So when reviewing the changes for rule machine 5.1 with update 2.2.9 it is states we should now be able to use variable states as part of predicate conditions once again. And I am again able to select variable as an option. However I'm still having the same issue as previously.
The room variable is changing correct by a similar leave room rule, correctly changing the variable to livingoom. The predicate is true when not bedroom, and it shows as such, but the status of the predicate condition remains false. And so it will not fire next time. Thus it seems I have to go back to using the connector.
Did I misunderstand the changes?
