Hi I recently did an upgrade to a C8 Pro replaced a C8 as my main hub. since the upgrade I've decided to cut the ties with smartthings and removed all my devices along with trying removing HubiThings Replica since the upgrade and the moving and re placing the hub in the garage with the C8 I've been getting these warnings as pasted below and I can not figured out how to stop the warnings. Any idea's on how to stop this I'm not sure what app 491 was might have been HubiThings Replica I since deleted all my devices on SmartThings and deleted the account thinking it might been from there cloud.
Did you remove it using uninstall in Hubitat Package Manager?
I tried but it wouldnt let me I delete the driver then reinstalled it and final removed it with package manager i forgot to disable it when i did the backup sent me into a rabbit hole trying to resolve it.
Install this app via HPM and in the future you won't be left trying to figure out an old app (or device) id: [Release] App and Device ID Logger (this won't help for apps you've already deleted)
This is some remote cloud running app that you had talking to your Hubitat hub. 66.102.6.xx should be the IP address of the cloud server. It's owned by Google. I suspect it could have been HubiThings.
Will do thanks, I think I might have figured it out. I shut down the 2 hub and put the old C7 back online which my old C8 is replacing and the c7 cloud backup was restored to, the issue started after the backup on the C8 log with the warnings about not finding the app 491 but I could not find any app 491 in the log all the way back, so i took the c7 offline restarted the c8 and the c8 pro checked the c8 pro log back a few days and it show up this is what i found in the c8 pro log hope this resolves the warning I re authorized it
**app:491**2026-09-20 9:23:19.012 pm
info
Refreshing access_token from Google
Issue is still there in the log file not sure what else to do?
It's the external service that is trying to communicate with Hubitat. You need to turn off whatever is coming from 66.102.6.xx, whether in Smartthings or somewhere else.
I deleted all devices from smartthings and deleted the account the only app with 491 that i could find is the one above
That appears to come from this app: [RELEASE] Google SDM API - Nest integration
