I have this same generic zigbee valve like Juan posted, 4 of them actually ordered from alibaba. I've tried every driver listed and I can get it to report status i.e. open or closed but cannot command it. When pairing I see INCOMPLETE - DO NOT SUBMIT THIS - TRY AGAIN: fingerprint model:"null", manufacturer:"null", profileId:"0104", endpointId:"F2", inClusters:"null", outClusters:"null" in the log. I was about to give up but then just for the hell of it I tried pairing it to my amazon echo plus and it works that way so I know its capable of working. Any suggestions would be appreciated. The echo recognizes it as a light bulb with description _tz3000_iedbgyxt smart device but turning it on and off opens and closes the valve.
Thank you @Juan !
Hey Bucket, you've got to try the driver from @kkossev. He has built about 6 or 7 versions of the Tuya valve into his driver. I'm fairly sure it will work in HE for your valve.
Hi @Rxich, we've been working together with @Bucket on the first test versions of the driver, he helped a lot in troubleshooting it, many thanks!
Hopefully, I will have the time today to add the driver into HPM and to officially publish it n a new thread.
Tuya Zigbee Valve driver is now published here:
Sorry to dig up an old thread, but I bought one of these valves recently from Aliexpress....no issues getting it paired and responding using the Sinope Driver...but my issue is more mechanical...
The image of the valve I bought showed it with a rigid clamp. the one I got has two pieces and a pipe clamp, and I can't seem to get it to be rigid enough to operate through both the closing and reopening of the valve without moving out of alignment.... this means that when I re-open the valve it only opens about ~80%.
Anyone have any words of advice?
Some photos would be helpful. Also, these valves aren’t meant for PEX.
Can you share a picture of how it clamps? I'll snap a pic of how mine is clamped shortly.
Ya i .had same issue gave up and had one of these installed by plummer.
