Vibration Sensor
When first paired, did you have the "Tuya ZigBee Vibration Sensor" driver already installed? Or you installed the driver later?
This device fingerprint is in the driver, should be selected automatically ...
I don't think Apple Home has such a device type 'vibration sensor'
Some other custom drivers simulate a motion sensor when a vibration/acceleration is detected. This could be a possible workaround to have the vibration sensor added to HomeKit, if really needed to trigger any automation there.
I naivly thought the device would work on existing drivers (the 4 in 1 multi sensor) but this was not the case although it paired to that driver automatically,
So i installed the specifick vibration sensor driver afterwards and changed drivers manually.
Correct, BUT, in that case i would expect the device to show up in the incompatible list in the app at the bottom section. This is where all not HK supported devices are shown like HPM and my NTP device. Strange thing is, it doesnt show up at all. Hence the mention of @gopher.ny.
Does it have any other capabilities, like switch?
If you Ctrl+F and search through the page, it might pop up in some unexpected category.
Nope, just vibration. I rebooted the hub, refreshed the page, deleted cookies, tried again. I cant find it. I can make some screenshots if you like :yum::ok_hand:
Do you have a GitHub link for the driver?
@gopher.ny here is the driver link from GitHub
Credits to @kkossev
 * ver 1.0.3 2022-02-28 kkossev - inital version
 * ver 1.0.4 2022-03-02 kkossev - 'acceleration' misspelled bug fix
 * ver 1.0.5 2022-03-03 kkossev - Battery reporting
 * ver 1.0.6 2022-03-03 kkossev - Vibration Sensitivity
 * ver 1.0.7 2022-05-12 kkossev - TS0210 _TYZB01_pbgpvhgx Smart Vibration Sensor HS1VS
 * ver 1.0.8 2022-11-08 kkossev - TS0210 _TZ3000_bmfw9ykl
def version() { "1.0.8" }
def timeStamp() {"2022/11/08 9:45 PM"}
Can you try a virtual device, using HE inbuilt vibration sensor driver? (search for acceleration in the driver names) ? Will it be shown OK in the Apple Home app?
I will fiddle around with that, see if i can get it to work.
Issue at the moment is that with the current driver the sensor fires every few seconds even if there is no vibration. So either tje sensor is quirky or there is something with the driver. I have laired it several times and every time the device response to vibration seems different. Quite erratic behaviour so far.
Copy and paste in a Summary section some debug logs… Does the sensitivity setting work?
I was unable to make the sensitivity setting work.
this is what repeated for three days [dev:48](http://192.168.11.89/logs?tab=past&deviceId=48#)2023-02-18 09:55:17.587[debug](http://192.168.11.89/logs?tab=past&deviceId=48#)Tuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:55:17.585debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:55:17.463debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:55:08.867debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:55:08.866debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:55:08.735debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:55:00.733debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:55:00.731debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:55:00.611debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:54:48.447debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:48.445debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:48.314debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:54:43.082debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:43.080debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:42.959debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:54:39.945debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:39.944debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:39.822debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:54:36.697debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:36.695debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:36.571debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:54:32.136debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:32.135debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:32.011debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:54:25.914debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:25.913debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:25.788debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:54:18.426debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:18.424debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:18.287debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:54:15.001debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:15.000debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:14.879debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:54:11.752debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:11.751debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:11.624debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:54:01.676debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:01.675debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:54:01.551debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:53:55.376debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:53:55.374debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:53:55.252debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:53:41.369debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:53:41.368debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:53:41.247debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:53:37.050debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:53:37.048debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:53:36.923debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:53:32.684debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:53:32.682debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:53:32.560debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:53:19.481debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:53:19.480debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:53:19.355debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:53:10.646debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:53:10.644debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:53:10.522debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:53:03.298debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:53:03.297debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:53:03.174debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:52:58.579debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:58.577debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:58.453debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:52:49.813debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:49.811debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:49.689debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:52:46.379debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:46.377debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:46.247debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:52:39.745debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:39.744debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:39.616debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:52:34.808debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:34.806debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:34.578debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:52:28.397debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:28.396debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:28.274debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:52:20.861debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:20.859debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:20.673debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:52:16.696debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:16.695debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:16.573debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:52:13.530debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:13.528debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:13.408debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:52:02.225debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:02.223debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:52:02.097debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:51:56.352debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:56.350debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:56.222debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:51:52.025debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:52.023debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:51.902debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:51:44.212debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:44.210debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:44.099debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:51:37.353debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:37.351debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:37.229debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:51:28.943debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:28.942debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:28.817debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:51:24.192debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:24.190debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:24.060debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:51:09.511debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:09.510debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:09.384debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:51:06.345debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:06.343debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:06.220debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:51:01.933debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:01.931debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:51:01.808debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:50:57.210debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:50:57.209debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:50:57.088debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-18 09:50:48.337debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:50:48.336debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-18 09:50:48.207debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
That’s not good…
Change the driver to HE inbuilt Generic Zigbee Contact or Generic Zigbee Motion (no temp) drivers, and pair the vibration sensors again (without deleting it).
Will the periodic IAS enroll messages stop?
I had the batteries out for a day. I just re-inserted them, here is what happened in the logging (no more continous IAS triggering).
Havent changed the driver yet, its still on your “Tuya Zigbee Vibration sensor” driver version 1.08.
new logging after re-inserting batteries [dev:48](http://192.168.11.89/logs?tab=past&deviceId=48#)2023-02-19 09:15:39.984[debug](http://192.168.11.89/logs?tab=past&deviceId=48#)Tuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-19 09:15:39.982debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-19 09:15:39.860debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-19 09:14:56.875debugTuya Vibration Sensor: Zone status: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-19 09:14:56.874debugTuya Vibration Sensor: Parsing: zone status 0x0401 -- extended status 0x00 - sourceEndpoint:01, zoneId:FF, delay:0000
dev:482023-02-19 09:14:56.745debugTuya Vibration Sensor: Parsing: enroll request endpoint 0x01 : data 0x0015
dev:482023-02-19 09:14:54.567debugTuya Vibration Sensor: Parsing: read attr - raw: DBC301000110210020C82000201E, dni: DBC3, endpoint: 01, cluster: 0001, size: 10, attrId: 0021, encoding: 20, command: 0A, value: C82000201E
dev:482023-02-19 09:14:54.414warnDescription map not parsed: [raw:DBC30100001801002040E2FF2037E4FF2001, dni:DBC3, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:40, clusterInt:0, attrInt:1, additionalAttrs:[[value:37, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:01, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:482023-02-19 09:14:54.408debugTuya Vibration Sensor: Parsing: read attr - raw: DBC30100001801002040E2FF2037E4FF2001, dni: DBC3, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 40E2FF2037E4FF2001
No, the virtual acceleration device is also not shown (also not as incompatible) in the HomeKit app device list. So there something going on with this type in general in the firmware i guess?
@gopher.ny i understand that you might be busy with other higher priority stuff regarding memory usage and general stability of the firmware, but i though this might be usefull for you to know as well…
Is it working now?
Seems to yes, just shared the logging because of the warning it gave in there.
Strange thing is, I tried removing the batteries 2 times before… just haven’t kept them out as long as this time.
I will come back to this when I start modifying the driver to add the healthStatus online/offline attribute to it.
It’s a good example on how setting it ‘online’ (or ACTIVE in HE) just because something was received from the device is not a good enough criteria.
@gopher.ny
Victor, after some (online) research and some trial and error on my C7, i would like to report that vibration (acceleration) sensors do not show up in the HomeKit app as a device at all. Not the virtual device and not the physical Zigbee vibration sensor.
It seems the relevant section is missing perhaps?
Issue with this is, that the device cannot be exposed to Homekit whilst the vibration/acceleration type is known to HomeKit. For instance Aqara sells a HomeKit compliant device. Any chance this can be solved in a future firmware release?
I am also having the same issues with this sensor - it just keeps on flipping between active and inactive, even at 6, the lowest possible sensitivity.
Is there a built in Hubitat Vibration sensor driver?
If so, what is it called?
(I think I will try and implement your idea, to have RM monitor this sensor, and only if it is continually active for X minutes, to "sound the alarm".)
I had the same issue. These sensors on Z2M do not do this, so possibly they are not initialized properly with HE..just spitballing here. Anyway after pairing repeatedly and changing sensitivity(not sure it always takes the setting) it seems better. Now that I'm looking, apparently I had 5 mail deliveries between midnight and 5AM !! So it can go days being fine and then it freaks out. I wouldn't use them for anything critical, as least not on HE. On Z2M they are well behaved. I'd be curious to see how they behave on a Tuya hub, but I already have 7 Zigbee networks and don't need another, or maybe I DO !
@Rxich do you have and can you install two sensors of the same type in the mailbox - one paired to HE and the second paired to Z2M? This way you can compare if they behave differently under one and the same conditions..
The one that I have is attached to my PC chair and it detects the small movements when I am sitting on it, I have just increased the events history size to be able to see if there are any false triggering.
Is your vibration sensor the same as mine ?
  • endpointId: 01
  • application: 46
  • inClusters: 0000,000A,0001,0500
  • manufacturer: _TYZB01_3zv6oleo
  • model: TS0210
  • outClusters: 0019
  • softwareBuild:
