Using HE with with InfluxDB, Grafana, with InfluxDB Logger
Create Visualizations and Dashboards
Hubitat community shared dashboards
The easiest way to get started with a dashboard will be to obtain shared dashboards from Community members. You can find shared dashboards in the below thread. From here obtain the raw JSON and import it into Grafana using the below procedure.
Here is one of my dashboards that simply shows various temps throughout the house.
  "__inputs": [
      "name": "DS_INFLUXDB",
      "label": "InfluxDB",
      "description": "",
      "type": "datasource",
      "pluginId": "influxdb",
      "pluginName": "InfluxDB"
  "__elements": {},
  "__requires": [
      "type": "grafana",
      "id": "grafana",
      "name": "Grafana",
      "version": "10.0.2"
      "id": "influxdb",
      "name": "InfluxDB",
      "version": "1.0.0"
      "type": "panel",
      "id": "timeseries",
      "name": "Time series",
      "version": ""
  "annotations": {
    "list": [
        "builtIn": 1,
        "datasource": {
          "uid": "grafana"
        "enable": true,
        "hide": true,
        "iconColor": "rgba(0, 211, 255, 1)",
        "name": "Annotations & Alerts",
        "target": {
          "limit": 100,
          "matchAny": false,
          "tags": [],
          "type": "dashboard"
        "type": "dashboard"
  "editable": true,
  "fiscalYearStartMonth": 0,
  "graphTooltip": 0,
  "id": null,
  "links": [],
  "liveNow": false,
  "panels": [
      "datasource": {
        "type": "influxdb",
        "uid": "${DS_INFLUXDB}"
      "fieldConfig": {
        "defaults": {
          "color": {
            "mode": "palette-classic"
          "custom": {
            "axisCenteredZero": false,
            "axisColorMode": "text",
            "axisLabel": "",
            "axisPlacement": "auto",
            "barAlignment": 0,
            "drawStyle": "line",
            "fillOpacity": 0,
            "gradientMode": "none",
            "hideFrom": {
              "legend": false,
              "tooltip": false,
              "viz": false
            "lineInterpolation": "linear",
            "lineWidth": 1,
            "pointSize": 5,
            "scaleDistribution": {
              "type": "linear"
            "showPoints": "auto",
            "spanNulls": false,
            "stacking": {
              "group": "A",
              "mode": "none"
            "thresholdsStyle": {
              "mode": "off"
          "mappings": [],
          "thresholds": {
            "mode": "absolute",
            "steps": [
                "color": "green",
                "value": null
                "color": "red",
                "value": 80
        "overrides": []
      "gridPos": {
        "h": 9,
        "w": 12,
        "x": 0,
        "y": 0
      "id": 10,
      "options": {
        "legend": {
          "calcs": [],
          "displayMode": "list",
          "placement": "bottom",
          "showLegend": true
        "tooltip": {
          "mode": "single",
          "sort": "none"
      "targets": [
          "alias": "$tag_deviceName",
          "datasource": {
            "type": "influxdb",
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
              "params": [
                "deviceName"
              "type": "tag"
              "params": [
                "previous"
              "type": "fill"
          "measurement": "temperature",
          "orderByTime": "ASC",
          "policy": "default",
          "refId": "A",
          "resultFormat": "time_series",
          "select": [
                "params": [
                  "value"
                "type": "field"
                "params": [],
                "type": "mean"
          "tags": [
              "key": "deviceName",
              "operator": "=~",
              "value": "/^$hvac_temp_Sensors$/"
          "datasource": {
            "type": "influxdb",
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
              "params": [
                "deviceName"
              "type": "tag"
              "params": [
                "previous"
              "type": "fill"
          "hide": true,
          "refId": "B",
          "select": [
                "params": [
                  "value"
                "type": "field"
                "params": [],
                "type": "mean"
          "tags": [
              "operator": "=",
              "value": "EcobeeSensor: Master Bedroom (GKT2)"
          "datasource": {
            "type": "influxdb",
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
              "params": [
                "deviceName"
              "type": "tag"
              "params": [
                "previous"
              "type": "fill"
          "hide": true,
          "refId": "C",
          "select": [
                "params": [
                  "value"
                "type": "field"
                "params": [],
                "type": "mean"
          "tags": [
              "operator": "=",
              "value": "EcobeeSensor: Thermostat (Thermostat)"
          "datasource": {
            "type": "influxdb",
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
              "params": [
                "deviceName"
              "type": "tag"
              "params": [
                "previous"
              "type": "fill"
          "hide": true,
          "refId": "D",
          "select": [
                "params": [
                  "value"
                "type": "field"
                "params": [],
                "type": "mean"
          "tags": [
              "operator": "=",
              "value": "EcobeeSensor: Study (GK3Q)"
          "datasource": {
            "type": "influxdb",
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
              "params": [
                "deviceName"
              "type": "tag"
              "params": [
                "previous"
              "type": "fill"
          "hide": true,
          "refId": "E",
          "select": [
                "params": [
                  "value"
                "type": "field"
                "params": [],
                "type": "mean"
          "tags": [
              "operator": "=",
              "value": "EcobeeTherm: Thermostat"
      "title": "Ecobee Temperatures",
      "type": "timeseries"
      "datasource": {
        "type": "influxdb",
      "fieldConfig": {
        "defaults": {
          "color": {
          "custom": {
            "axisLabel": "",
            "barAlignment": 0,
            "fillOpacity": 0,
            "hideFrom": {
              "legend": false,
              "tooltip": false,
              "viz": false
            "lineWidth": 1,
            "pointSize": 5,
              "type": "linear"
            "spanNulls": false,
            "stacking": {
              "group": "A",
              "mode": "none"
              "mode": "off"
          "mappings": [],
          "thresholds": {
            "mode": "absolute",
            "steps": [
                "color": "green",
                "value": null
                "color": "red",
                "value": 80
        "overrides": []
      "gridPos": {
        "h": 9,
        "w": 12,
        "x": 12,
        "y": 0
      "id": 2,
      "options": {
        "legend": {
          "calcs": [],
          "showLegend": true
        "tooltip": {
          "mode": "single",
          "sort": "none"
      "pluginVersion": "9.4.3",
      "targets": [
          "datasource": {
            "type": "influxdb",
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
              "params": [
                "deviceName"
              "type": "tag"
              "params": [
                "previous"
              "type": "fill"
          "refId": "A",
          "select": [
                "params": [
                  "value"
                "type": "field"
                "params": [],
                "type": "mean"
          "tags": [
              "operator": "=~",
              "value": "/^$alt_Indoor_Temp$/"
      "title": "House Temperature Sensors",
      "datasource": {
        "type": "influxdb",
      "fieldConfig": {
        "defaults": {
          "color": {
          "custom": {
            "axisLabel": "",
            "barAlignment": 0,
            "fillOpacity": 10,
            "hideFrom": {
              "legend": false,
              "tooltip": false,
              "viz": false
            "lineWidth": 1,
            "pointSize": 5,
              "type": "linear"
            "showPoints": "never",
            "spanNulls": false,
            "stacking": {
              "group": "A",
              "mode": "none"
              "mode": "off"
          "mappings": [],
          "thresholds": {
            "mode": "absolute",
            "steps": [
                "color": "green",
                "value": null
                "color": "red",
                "value": 80
          "unit": "short"
        "overrides": []
      "gridPos": {
        "h": 8,
        "w": 12,
        "x": 0,
        "y": 9
      "id": 6,
      "options": {
        "legend": {
          "calcs": [],
          "showLegend": true
        "tooltip": {
          "mode": "multi",
          "sort": "none"
      "pluginVersion": "10.0.2",
      "targets": [
          "datasource": {
            "type": "influxdb",
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
              "params": [
                "deviceName"
              "type": "tag"
              "params": [
                "previous"
              "type": "fill"
          "refId": "A",
          "select": [
                "params": [
                  "value"
                "type": "field"
                "params": [],
                "type": "mean"
          "tags": [
              "operator": "=~",
              "value": "/^$outdoor_Temp_Sensors$/"
      "title": "Outdoor Temps",
      "datasource": {
        "type": "influxdb",
      "description": "",
      "fieldConfig": {
        "defaults": {
          "color": {
          "custom": {
            "axisLabel": "",
            "barAlignment": 0,
            "fillOpacity": 10,
            "hideFrom": {
              "legend": false,
              "tooltip": false,
              "viz": false
            "lineWidth": 1,
            "pointSize": 5,
              "type": "linear"
            "spanNulls": false,
            "stacking": {
              "group": "A",
              "mode": "none"
              "mode": "off"
          "mappings": [],
          "thresholds": {
            "mode": "absolute",
            "steps": [
                "color": "green",
                "value": null
                "color": "red",
                "value": 80
          "unit": "short"
        "overrides": []
      "gridPos": {
        "h": 8,
        "w": 12,
        "x": 12,
        "y": 9
      "id": 8,
      "options": {
        "legend": {
          "calcs": [],
          "showLegend": true
        "tooltip": {
          "mode": "multi",
          "sort": "none"
      "targets": [
          "datasource": {
            "type": "influxdb",
          "groupBy": [
              "params": [
                "$__interval"
              "type": "time"
              "params": [
                "deviceName"
              "type": "tag"
              "params": [
                "previous"
              "type": "fill"
          "refId": "A",
          "select": [
                "params": [
                  "value"
                "type": "field"
                "params": [],
                "type": "mean"
          "tags": [
              "operator": "=~",
              "value": "/^$misc_Temp_Sensor$/"
      "title": "Misc Temp Sensors",
  "refresh": "",
  "revision": 1,
  "schemaVersion": 38,
  "style": "dark",
  "tags": [],
  "templating": {
    "list": [
        "current": {
          "selected": false,
          "text": "InfluxDB",
          "value": "InfluxDB"
        "hide": 0,
        "includeAll": false,
        "label": "Datasource",
        "multi": false,
        "name": "datasource_InfluxDB",
        "options": [],
        "query": "influxdb",
        "queryValue": "",
        "refresh": 1,
        "regex": "",
        "skipUrlSync": false,
        "current": {},
        "datasource": {
          "type": "influxdb",
        "definition": "select DISTINCT(\"deviceName\") FROM (select * from \"temperature\" where $timeFilter)",
        "hide": 0,
        "label": "HVAC Temp Sensors",
        "multi": true,
        "name": "hvac_temp_Sensors",
        "options": [],
        "query": "select DISTINCT(\"deviceName\") FROM (select * from \"temperature\" where $timeFilter)",
        "refresh": 1,
        "regex": "",
        "sort": 0,
        "type": "query"
        "current": {},
        "datasource": {
          "type": "influxdb",
        "hide": 0,
        "label": "Alternate Indoor Temp Sensors",
        "multi": true,
        "name": "alt_Indoor_Temp",
        "options": [],
        "refresh": 1,
        "regex": "",
        "sort": 0,
        "type": "query"
        "current": {},
        "datasource": {
          "type": "influxdb",
        "hide": 0,
        "label": "Outdoor Sensors",
        "multi": true,
        "name": "outdoor_Temp_Sensors",
        "options": [],
        "refresh": 1,
        "regex": "",
        "sort": 0,
        "type": "query"
        "current": {},
        "datasource": {
          "type": "influxdb",
        "hide": 0,
        "label": "Misc Temp Sensors",
        "multi": true,
        "name": "misc_Temp_Sensor",
        "options": [],
        "refresh": 1,
        "regex": "",
        "sort": 0,
        "type": "query"
  "time": {
    "from": "now-24h",
    "to": "now"
  "timepicker": {},
  "timezone": "",
  "title": "Home Temps",
  "uid": "b024c58d-a552-4f80-a207-e81228b9316b",
  "version": 7,
  "weekStart": ""
Log into Grafana and click on the 3-line sandwich icon in the upper left of the page. Then click on Dashboards. This will load the Dashboard page that will list all of the dashboards you have loaded. From here on the far right of the window there will be an option for “New” Select that and click on Import. Now past the Raw JSON data you copied into the window labled “Import via panel json” and click load.
Now you should have the dashboard available in the list and you can open it. Now based on the dashboard you will need to likely fill in variable across the top to enable access to your specific InfluxDB Database for HE. Once all the variables are setup Click on save and select the checkbox to save the variable settings. Lastly click Save Again. Now you have a working dashboard.
