#1
There is small inconsistency between regular UI and Zigbee Network Graph. If I want to have clean "rooms" (and not too long names of devices) I had to give up on adding ROOM information in device name. On other hand, when I strip ROOM information from device name, then I had a lot of devices on Network Graph, without possibility to assign information where they are located, because I stripped ROOM from name.
Idea is: could Network Graph contain in brackets () room information?
#2: there is still inconvenience with "ROOM", that I described here:
I kindly ask you to consider making the suggested changes.
