BTW
If I have missed an important attribute or you need a different combination of attributes, please let me know and I'll look at coding it for you
Andy
BTW
Andy
Andy I created a weeWX extension that installs a new skin called Hubitat and installs daily.json.tmpl
Scott
Thatâs brilliant!
Do you have it running somewhere so we can see the skin?
Andy
It's not a REAL skin.... the only thing it does is create the template skin.
The extension does all this automatically. And doesn't matter what skin you are using. It creates the daily.json in the HTML_ROOT found in your weewx.conf
And PLEASE don't rip Andy's code !!! He and I have spent hours debugging this to make it work.
WOW, Was just trying to help. Tough crowd
You added code in the middle of another routine which could make the driver unstable.
I spent many hours rewriting parts of the code to get the information into a new method/routine
I made this mistake in one of my apps where I added code from another source - I have since had to rip it out as it caused problems
Not my comment.
However; I realise that this platform uses open source licenses and I am unable to compile my drivers/apps so not much I can do about people copying my code to use in their own apps/drivers
Hi Cobra! Really useful driver. Thank you.
One thing that came up - I am generating daily.json with temperature symbol (F) already present and this generates double FF - would be nice to have an option not to include temperature measurement symbol in dropdown.
Turn this off
Upon more investigation (even with Display data units off) I am getting FF in WeatherDisplay attribute
DriverStatus : Current
DriverUpdate : N/A
DriverVersion : 2.8.0
LastUpdate-External : 2019-02-12 11:45
LastUpdate-Weewx : 02/12/2019 11:55:00 AM
Refresh-External : 3 Hours
Refresh-Weewx : 5 Minutes
WeatherDisplay : Ada Weather
Current Weather: Light freezing rain
Forecast Weather: Blizzard
Temp: 27.7°F °F - Feels like 27.0°F °F
Wind: 2 mph, Gust: 4 mph
Pressure: 29.976 inhg
Humidity: 99%
Chance of Rain: null%
WeewxLocation : Ada, MI
WeewxUptime : 2 days, 17 hours, 29 minutes
city : Ada
country : USA
dewpoint : 27.4°F
feelsLike : 27.0°F
forecastHigh : 34.2
forecastIcon : snow
forecastLow : 21.6
humidity : 99
Is it the 'standard' dashboard summary or a custom one?
That was custom.
Here is standard:
DriverUpdate : N/A
LastUpdate-External : 2019-02-12 12:45
LastUpdate-Weewx : 02/12/2019 12:50:00 PM
Temp: 28.9°F °F - Feels like 28.9°F °F
Wind: 1 mph, Gust: 3 mph
Pressure: 29.964 inhg
Humidity: 99%
WeewxUptime : 2 days, 18 hours, 24 minutes
city : Ada
country : USA
dewpoint : 28.7°F
feelsLike : 28.9°F
forecastHigh : 34.2
forecastIcon : snow
forecastLow : 21.6
humidity : 99
illuminance : No Station Data
inside_humidity : No Station Data
inside_temperature : 63.0°F
If you have units turned off then you shouldn't be seeing these
They must be coming from the json file
Which json file are you using?
silly question... you did 'save' the preferences after turning off the units?
this is my daily.json.tmpl
#encoding UTF-8
"title":"Current Values",
"location":"$station.location",
"time":"$current.dateTime",
"lat":"$station.latitude[0]° $station.latitude[1]' $station.latitude[2]",
"lon":"$station.longitude[0]° $station.longitude[1]' $station.longitude[2]",
"alt":"$station.altitude",
"hardware":"$station.hardware",
"uptime":"$station.uptime",
"serverUptime":"$station.os_uptime",
"weewxVersion":"$station.version",
"stats": {
"current": {
"outTemp":"$current.outTemp",
"windchill":"$current.windchill",
"heatIndex":"$current.heatindex",
"dewpoint":"$current.dewpoint",
"humidity":"$current.outHumidity",
"insideHumidity":"$current.inHumidity",
"barometer":"$current.barometer",
"barometerTrendDelta":"$trend.time_delta.hour.format("%.0f")",
"barometerTrendData":"$trend.barometer",
"windSpeed":"$current.windSpeed",
"windDir":"$current.windDir",
"windDirText":"$current.windDir.ordinal_compass",
"windGust":"$current.windGust",
"windGustDir":"$current.windGustDir",
"rainRate":"$current.rainRate",
#if $day.extraTemp1.has_data
"pondTemp":"$current.extraTemp1",
#end if
#if $day.UV.has_data
"UV":"$current.UV",
#end if
#if $day.ET.has_data and $day.ET.sum.raw > 0.0
"ET":"$current.ET",
#end if
#if $day.radiation.has_data
"solarRadiation":"$current.radiation",
#end if
"insideTemp":"$current.inTemp"
"sinceMidnight": {
"rainSum":"$day.rain.sum",
"maxtemptoday":"$day.outTemp.max",
"mintemptoday":"$day.outTemp.min",
"maxinsidetemptoday":"$day.inTemp.max",
"mininsidetemptoday":"$day.inTemp.min"
"almanac":{
#if $almanac.hasExtras
"sun":{
"startCivilTwilight":"$almanac(horizon=-6).sun(use_center=1).rise",
"sunrise":"$almanac.sun.rise",
"transit":"$almanac.sun.transit",
"sunset":"$almanac.sun.set",
"endCivilTwilight":"$almanac(horizon=-6).sun(use_center=1).set",
"azimuth":"$("%.1f°" % $almanac.sun.az)",
"altitude":"$("%.1f°" % $almanac.sun.alt)",
"rightAscension":"$("%.1f°" % $almanac.sun.ra)",
"declination":"$("%.1f°" % $almanac.sun.dec)",
"equinox":"$almanac.next_equinox",
"solstice":"$almanac.next_solstice"
"moon":{
"rise":"$almanac.moon.rise",
"transit":"$almanac.moon.transit",
"set":"$almanac.moon.set",
"azimuth":"$("%.1f°" % $almanac.moon.az)",
"altitude":"$("%.1f°" % $almanac.moon.alt)",
"rightAscension":"$("%.1f°" % $almanac.moon.ra)",
"declination":"$("%.1f°" % $almanac.moon.dec)",
"fullMoon":"$almanac.next_full_moon",
"newMoon":"$almanac.next_new_moon",
"phase":"$almanac.moon_phase",
"fullness":"$almanac.moon_fullness%"
#else
"sun":{
"sunrise":"$almanac.sunrise",
"sunset":"$almanac.sunset",
"moon":{
#end if
And her it is populated:
"location":"Ada, MI",
"time":"02/12/2019 01:05:00 PM",
"lat":"42° 58.21' N",
"lon":"085° 33.40' E",
"alt":"830 feet",
"hardware":"AcuRite 01536",
"uptime":"0 days, 20 hours, 36 minutes",
"serverUptime":"2 days, 18 hours, 39 minutes",
"weewxVersion":"3.8.2",
"stats": {
"current": {
"outTemp":"29.3°F",
"windchill":"28.7°F",
"heatIndex":"29.3°F",
"dewpoint":"29.1°F",
"humidity":"99%",
"insideHumidity":" N/A",
"barometer":"29.990 inHg",
"barometerTrendDelta":"3 hours",
"barometerTrendData":"0.052 inHg",
"windSpeed":"2 mph",
"windDir":"88°",
"windDirText":"E",
"windGust":"4 mph",
"windGustDir":"112°",
"rainRate":"0.00 in/hr",
"insideTemp":"63.1°F"
"sinceMidnight": {
"rainSum":"0.00 in",
"maxtemptoday":"29.3°F",
"mintemptoday":"23.7°F",
"maxinsidetemptoday":"64.1°F",
"mininsidetemptoday":"61.6°F"
"almanac":{
"sun":{
"sunrise":"08:19:51 PM",
"sunset":"06:44:07 AM",
"moon":{
"phase":"First quarter",
"fullness":"48%"
they are coming from json
The driver was designed to strip these units off and only replace them at the end (if configured to)..
Not sure why yours are not being stripped off
