Is there a way to use a real tilt sensor as the open/close status in a virtual garage door? The only thing I can think of is just use rule machine to open/close the virtual door based on sensor status. Is there a better way?
Thanks!
Thanks!
Using the Virtual Garage Door Controller that's built in?
No.
You could create a hybrid Virtual GDO which has a switch interlocked to the GDO elements. Your physical Switch can then alter the virtual switch via automation and you get Open and Close on the GDO.
I was finally able to find an app that someone put together to use a tilt sensor. It's here for anyone that is curious https://community.hubitat.com/t/release-garage-opener-app-beta/37444
