Hey, guys, I can't seem to catch on, so maybe you can help me with the thermostat.
I have a physical temperature sensor and an outlet. The goal is simple automation - when the temperature rises above 20°C, turn on the outlet (it has a fridge in it and starts cooling). When the temperature drops below 20°C, turn it off again.
It could certainly be done easily via a Basic rule machine. But using a virtual thermostat should be more convenient, right? It has a nice dashboard element, easy to set the target temperature from dashboard, I can see the system status right away.
But I don't get how to set it up in HE at all. I added a vThermostat device, I have the element in the dashboard. But how to connect the temperature sensor and the socket to it I have no idea.
I must be missing some basic thing.
Thanks for any possible advice.
You would have to use a virtual thermostat device PLUS additional rules to do it, as the virtual thermostat driver itself doesn't connect to/talk to anything.
Basically when operating mode is cool, outlet on, when off, outlet off type of thing.
I've just added a z-wave switch and zigbee temp sensor. Did the same, added Virtual Thermostat, and then lost the marked trail on what to do. I'll figure it out- I've had stuff like this setup previously on Hubitat or back in the day on VERA.
Just saying- some non-nanny UX Improvement is self-identifying. A note, or link to knowledge seems warranted, given the instinct is Temp Sensor + Switch/Plug/Outlet => virtual thermostat.
