Well just starting with Hubitat Elevation and so far I like it.
Well I know its a bit run before you can walk but could someone give a few pointers on how to implement a task for me.
simply put I wish to switch a wall sock off then on again a few minutes later but only after aI have logged off from my computer how would I make Hubitat sense that its occurred.
Scripted call to Maker API exposed virtual switch? ... as a scheduled task, if you can identify a way for logging out to trigger it (eg, Windows EventID associated with the act of logging out, never tried it, don't know if possible for sure)
hi
Yes its a windows 10 machine on the same network as the Hubitat There is also a sinology Nas drive on that network, the socket is a simple Zigbee one
cheers
You should be able to set a log off script to run on the computer which somehow calls a MakerAPI URL for a virtual switch, like @martybird suggested above.
