I have a Home Assistant tag reader and want to use it with Habitat. Is there a YAML file I need to compile to make it work. I have a grasp on writing the cards using Tag reader Pro. Thanks guys/gals.
How do you plan on integrating home assistant hardware with hubitat? I don’t think there’s a hubitat driver for the HA tag reader but there is a HA hubitat bridge.
Your YMAL here is rule machine, with Hubitat you will need to create a local or cloud endpoint using rule machine and then create the automation. Take a look at this link, it has a step-by-step process for creating the endpoint.
How-To: Program NFC Tags/Stickers For Automations In Hubitat
