillions of WiFi networks around. Surprisingly Zigbee Mesh works just fine and seems to be very stable.
There is also a C7 with only 4 zigbee devices (these refused to connect directly to C8 Pro):
and C7 zigbee mesh also seems to be stable.
My questions are:
Should I change zigbee channels on C8 Pro and/or C7 or leave everything "as is" and simply ignore this new warning?
If it is better to change channels what channels should be used for each hub?
If your Zigbee mesh isn't broken/problematic, I wouldn't touch it. There should be an option on this warning to "Dismiss" it, so it does not bother you constantly.
I have my C8-Pro on Zigbee Channel 20 with power level 8, and it has been working extremely reliably.
Channel 26 in the USA is mandated by the FCC to use Low Power. I am not sure how low, though. I have always avoided Zigbee Ch 26 for this reason. I try to stick to channels 15, 20, and 25. I keep my 2.4GHz WiFi APs on channels 1, 6, and 11 with a 20Mhz channel width. This prevents conflicts between Zigbee 2.4GHz and WiFi 2.4GHz.
Then the warning is not for you, so you can ignore it. There are many folks who might experience Zigbee problems and could benefit from changing the channel to gain better experience. The message is for those users.
The hub can't precisely determine if you have problems or not, it just knows that there is a chance that you might, and if you do, it suggests a way to potentially resolve the problem.
@ogiewon @bobbyD Thank you for the comments.
Because zigbee mashes on both hubs are stable I am/was not planning to change anything but would like to hear a comments and opinions.
(The Dismiss button aready pressed.)
Actually I am really surprised, Zigbee works very well in my extremely rf-noisy environment.
I got the exact same thing this morning on my C-8 Pro. Was on .193 and now .196. I also got the infamous cloud backup did not complete which is the first time I've gotten that on my Pro hub. I got that regularly on my old C-8 hub and one reason why I bought a pro.
I have the same settings in the weak Zigbee as the op, channel 20 (ox14) and power level 8. I did change the channel and still the same. Rebooting doesn't clear it. I've never seen this alert before.
As a follow up I changed the channel to 26, power level 8 and reset the radio and the status changed to online and alert went away. Went back to channel 20 and got the weak alert again and status off line.
This is a brand new alert that came out in the latest release. You can click the dismiss option to suppress it. During beta I brought up the fact I have been on channel 20 for 10 years now while on ST for 4 years and HE for 6 with zero issues yet it popped up for me. The criteria for why it shows isn’t clear but was told it is more of a warning and that is why the dismiss button is there for those with no issues to suppress it.
Definitely don’t do this 26 is the weakest channel due to FCC regulations and many older devices won’t work on that frequency.
Thanks for that info. I moved it back to 20/8 and got the warning/alert back. I'll leave it there and hope an update will fix it. This time, however, the status is online with channel 20 and before it was offline.
not sure what your environment looks like, but I find it best to have lots of Wifi AP all TXing at low power, I set a minimal RSSI on my AP's to kick off clients that are too far away, to force them to roam to closer APs (go fish). I do the same with Zigbee. Low power Tx on the Hub and lots of routers. No need to have the Hub screaming over everyone and encourages zigbee devices to find the closest zigbee routers instead of having the hub talk over potential routers which may be closer. btw, the diagram of Wifi vs Zigbee overlap is not quite right. The only relatively clear channel is 26, however not all devices support it. 15, 20, and 25 are best but there still is Wifi spill over.
I just activated and moved my main setup to a C8 Pro hub from a C7 hub. I see this "Weak Zigbee channel found" message along with a (dismiss). However, it refuses to dismiss. How do I get this error message to dismiss? Aside from a couple of glitches in operation that have now resolved, I am not observing any apparent issues with Zigbee operation.
I don't know what to say. In my case it did work as expected.
UPDATE
I do not remember which update generated this warning. The DISMISS button worked as expected on a first try and did suppress this warning.
The Zigbee channel always was 20 starting back in 2019 with C5 hub and made to the latest/current C8 Pro. Power level was set to 8 on C8 hub and made it to C8 Pro.
Am in a BIG apartment complex with 400 units. There gazillions of WiFi AP around. Initially I was skeptical if Zigbee will work at all in this extremely rf-noisy environment. But to my BIG surprise Zigbee was/is very stable and never had/have any single mesh-related (connectivity) problem.
I also have no zigbee issues, but got the warning, and it will not dismiss
The debug console shows this:
That appears on every page.
Also, when I click dismiss, nothing shows up in the network tab or the console.
I got the warning a few updates ago. I don't even have a dismiss button. I have not changed anything and not experiencing any issues. I have just left the warning alone. If it isn't broke I am not going to fix it.
Just a side note it appears from several other threads that when this was put in the firmware update a few updates ago (sorry don't remember which one) that anyone on channel 20 gets this warning regardless if they are having issues or not. If you guys are on channel 20 this could explain it.
@gopher.ny see above browser console error.
Unable to dismiss Zigbee "weak signal" warning.
Weak Zigbee channel found - #13 by gikjll
@gikjll @LearningHubitat @StephenH
Can you confirm if you are on the current 2.4.0 HE platform/firmware?
Platform version is 2.4.0.144
Edit: I have tried Zigbee power levels 8, 12, and 16. I reverted back to 8 because it seemed to make no difference in this message.
I am not I am on the last 2.3 version. I have not updated yet.
2.4.0.144 and am on channel 20, power level 8
So just FYI, if you are impatient you can change the channel to anything other than 20 and the warning will go away. It is specifically an issue with 20, but only in some cases and does not affect everyone, hence why if its working fine the normal advice is to dismiss it. If you were having the issue you would know, zigbee would be awful. If you switch I recommend 25 because it is least likely to have Wifi interferences since it overlaps only slightly on one side. Sometimes a channel change will cause a few devices to drop off and not find it again, so you may have to pair some devices again.
OR if you just wait a little bit I am sure they will fix the alert so it can be dismissed.
Since my Zigbee devices seem to be working okay, I will abide by the old saying, "If it ain't broke, don't fix it!"
BTW, I have a C5 hub on Zigbee channel 25 already, so I can't switch to that. My router is set to use WiFi channel 1 in order to keep the WiFi and Zigbee as far separated as possible. Of course, I can't control what the neighbors might be using.
