Vibration Sensor recomendations
Hi guys,im looking for a vibration sensors, any recomendation? ( preferably not so expensive as the smarthings/aotec) Anyone has used the Moes vibration sensor?is compatible with Hubitat?
Recently i bought an Aqara vibration sensor,after figure how to pair it to the hubitat,its working fine (so far,altought i know some people have trouble with them) but i discover something ¨¨ugly¨¨ when the vibration is detected,it as a cooldown of 60 seconds and i need one with a short cooldown
with the driver ,for example, i can set the motion inactive after 5 seconds after been trigger,but even if i keep shaking the sensor for 20,30,50 seconds it would never trigger again,until 60 seconds has passed
Captura de pantalla (182)
(i Want the sensors for a spiral staircase,in the first and last step,and because is a spiral staircase,using a Motion sensor Pir or Mmwave is kind of hard positioning without constant false triggering of people passing near the staircase without using it)
For the Moes vibration sensor you can try the Tuya Zigbee Vibration Sensor driver which is w available for installation from HPM.
Tuya vibration sensors cooldown time is about 2-3 seconds only, but some are reported to be too much sensitive.
Update May 2024: now there is a dedicated thread for the Tuya Vibration Sensor driver :
I just bought a Moes vibration sensor, and after struggling a little with it for a couple of days, and using @kkossev driver, I was able to make it work perfectly. Highly recommended!
Hi Kkossev,
It seems that I recently bought the Moes vibration sensor without realizing that some users have reported it's too sensitive.
Unfortunately, the Moes unit I bought is indeed too sensitive, and adjusting the sensitivity within the driver doesn't seem to make a difference. Is there a way to manually adjust settings within the driver code to prevent the device from detecting minor vibrations?
Thanks in advance
I've had good luck with the Zooz XS tilt+shock sensor. I use the shock capability to detect whether my garage door is opening - it's that sensitive. But can be adjusted.
Please post the device details (model and manufacturer data from the section at the bottom of the device page), there are many different devices, all labeled 'Moes' ...
TS0210 _TZ3000_bmfw9ykl
This device seems to have problem configuring the sensitivity also in Zigbee2MQTT:
I will watch this thread for any solution if such becomes available.
I just grabbed 3rd reality Vibration sensor from amazon. They've since raised the price from 13.00 to 19.99, still not bad. Takes 2 AAA batteries and has a built in siren, pretty neat. It paired as device, so I pulled the info using the Device driver "Info" button and managed to get some functionality by modifying @kkossev Tuya driver. It picks up vibration and seems to obey the reset time, as well as showing battery voltage! yippee
The one inCluster that I have no idea what it does is "FFF1". I don't know if that's mfgr specific or if I'm missing out on some functionality.
This is the fingerprint I kludged together:
fingerprint profileID:"0104", endpointId:"01", inClusters:"0000,0001,0500,FFF1", outClusters:"0019", model:"3RVS01031Z", manufacturer:"Third Reality, Inc" //tested RH
I really like this device, hopefully it'll stay connected to my C7 and not have abysmal battery life...time will tell.
  • endpointId: 01
  • application: 28
  • firmwareMT: 1233-D3AB-00000028
  • inClusters: 0000,0001,0500,FFF1
  • manufacturer: Third Reality, Inc
  • model: 3RVS01031Z
  • outClusters: 0019
  • softwareBuild: v1.00.40
https://www.amazon.com/dp/B0C9DP249C?psc=1&ref=ppx_yo2ov_dt_b_product_details
I've been using a 3R vibration sensor for a while now - works like a champ!
As suggested by 3R in the user guide, I am just using the generic zigbee motion sensor driver (more specifically, I'm using the "Generic Zigbee Motion Sensor (no temp)" option).
I really like the fact that both alarm and sensitivity is set on the device itself - less software-related bells-&-whistles to get mucked up.
Awesome. I just noticed that I only see active in the device events, not in the logs, whereas with my other motion sensors(Hue,Iris) I see motion in the logs and device events. How about you?
I get "(in)active" events in the logs but nothing else.
I do suspect that (like so many other 3R devices), the battery reporting is borked - mine hasn't budged since install many months ago, and I'm pretty sure my batteries ain't that good.
But mine does get activated at least every other day, so if I don't find out the hard way (which wouldn't be a big deal in my use case), then Device Activity Check will tell me when the batts finally kick the can.
This device is very interesting, but it is priced ridiculously high in Europe at around $35 USD !
It should be capable of 3-axis reporting (similar to Samsung multi-sensor), most probably this is the cluster that reports the x-y-z data ...
Do you see anything reported in the debug logs coming from the 0xFFF1 cluster when an acceleration is sensed?
Ugg, 3R Vib stopped reporting but that was with my hub memory dropping to the lowest I've ever seen, 150k !!
Rebooting now and will reconnect & report back
Okay, had to reboot Zigbee was lagging due to super low memory
Here's the debug logs on tilt, which also set off motion acceleration:
3rd Reality Vibration Sensor Debug Logs
dev:21572023-12-06 04:23:24.199 PMinfo__3rd reality vib sensor: null
dev:21572023-12-06 04:23:24.195 PMdebug__3rd reality vib sensor: zs.batteryDefect = 0
dev:21572023-12-06 04:23:24.192 PMdebug__3rd reality vib sensor: zs.test = 0
dev:21572023-12-06 04:23:24.189 PMdebug__3rd reality vib sensor: zs.ac = 0
dev:21572023-12-06 04:23:24.186 PMdebug__3rd reality vib sensor: zs.trouble = 0
dev:21572023-12-06 04:23:24.182 PMdebug__3rd reality vib sensor: zs.restoreReports = 1
dev:21572023-12-06 04:23:24.179 PMdebug__3rd reality vib sensor: zs.supervisionReports = 0
dev:21572023-12-06 04:23:24.176 PMdebug__3rd reality vib sensor: zs.battery = 0
dev:21572023-12-06 04:23:24.173 PMdebug__3rd reality vib sensor: zs.tamper = 0
dev:21572023-12-06 04:23:24.169 PMdebug__3rd reality vib sensor: zs.alarm2 = 0
dev:21572023-12-06 04:23:24.166 PMdebug__3rd reality vib sensor: zs.alarm1 = 0
dev:21572023-12-06 04:23:24.163 PMwarnZone status message not parsed
dev:21572023-12-06 04:23:24.160 PMdebug__3rd reality vib sensor: Zone status: zone status 0x0020 -- extended status 0x00 - sourceEndpoint:01, zoneId:14, delay:0000
dev:21572023-12-06 04:23:24.157 PMdebug__3rd reality vib sensor: Parsing: zone status 0x0020 -- extended status 0x00 - sourceEndpoint:01, zoneId:14, delay:0000
dev:21572023-12-06 04:23:24.150 PMwarnDescription map not parsed: [raw:E6D101FFF10A0000290000, dni:E6D1, endpoint:01, cluster:FFF1, size:0A, attrId:0000, encoding:29, command:0A, value:0000, clusterInt:65521, attrInt:0]
dev:21572023-12-06 04:23:24.146 PMdebug__3rd reality vib sensor: Parsing: read attr - raw: E6D101FFF10A0000290000, dni: E6D1, endpoint: 01, cluster: FFF1, size: 0A, attrId: 0000, encoding: 29, command: 0A, value: 0000
dev:7692023-12-06 04:23:17.984 PMinfoMotion Front Door Hue is inactive
dev:7692023-12-06 04:23:08.050 PMinfoMotion Front Door Hue is active
dev:20522023-12-06 04:23:04.313 PMinfoApplication ID Received
dev:21432023-12-06 04:22:54.079 PMinfo__Pendant V1 : ping
dev:21572023-12-06 04:22:52.123 PMinfo__3rd reality vib sensor: null
dev:21572023-12-06 04:22:52.120 PMdebug__3rd reality vib sensor: zs.batteryDefect = 0
dev:21572023-12-06 04:22:52.116 PMdebug__3rd reality vib sensor: zs.test = 0
dev:21572023-12-06 04:22:52.113 PMdebug__3rd reality vib sensor: zs.ac = 0
dev:21572023-12-06 04:22:52.110 PMdebug__3rd reality vib sensor: zs.trouble = 0
dev:21572023-12-06 04:22:52.107 PMdebug__3rd reality vib sensor: zs.restoreReports = 1
dev:21572023-12-06 04:22:52.104 PMdebug__3rd reality vib sensor: zs.supervisionReports = 0
dev:21572023-12-06 04:22:52.101 PMdebug__3rd reality vib sensor: zs.battery = 0
dev:21572023-12-06 04:22:52.098 PMdebug__3rd reality vib sensor: zs.tamper = 0
dev:21572023-12-06 04:22:52.095 PMdebug__3rd reality vib sensor: zs.alarm2 = 0
dev:21572023-12-06 04:22:52.091 PMdebug__3rd reality vib sensor: zs.alarm1 = 0
dev:21572023-12-06 04:22:52.088 PMwarnZone status message not parsed
dev:21572023-12-06 04:22:52.085 PMdebug__3rd reality vib sensor: Zone status: zone status 0x0020 -- extended status 0x00 - sourceEndpoint:01, zoneId:14, delay:0000
dev:21572023-12-06 04:22:52.082 PMdebug__3rd reality vib sensor: Parsing: zone status 0x0020 -- extended status 0x00 - sourceEndpoint:01, zoneId:14, delay:0000
dev:21572023-12-06 04:22:52.074 PMwarnDescription map not parsed: [raw:E6D101FFF10A0000290000, dni:E6D1, endpoint:01, cluster:FFF1, size:0A, attrId:0000, encoding:29, command:0A, value:0000, clusterInt:65521, attrInt:0]
dev:21572023-12-06 04:22:52.070 PMdebug__3rd reality vib sensor: Parsing: read attr - raw: E6D101FFF10A0000290000, dni: E6D1, endpoint: 01, cluster: FFF1, size: 0A, attrId: 0000, encoding: 29, command: 0A, value: 0000
dev:21572023-12-06 04:22:44.121 PMinfo__3rd reality vib sensor: null
dev:21572023-12-06 04:22:44.118 PMdebug__3rd reality vib sensor: zs.batteryDefect = 0
dev:21572023-12-06 04:22:44.115 PMdebug__3rd reality vib sensor: zs.test = 0
dev:21572023-12-06 04:22:44.112 PMdebug__3rd reality vib sensor: zs.ac = 0
dev:21572023-12-06 04:22:44.109 PMdebug__3rd reality vib sensor: zs.trouble = 0
dev:21572023-12-06 04:22:44.105 PMdebug__3rd reality vib sensor: zs.restoreReports = 1
dev:21572023-12-06 04:22:44.102 PMdebug__3rd reality vib sensor: zs.supervisionReports = 0
dev:21572023-12-06 04:22:44.099 PMdebug__3rd reality vib sensor: zs.battery = 0
dev:21572023-12-06 04:22:44.096 PMdebug__3rd reality vib sensor: zs.tamper = 0
dev:21572023-12-06 04:22:44.093 PMdebug__3rd reality vib sensor: zs.alarm2 = 0
dev:21572023-12-06 04:22:44.090 PMdebug__3rd reality vib sensor: zs.alarm1 = 0
dev:21572023-12-06 04:22:44.087 PMwarnZone status message not parsed
dev:21572023-12-06 04:22:44.084 PMdebug__3rd reality vib sensor: Zone status: zone status 0x0020 -- extended status 0x00 - sourceEndpoint:01, zoneId:14, delay:0000
dev:21572023-12-06 04:22:44.081 PMdebug__3rd reality vib sensor: Parsing: zone status 0x0020 -- extended status 0x00 - sourceEndpoint:01, zoneId:14, delay:0000
dev:21572023-12-06 04:22:44.073 PMwarnDescription map not parsed: [raw:E6D101FFF10A0000290000, dni:E6D1, endpoint:01, cluster:FFF1, size:0A, attrId:0000, encoding:29, command:0A, value:0000, clusterInt:65521, attrInt:0]
dev:21572023-12-06 04:22:44.069 PMdebug__3rd reality vib sensor: Parsing: read attr - raw: E6D101FFF10A0000290000, dni: E6D1, endpoint: 01, cluster: FFF1, size: 0A, attrId: 0000, encoding: 29, command: 0A, value: 0000
dev:21572023-12-06 04:22:42.062 PMinfo__3rd reality vib sensor: Vibration reset to inactive after 7s
dev:21572023-12-06 04:22:42.059 PMinfo__3rd reality vib sensor: null
dev:21572023-12-06 04:22:42.056 PMdebug__3rd reality vib sensor: zs.batteryDefect = 0
dev:21572023-12-06 04:22:42.052 PMdebug__3rd reality vib sensor: zs.test = 0
dev:21572023-12-06 04:22:42.049 PMdebug__3rd reality vib sensor: zs.ac = 0
dev:21572023-12-06 04:22:42.046 PMdebug__3rd reality vib sensor: zs.trouble = 0
dev:21572023-12-06 04:22:42.043 PMdebug__3rd reality vib sensor: zs.restoreReports = 1
dev:21572023-12-06 04:22:42.040 PMdebug__3rd reality vib sensor: zs.supervisionReports = 0
dev:21572023-12-06 04:22:42.037 PMdebug__3rd reality vib sensor: zs.battery = 0
dev:21572023-12-06 04:22:42.034 PMdebug__3rd reality vib sensor: zs.tamper = 0
dev:21572023-12-06 04:22:42.031 PMdebug__3rd reality vib sensor: zs.alarm2 = 0
dev:21572023-12-06 04:22:42.028 PMdebug__3rd reality vib sensor: zs.alarm1 = 0
dev:21572023-12-06 04:22:42.025 PMwarnZone status message not parsed
dev:21572023-12-06 04:22:42.021 PMdebug__3rd reality vib sensor: Zone status: zone status 0x0020 -- extended status 0x00 - sourceEndpoint:01, zoneId:14, delay:0000
dev:21572023-12-06 04:22:42.018 PMdebug__3rd reality vib sensor: Parsing: zone status 0x0020 -- extended status 0x00 - sourceEndpoint:01, zoneId:14, delay:0000
dev:21572023-12-06 04:22:42.011 PMwarnDescription map not parsed: [raw:E6D101FFF10A0000290000, dni:E6D1, endpoint:01, cluster:FFF1, size:0A, attrId:0000, encoding:29, command:0A, value:0000, clusterInt:65521, attrInt:0]
dev:21572023-12-06 04:22:42.007 PMdebug__3rd reality vib sensor: Parsing: read attr - raw: E6D101FFF10A0000290000, dni: E6D1, endpoint: 01, cluster: FFF1, size: 0A, attrId: 0000, encoding: 29, command: 0A, value: 0000
dev:20612023-12-06 04:22:38.041 PMinfoping()
dev:21572023-12-06 04:22:37.064 PMinfo__3rd reality vib sensor: Detected vibration
dev:21572023-12-06 04:22:37.007 PMdebug__3rd reality vib sensor: Zone status: zone status 0x0011 -- extended status 0x00 - sourceEndpoint:01, zoneId:14, delay:0000
dev:21572023-12-06 04:22:37.004 PMdebug__3rd reality vib sensor: Parsing: zone status 0x0011 -- extended status 0x00 - sourceEndpoint:01, zoneId:14, delay:0000
dev:21572023-12-06 04:22:36.006 PMwarnDescription map not parsed: [raw:E6D101FFF12800002901000100295D0002002919010300296B03, dni:E6D1, endpoint:01, cluster:FFF1, size:28, attrId:0000, encoding:29, command:0A, value:0001, clusterInt:65521, attrInt:0, additionalAttrs:[[value:005D, encoding:29, attrId:0001, consumedBytes:5, attrInt:1], [value:0119, encoding:29, attrId:0002, consumedBytes:5, attrInt:2], [value:036B, encoding:29, attrId:0003, consumedBytes:5, attrInt:3]]]
dev:21572023-12-06 04:22:35.995 PMdebug__3rd reality vib sensor: Parsing: read attr - raw: E6D101FFF12800002901000100295D0002002919010300296B03, dni: E6D1, endpoint: 01, cluster: FFF1, size: 28, attrId: 0000, encoding: 29, command: 0A, value: 01000100295D0002002919010300296B03
dev:21572023-12-06 04:22:35.157 PMinfo__3rd reality vib sensor: Detected vibration
dev:21572023-12-06 04:22:35.018 PMdebug__3rd reality vib sensor: Zone status: zone status 0x0011 -- extended status 0x00 - sourceEndpoint:01, zoneId:14, delay:0000
dev:21572023-12-06 04:22:35.015 PMdebug__3rd reality vib sensor: Parsing: zone status 0x0011 -- extended status 0x00 - sourceEndpoint:01, zoneId:14, delay:0000
dev:21572023-12-06 04:22:35.008 PMwarnDescription map not parsed: [raw:E6D101FFF12800002901000100293E00020029EA00030029D803, dni:E6D1, endpoint:01, cluster:FFF1, size:28, attrId:0000, encoding:29, command:0A, value:0001, clusterInt:65521, attrInt:0, additionalAttrs:[[value:003E, encoding:29, attrId:0001, consumedBytes:5, attrInt:1], [value:00EA, encoding:29, attrId:0002, consumedBytes:5, attrInt:2], [value:03D8, encoding:29, attrId:0003, consumedBytes:5, attrInt:3]]]
dev:21572023-12-06 04:22:34.997 PMdebug__3rd reality vib sensor: Parsing: read attr - raw: E6D101FFF12800002901000100293E00020029EA00030029D803, dni: E6D1, endpoint: 01, cluster: FFF1, size: 28, attrId: 0000, encoding: 29, command: 0A, value: 01000100293E00020029EA00030029D803
and trying to save preferences when adjusting sensitivity:
Saving Prefs w/ Change in sensitivity
dev:21572023-12-06 04:27:47.865 PMwarnexception caught while parsing description: read attr - raw: E6D101000070040042125468697264205265616C6974792C20496E6300000020030100002028050000420A3352565330313033315A0700003001FEFF86, dni: E6D1, endpoint: 01, cluster: 0000, size: 70, attrId: 0004, encoding: 42, command: 01, value: 125468697264205265616C6974792C20496E6300000020030100002028050000420A3352565330313033315A0700003001FEFF86
dev:21572023-12-06 04:27:47.857 PMdebug__3rd reality vib sensor: Parsing: read attr - raw: E6D101000070040042125468697264205265616C6974792C20496E6300000020030100002028050000420A3352565330313033315A0700003001FEFF86, dni: E6D1, endpoint: 01, cluster: 0000, size: 70, attrId: 0004, encoding: 42, command: 01, value: 125468697264205265616C6974792C20496E6300000020030100002028050000420A3352565330313033315A0700003001FEFF86
dev:21572023-12-06 04:27:47.848 PMinfo__3rd reality vib sensor: battery voltage is 3.2 volts
dev:21572023-12-06 04:27:47.845 PMdebug__3rd reality vib sensor: Parsing: read attr - raw: E6D10100010A20002020, dni: E6D1, endpoint: 01, cluster: 0001, size: 0A, attrId: 0020, encoding: 20, command: 01, value: 20
dev:21572023-12-06 04:27:47.833 PMwarnDescription map not parsed: [raw:catchall: 0104 0500 01 01 0040 00 E6D1 00 00 0000 04 01 00, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E6D1, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:21572023-12-06 04:27:47.829 PMdebug__3rd reality vib sensor: Parsing: catchall: 0104 0500 01 01 0040 00 E6D1 00 00 0000 04 01 00
dev:1732023-12-06 04:27:47.573 PMinfoApplication ID Received
dev:21572023-12-06 04:27:44.876 PMwarnDescription map not parsed: [raw:catchall: 0104 0500 01 01 0040 00 E6D1 00 00 0000 04 01 00, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E6D1, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:21572023-12-06 04:27:44.872 PMdebug__3rd reality vib sensor: Parsing: catchall: 0104 0500 01 01 0040 00 E6D1 00 00 0000 04 01 00
dev:21572023-12-06 04:27:44.865 PMinfo__3rd reality vib sensor: battery voltage is 3.2 volts
dev:21572023-12-06 04:27:44.862 PMdebug__3rd reality vib sensor: Parsing: read attr - raw: E6D10100010A20002020, dni: E6D1, endpoint: 01, cluster: 0001, size: 0A, attrId: 0020, encoding: 20, command: 01, value: 20
dev:21572023-12-06 04:27:44.834 PMwarnexception caught while parsing description: read attr - raw: E6D101000070040042125468697264205265616C6974792C20496E6300000020030100002028050000420A3352565330313033315A0700003001FEFF86, dni: E6D1, endpoint: 01, cluster: 0000, size: 70, attrId: 0004, encoding: 42, command: 01, value: 125468697264205265616C6974792C20496E6300000020030100002028050000420A3352565330313033315A0700003001FEFF86
dev:21572023-12-06 04:27:44.826 PMdebug__3rd reality vib sensor: Parsing: read attr - raw: E6D101000070040042125468697264205265616C6974792C20496E6300000020030100002028050000420A3352565330313033315A0700003001FEFF86, dni: E6D1, endpoint: 01, cluster: 0000, size: 70, attrId: 0004, encoding: 42, command: 01, value: 125468697264205265616C6974792C20496E6300000020030100002028050000420A3352565330313033315A0700003001FEFF86
dev:21572023-12-06 04:27:34.900 PMwarnDescription map not parsed: [raw:catchall: 0104 0500 01 01 0040 00 E6D1 00 00 0000 04 01 00, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E6D1, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:21572023-12-06 04:27:34.896 PMdebug__3rd reality vib sensor: Parsing: catchall: 0104 0500 01 01 0040 00 E6D1 00 00 0000 04 01 00
dev:21572023-12-06 04:27:34.888 PMwarnReporting configuration failed: [raw:catchall: 0104 0001 01 01 0040 00 E6D1 00 00 0000 07 01 86002000, profileId:0104, clusterId:0001, clusterInt:1, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E6D1, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 20, 00]]
dev:21572023-12-06 04:27:34.884 PMdebug__3rd reality vib sensor: Parsing: catchall: 0104 0001 01 01 0040 00 E6D1 00 00 0000 07 01 86002000
dev:21572023-12-06 04:27:34.875 PMdebug__3rd reality vib sensor: Parsing: catchall: 0000 8021 00 00 0040 00 E6D1 00 00 0000 00 00 D800
dev:21572023-12-06 04:27:34.866 PMwarnexception caught while parsing description: read attr - raw: E6D101000070040042125468697264205265616C6974792C20496E6300000020030100002028050000420A3352565330313033315A0700003001FEFF86, dni: E6D1, endpoint: 01, cluster: 0000, size: 70, attrId: 0004, encoding: 42, command: 01, value: 125468697264205265616C6974792C20496E6300000020030100002028050000420A3352565330313033315A0700003001FEFF86
dev:21572023-12-06 04:27:34.854 PMdebug__3rd reality vib sensor: Parsing: read attr - raw: E6D101000070040042125468697264205265616C6974792C20496E6300000020030100002028050000420A3352565330313033315A0700003001FEFF86, dni: E6D1, endpoint: 01, cluster: 0000, size: 70, attrId: 0004, encoding: 42, command: 01, value: 125468697264205265616C6974792C20496E6300000020030100002028050000420A3352565330313033315A0700003001FEFF86
dev:21572023-12-06 04:27:34.828 PMwarnDescription map not parsed: [raw:catchall: 0104 0500 01 01 0040 00 E6D1 00 00 0000 04 01 861300, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E6D1, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, 13, 00]]
dev:21572023-12-06 04:27:34.657 PMdebug__3rd reality vib sensor: Parsing: catchall: 0104 0500 01 01 0040 00 E6D1 00 00 0000 04 01 861300
dev:21572023-12-06 04:27:34.611 PMwarnReporting configuration failed: [raw:catchall: 0104 0001 01 01 0040 00 E6D1 00 00 0000 07 01 86002000, profileId:0104, clusterId:0001, clusterInt:1, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E6D1, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 20, 00]]
dev:21572023-12-06 04:27:34.606 PMdebug__3rd reality vib sensor: Parsing: catchall: 0104 0001 01 01 0040 00 E6D1 00 00 0000 07 01 86002000
dev:21572023-12-06 04:27:34.587 PMdebug__3rd reality vib sensor: Parsing: catchall: 0000 8021 00 00 0040 00 E6D1 00 00 0000 00 00 D800
dev:21572023-12-06 04:27:34.548 PMdebug__3rd reality vib sensor: Parsing: catchall: 0000 8021 00 00 0040 00 E6D1 00 00 0000 00 00 D800
dev:21572023-12-06 04:27:34.508 PMwarnexception caught while parsing description: read attr - raw: E6D101000070040042125468697264205265616C6974792C20496E6300000020030100002028050000420A3352565330313033315A0700003001FEFF86, dni: E6D1, endpoint: 01, cluster: 0000, size: 70, attrId: 0004, encoding: 42, command: 01, value: 125468697264205265616C6974792C20496E6300000020030100002028050000420A3352565330313033315A0700003001FEFF86
dev:21572023-12-06 04:27:34.499 PMdebug__3rd reality vib sensor: Parsing: read attr - raw: E6D101000070040042125468697264205265616C6974792C20496E6300000020030100002028050000420A3352565330313033315A0700003001FEFF86, dni: E6D1, endpoint: 01, cluster: 0000, size: 70, attrId: 0004, encoding: 42, command: 01, value: 125468697264205265616C6974792C20496E6300000020030100002028050000420A3352565330313033315A0700003001FEFF86
dev:21572023-12-06 04:27:34.481 PMwarnDescription map not parsed: [raw:catchall: 0104 0500 01 01 0040 00 E6D1 00 00 0000 04 01 861300, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E6D1, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, 13, 00]]
dev:21572023-12-06 04:27:34.476 PMdebug__3rd reality vib sensor: Parsing: catchall: 0104 0500 01 01 0040 00 E6D1 00 00 0000 04 01 861300
dev:21572023-12-06 04:27:34.469 PMwarnDescription map not parsed: [raw:catchall: 0104 0500 01 01 0040 00 E6D1 00 00 0000 04 01 861300, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:E6D1, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, 13, 00]]
dev:21572023-12-06 04:27:34.461 PMdebug__3rd reality vib sensor: Parsing: catchall: 0104 0500 01 01 0040 00 E6D1 00 00 0000 04 01 861300
dev:7692023-12-06 04:27:33.213 PMinfoMotion Front Door Hue is inactive
dev:21572023-12-06 04:27:28.144 PMtrace__3rd reality vib sensor sendZigbeeCommands received : [he raw 0xE6D1 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, zdo bind 0xE6D1 0x01 0x01 0x0001 {282C02BFFFEDB442} {}, delay 2000, he cr 0xE6D1 0x01 1 32 32 43199 43200 {} {}, delay 2000, he raw 0xE6D1 1 0x01 0x0001 {10 00 00 20 00}, delay 2000, he wattr 0xE6D1 0x01 0x0500 0x0010 0xF0 {DF042016006F0D00}, delay 2000, he raw 0xE6D1 1 0x01 0x0500 {01 23 00 00 00}, delay 2000, he raw 0xE6D1 1 0x01 0x0500 {10 00 00 00 00}, delay 2000, null]
dev:21572023-12-06 04:27:28.137 PMtrace__3rd reality vib sensor sendZigbeeCommands received : [he wattr 0xE6D1 0x01 0x0500 0x0013 0x20 {00} {}, delay 2000]
dev:21572023-12-06 04:27:28.134 PMdebug__3rd reality vib sensor: Configuring vibration sensitivity to : 0
dev:21572023-12-06 04:27:28.126 PMinfo__3rd reality vib sensor: Battery reporting frequency: 12h
dev:21572023-12-06 04:27:28.122 PMinfo__3rd reality vib sensor: Updating preference settings
The x-y-x data is there, but the driver currently parses only the x-axis... If I have the time around Christmas, I can try adding the 3-axis reporting as an extra feature.
@kkossev checking to see if that 3axis data feature is a possibility and if so where I could find a copy of the driver? New to the HE scene. Much appreciated!
-N
I am currently working on another big project, so adding 3axis capability to this device is unlikely to happen soon.
I am using a SmartThings multipurpose sensor with HE, and it has been working great in the past years. This device easily detects someone trying to open the door, someone simply pressing the lock handle.
