Updating driver for Zooz ZEN54?
I've got this Zooz ZEN54 0-10V dimmer. It works pretty well, except that by default it takes 5 seconds to turn on or off. I was able to use the Basic Z-wave tool to change its dimming speed parameter, but it's a clunky workaround.
The supplied driver has some parameters that can be changed, but not all of the supported ones: ZEN54 0-10 V Dimmer Advanced Settings - Zooz Support Center
How can the built-in ZEN54 driver be enhanced? Their code isn't available, right?
I've got you covered. Try this: [DRIVER] Zooz ZEN54 10V Dimmer Advanced
Sweet, thanks!
No, but we can add it. What parameter are you looking for? It looks like they may have added/changed some parameters with firmware updates, so it's likely these didn't exist if the driver was written for the original device as-is...
Ideally, all of them, but at least the ramp rate & dimming speed settings. Type of wall switch is probably important.
These parameters should appear on the built-in driver in 2.4.1 (currently in beta, no estimate for public release) on firmware 1.40+, assuming the firmware version numbers reported match the ones Zooz provided in their documentation.
"Switch Type" and "Smart Bulb Mode" are parameters 12 and 11, so those are already there, unless you're taking about something else.
Thanks!
