Vertilux Blinds compatibility
Has anyone worked with VERTILUX Blinds? I went thru the site and indicate that they requiere a hub, but haven't found out any compatibility with HE
Thank you
Doing a quick scan of what's out there it looks like the VTI Smart Hub is a cloud based solution that can talk to other cloud based solutions. Locally it runs 433.92 MHz and IR in the range 20~60 KHzd. So not directly compatible with HE.
Thank you very much for the information
