I am new to Hubitat. I have not bought one yet, still debating on how I will switch from ST to HE. I currently have a Mimolite hooked up to a motorized ball valve with the following code. I have included the DTH. Will this function with HE? or will I have to modify it to work?
metadata {
// Automatically generated. Make future change here.
definition (name: "My MIMOlite - Main Water Valve v2", namespace: "jscgs350", author: "jsconst@gmail.com") {
capability "Alarm"
capability "Polling"
capability "Refresh"
capability "Switch"
capability "Valve"
capability "Contact Sensor"
capability "Configuration"
attribute "power", "string"
attribute "valveState", "string"
attribute "powerState", "string"
fingerprint deviceId: "0x1000", inClusters: "0x72,0x86,0x71,0x30,0x31,0x35,0x70,0x85,0x25,0x03"
// UI tile definitions
tiles(scale: 2) {
multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true, decoration: "flat"){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label: 'Valve Closed', action: "switch.on", icon: "st.valves.water.closed", backgroundColor: "#ff0000", nextState:"openingvalve"
attributeState "off", label: 'Valve Open', action: "switch.off", icon: "st.valves.water.open", backgroundColor: "#53a7c0", nextState:"closingvalve"
attributeState "closingvalve", label:'Closing', icon:"st.valves.water.closed", backgroundColor:"#ffd700"
attributeState "openingvalve", label:'Opening', icon:"st.valves.water.open", backgroundColor:"#ffd700"
tileAttribute ("statusText", key: "SECONDARY_CONTROL") {
attributeState "statusText", label:'${currentValue}'
standardTile("contact", "device.contact", width: 3, height: 2, inactiveLabel: false) {
state "open", label: 'Open (On)', icon: "st.valves.water.open", backgroundColor: "#53a7c0"
state "closed", label: 'Closed (Off)', icon: "st.valves.water.closed", backgroundColor: "#ff0000"
standardTile("power", "device.power", width: 3, height: 2, inactiveLabel: false) {
state "dead", label: 'OFF', backgroundColor: "#ff0000", icon:"st.switches.switch.off"
state "alive", label: 'ON', backgroundColor: "#79b821", icon:"st.switches.switch.on"
standardTile("refresh", "device.switch", width: 3, height: 2, inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
standardTile("configure", "device.configure", width: 3, height: 2, inactiveLabel: false, decoration: "flat") {
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
valueTile("statusText", "statusText", inactiveLabel: false, width: 2, height: 2) {
state "statusText", label:'${currentValue}', backgroundColor:"#ffffff"
main (["switch", "contact"])
details(["switch", "refresh", "configure"])
def result = null
def cmd = zwave.parse(description, [0x72: 1, 0x86: 1, 0x71: 1, 0x30: 1, 0x31: 3, 0x35: 1, 0x70: 1, 0x85: 1, 0x25: 1, 0x03: 1, 0x20: 1, 0x84: 1])
log.debug cmd
if (cmd.CMD == "7105") { //Mimo sent a power report lost power
sendEvent(name: "power", value: "dead")
sendEvent(name: "powerState", value: "NO POWER!")
} else {
sendEvent(name: "power", value: "alive")
sendEvent(name: "powerState", value: "electrical power.")
if (cmd) {
result = createEvent(zwaveEvent(cmd))
def statusTextmsg = ""
def timeString = new Date().format("h:mm a MM-dd-yyyy", location.timeZone)
statusTextmsg = "Valve is ${device.currentState('valveState').value}.\nLast refreshed at "+timeString+"."
sendEvent("name":"statusText", "value":statusTextmsg)
log.debug statusTextmsg
return result
def sensorValueEvent(Short value) {
if (value) {
log.debug "Main Water Valve is Open"
sendEvent(name: "contact", value: "open", descriptionText: "$device.displayName is open")
sendEvent(name: "valveState", value: "flowing water (tap to close)")
} else {
log.debug "Main Water Valve is Closed"
sendEvent(name: "contact", value: "closed", descriptionText: "$device.displayName is closed")
sendEvent(name: "valveState", value: "NOT flowing water (tap to open)")
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
[name: "switch", value: cmd.value ? "on" : "off", type: "physical"]
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd)
sensorValueEvent(cmd.value)
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
[name: "switch", value: cmd.value ? "on" : "off", type: "digital"]
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
sensorValueEvent(cmd.sensorValue)
def zwaveEvent(physicalgraph.zwave.commands.alarmv1.AlarmReport cmd)
log.debug "zwaveEvent AlarmReport: '${cmd}'"
switch (cmd.alarmType) {
case 8:
def map = [ name: "power", isStateChange:true]
if (cmd.alarmLevel){
map.value="dead"
map.descriptionText = "${device.displayName} lost power"
else {
map.value="alive"
map.descriptionText = "${device.displayName} has power"
sendEvent(map)
break;
default:
break;
def zwaveEvent(physicalgraph.zwave.Command cmd) {
// Handles all Z-Wave commands we aren't interested in
def off() {
log.debug "Closing Main Water Valve per user request"
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
zwave.switchBinaryV1.switchBinaryGet().format()
def both() {
log.debug "Closing Main Water Valve due to an alarm condition"
delayBetween([
def on() {
log.debug "Opening Main Water Valve per user request"
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
def poll() {
log.debug "Executing Poll for Main Water Valve"
delayBetween([
zwave.switchBinaryV1.switchBinaryGet().format(),
zwave.sensorBinaryV1.sensorBinaryGet().format(),
zwave.basicV1.basicGet().format(),
zwave.alarmV1.alarmGet().format()
],100)
def refresh() {
log.debug "Executing Refresh for Main Water Valve per user request"
delayBetween([
],100)
def configure() {
log.debug "Executing Configure for Main Water Valve per user request"
def cmd = delayBetween([
zwave.associationV1.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format(), //subscribe to power alarm
zwave.configurationV1.configurationSet(configurationValue: [25], parameterNumber: 11, size: 1).format(),
zwave.configurationV1.configurationSet(parameterNumber: 11, size: 1, configurationValue: [0]).format(), // momentary relay disable=0 (default)
],100)
log.debug "zwaveEvent ConfigurationReport: '${cmd}'"
