Use of Bond Bridge Pro with 2.4 GHz remotes
Has anyone cracked this? I have 4 x 800mhz fans remotes, 2 x 2400 mhz fans remotes & 2 x manual switch fans.
Hubitat (via Bond Bridge Pro) sees the 800mhz fans (and their built in lights) but BB Pro won’t see the 2400mhz fan remotes as that is outside the BB frequency range and so can’t be added.
Anyone have a workaround? Would a universal remote help or would that just mimic the same frequency?
For the manual switches I will buy some zooz type products.
Are these BT?
No. RF controlled
Using
https://fccid.io/R8Y7RC04-CF100001/User-Manual/Users-manual-pdf-2136537
Then you might be out of luck. I'm unaware of any off-the-solution.
They're should be some kind of "solution" given it is a supported platform.. Obviously plenty of caveats to that statement.... Personally I am still using dman's old Community solution with an old Bond bridge....
What’s a supported platform? Bond doesn’t support 2.4 GHz RF devices.
The issue isn't with HE's Bond implementation, it's the fact that Bond itself doesn't cover that freq at all.
And my reading ability... :wink:
You’re way too young for that!!
I like to push boundaries... :slight_smile:
... particulary when I am going to mis-interpret a requirement....
Yeah, I've got a remote on that frequency also, have been advised the device will not be replaced and would love to figure out a way to get HE control of the device. My Bond Bridge won't. So far I've found:
I have not yet done any of these...
