Using new aeotec dual micro driver - status issues
Well - that does work better :slight_smile: but it appears Parameter 80 is already set to 2.
Some interesting feedback when the driveway light turns on though. FYI - I pushed all 4 buttons so that the logs showed all the pertinent data. What do you make of this? Second to last line item...
dev:12020-06-04 08:59:58.565 pm infoCommandClassReport- class:0x60, version:2
dev:12020-06-04 08:59:58.504 pm infoAssociationReport- groupingIdentifier:1, maxNodesSupported:5, nodes:[1]
dev:12020-06-04 08:59:58.442 pm infoAssociationReport- groupingIdentifier:1, maxNodesSupported:5, nodes:[1]
dev:12020-06-04 08:59:58.378 pm infoAssociationReport- groupingIdentifier:1, maxNodesSupported:5, nodes:[1]
dev:12020-06-04 08:59:58.316 pm infoAssociationReport- groupingIdentifier:1, maxNodesSupported:5, nodes:[1]
dev:12020-06-04 08:59:58.262 pm infoAssociationReport- groupingIdentifier:1, maxNodesSupported:5, nodes:[1]
dev:12020-06-04 08:59:58.035 pm infoCommandClassReport- class:0x86, version:1
dev:12020-06-04 08:59:57.504 pm infoCommandClassReport- class:0x72, version:1
dev:12020-06-04 08:59:56.990 pm infoCommandClassReport- class:0x85, version:1
dev:12020-06-04 08:59:56.466 pm infoCommandClassReport- class:0x70, version:1
dev:12020-06-04 08:59:55.954 pm infoCommandClassReport- class:0x27, version:1
dev:12020-06-04 08:59:55.437 pm infoCommandClassReport- class:0x32, version:2
dev:12020-06-04 08:59:54.943 pm infoCommandClassReport- class:0x31, version:3
dev:12020-06-04 08:59:54.463 pm infoCommandClassReport- class:0x25, version:1
dev:2922020-06-04 08:59:20.041 pm errorjava.lang.IndexOutOfBoundsException: toIndex = 8 on line 235 (parse)
dev:2922020-06-04 08:59:19.942 pm debugParsed MeterReport(scale: 0, rateType: 1, scale2: 0, deltaTime: 600, previousMeterValue: [0, 2, 46, 229], meterType: 1, precision: 3, size: 4, meterValue: [0, 2, 46, 243]) to [['name':'energy', 'value':143.091, 'unit':'kWh'], hubitat.device.HubMultiAction@13a5628]
dev:12020-06-04 08:58:50.839 pm infoVersionReport- applicationVersion:1.7
dev:12020-06-04 08:58:50.837 pm infoVersionReport- zWaveProtocolVersion:2.78
dev:12020-06-04 08:58:50.835 pm infoVersionReport- zWaveLibraryType:Routing Slave
dev:12020-06-04 08:58:19.923 pm infoConfigurationReport- parameterNumber:80, size:1, value:2
dev:12020-06-04 08:58:19.834 pm infoConfigurationReport- parameterNumber:254, size:2, value:0
dev:12020-06-04 08:58:19.772 pm infoConfigurationReport- parameterNumber:252, size:1, value:0
dev:12020-06-04 08:58:18.169 pm infoConfigurationReport- parameterNumber:200, size:1, value:0
dev:12020-06-04 08:58:15.646 pm infoConfigurationReport- parameterNumber:120, size:1, value:1
dev:12020-06-04 08:58:15.416 pm infoConfigurationReport- parameterNumber:113, size:4, value:600
dev:12020-06-04 08:58:15.360 pm infoConfigurationReport- parameterNumber:112, size:4, value:600
dev:12020-06-04 08:58:15.308 pm infoConfigurationReport- parameterNumber:111, size:4, value:600
dev:12020-06-04 08:58:15.023 pm infoConfigurationReport- parameterNumber:103, size:4, value:0
dev:12020-06-04 08:58:14.968 pm infoConfigurationReport- parameterNumber:102, size:4, value:8
dev:12020-06-04 08:58:14.918 pm infoConfigurationReport- parameterNumber:101, size:4, value:4
dev:12020-06-04 08:58:14.612 pm infoConfigurationReport- parameterNumber:92, size:1, value:10
dev:12020-06-04 08:58:14.551 pm infoConfigurationReport- parameterNumber:91, size:2, value:50
dev:12020-06-04 08:58:14.492 pm infoConfigurationReport- parameterNumber:90, size:1, value:0
dev:12020-06-04 08:58:14.434 pm infoConfigurationReport- parameterNumber:89, size:1, value:1
dev:12020-06-04 08:58:14.167 pm infoConfigurationReport- parameterNumber:80, size:1, value:2
dev:12020-06-04 08:58:11.788 pm infoConfigurationReport- parameterNumber:3, size:1, value:0
dev:12020-06-04 08:58:11.746 pm infoConfigurationReport- parameterNumber:1, size:1, value:0
dev:12020-06-04 08:57:22.504 pm debugParsed MultiChannelCmdEncap(bitAddress:false, command:3, commandClass:32, destinationEndPoint:2, parameter:[255], res01:false, sourceEndPoint:2) to [['name':switch2, 'value':'on'], ['name':'switch', 'value':'on']]
dev:1382020-06-04 08:57:21.749 pm infoDriveway was turned on
Here are the logs for the Enerwave RSM2 dual switch as well. It appears as though the Enerwave is not responding to the the z-wave tool for the Get Parameter report. This is all I get. Push all 4 buttons, but also the Parameter Report several times.
dev:1612020-06-04 09:05:54.102 pm infoCommandClassReport- class:0x27, version:1
dev:1612020-06-04 09:05:53.886 pm infoCommandClassReport- class:0x27, version:1
dev:1612020-06-04 09:05:49.195 pm infoCommandClassReport- class:0x85, version:2
dev:1612020-06-04 09:05:49.155 pm infoCommandClassReport- class:0x85, version:2
dev:1612020-06-04 09:05:49.037 pm infoCommandClassReport- class:0x85, version:2
dev:1612020-06-04 09:05:48.902 pm infoCommandClassReport- class:0x85, version:2
dev:1612020-06-04 09:05:43.895 pm infoCommandClassReport- class:0x85, version:2
dev:1612020-06-04 09:05:43.811 pm infoCommandClassReport- class:0x85, version:2
dev:1612020-06-04 09:05:43.478 pm infoCommandClassReport- class:0x85, version:2
dev:1612020-06-04 09:05:42.671 pm infoCommandClassReport- class:0x85, version:2
dev:1612020-06-04 09:05:42.251 pm infoCommandClassReport- class:0x85, version:2
dev:1612020-06-04 09:05:41.936 pm infoCommandClassReport- class:0x85, version:2
dev:1612020-06-04 09:05:41.209 pm infoCommandClassReport- class:0x85, version:2
dev:1612020-06-04 09:05:41.002 pm infoCommandClassReport- class:0x85, version:2
dev:1612020-06-04 09:05:39.528 pm infoCommandClassReport- class:0x85, version:2
dev:1612020-06-04 09:05:39.155 pm infoCommandClassReport- class:0x85, version:2
dev:1612020-06-04 09:05:24.507 pm infoCommandClassReport- class:0x8E, version:2
dev:1612020-06-04 09:05:23.991 pm infoCommandClassReport- class:0x8E, version:2
dev:1612020-06-04 09:05:23.177 pm infoCommandClassReport- class:0x8E, version:2
dev:1612020-06-04 09:05:21.803 pm infoCommandClassReport- class:0x8E, version:2
dev:1612020-06-04 09:05:21.392 pm infoCommandClassReport- class:0x8E, version:2
dev:1612020-06-04 09:05:20.431 pm infoCommandClassReport- class:0x8E, version:2
dev:1612020-06-04 09:05:20.301 pm infoCommandClassReport- class:0x8E, version:2
dev:1612020-06-04 09:05:19.028 pm infoCommandClassReport- class:0x8E, version:2
dev:1612020-06-04 09:05:18.211 pm infoCommandClassReport- class:0x8E, version:2
dev:1612020-06-04 09:05:18.025 pm infoCommandClassReport- class:0x8E, version:2
dev:1612020-06-04 09:05:04.599 pm infoCommandClassReport- class:0x60, version:4
dev:1612020-06-04 09:05:04.107 pm infoCommandClassReport- class:0x25, version:1
dev:1612020-06-04 09:05:03.599 pm infoCommandClassReport- class:0x73, version:1
dev:1612020-06-04 09:05:03.097 pm infoCommandClassReport- class:0x5A, version:1
dev:1612020-06-04 09:05:02.542 pm infoCommandClassReport- class:0x72, version:2
dev:1612020-06-04 09:05:02.005 pm infoCommandClassReport- class:0x86, version:2
dev:1612020-06-04 09:05:01.536 pm infoCommandClassReport- class:0x5E, version:2
dev:1612020-06-04 09:04:59.768 pm infoAssociationReport- groupingIdentifier:1, maxNodesSupported:1, nodes:[1]
Any ideas on the above log files?
No help I'm afraid but I have the same issue with my aeotec dual nano switches with the new driver. I.e. switching works, parameter 80 is set to basic but still the status of the switch doesn't update unless I refresh. Did you get anywhere with this?
Nope -no one has commented since I posted the logs. I’d really like to get these working too. Not sure what is so difficult about these switches. They worked with other hubs.
Try it removing it from HE, then factory reset it and then re join it that usually fixes odd ones. Also check that your on the latest firmware.
Will give that a go this evening, thanks. I hope it works. Will report back here.
@mike.maxwell or @aaiyar - have you had a chance to look at these logs?
@Boris - the older micro switches do not have any firmware update capabilities as per Aeotec. The nano on the other hand does, so that may help @chris.parsons85
Any news on a new driver for the Aeotec dual micro as mentioned earlier?
Also - any news on a driver for a dual enerwave?
Can anyone help here?
You need to have logs open, nothing happens on the device page.
I think your issue is polling after reading this again. I assume that the micro is z-wave rather than z-wave plus? Wink does polling on all devices no matter what (not a good idea for your network) hubitat you need to add the app and specify the devices you want to pole.
When doing logs do a screen shot and hide it in the "hide details" options in the settings cog when you do a post, this will make them easier to read.
I tried ZWave polling, but no devices show up in the drop down. I assume that means all of my devices are Z-wave Plus, so this does no good.
Ok - now all my virtual devices stopped working. Did something change with a recent update? I tried a full shutdown and power cycle but no change. Devices still work but virtual switches stopped working.
