[UPDATED] - Weather Switch - Turn on a switch in response to weather
You should now get something like this:
Ok
New version released on GitHub (link above)
The driver now creates a 'summary report' of the data collected.
You can select how to format it (imperial/metric etc)
I'm intending to use this with a new release of Weather Switch to SMS or use PushOver to send this report
For this version I have included the lowercase attributes
Let me know what you think and how you get on.
Andy
Good Afternoon!!
I loaded the new driver (with lowercase in the title) and the WS app is working find. Here's the view of the summary though I have to force a poll to get it on the page:
Here is the weather tile:
45%20AM
I added in an - attribute "city", "string" to pull the city:
47%20AM
I'm getting called into work early so I don't have time to hunt down by the percentPrecip nor the humidity are showing up. I'll give it a look over when I get back though.
Everything is looking pretty solid so far!
If you are using station id: KCALOSAN362
Then I can’t see that it reports percentPrecip
I loaded this station into my driver and did a search for it but could not find it
Humidity is being reported from the capability so that should be the same as previuosly
Andy
I think we are both dancing around the same head of a pin. In that SmartTile, the info use to be there. This whole experience now leads me to question whether it was accurate which links to your point about my station. The perecentPrecip is a forecast and wouldn’t be provided by the weather station. So how it use to get it from the default or older driver I was using (which I lost in all of this shuffle), is still a mystery to me.
As far as I’m concerned your app is spot on and works for me. The SmartTile is more of a distraction with an app that isn’t being updated so it’s more of a curiosity to me. I’m sure there’s an easy answer to it.
I’ve added the ā€˜city’ attribute and sendEvent so that should work ok now.
I’ve also marked a couple of things to refresh when polled - they were not refreshing correctly before
Latest Driver version: 1.8.0
Andy
@homeauto2112
Ok… I think I got it!
we were looking for the wrong data name - It’s not percentPrecip but ā€˜pop’ (Probability of Precipitation)
Also I found a bug with the summary so it should show correctly now without having to poll
Have a look at version 1.9.0 on GitHub
This now has an attribute & sendEvent for ā€˜percentPrecip’ as requested :slight_smile:
I have also uploaded a new version of the app which can use ā€˜Chance Of Rain’ as a trigger
Andy
Good afternoon!
Just got up and will try the drive as soon as the coffee is brewed. The ā€œpercentPrecipā€ came directly from the code in SmartTiles. At this point (without having tried the 1.9.0 driver), the WS app works and most of the SmartTiles code works as well. For some odd reason, the humidity isn’t reporting correctly and I didn’t have any time yesterday to look into it.
Coffee is done and trying the new driver now.
Okay, the driver looks good. App is responding as it should. I forgot to post this earlier, but I receive the following error when I select the "poll"
This error seems to occur whether the auto poll is on or off.
BTW: I’m really enjoying the illuminance!
I started to play with the HU dashboard and here's a screenshot. Not sure why the humidity is showing a double % sign.
For Cobra's driver are you using the attributes option when setting up the tile? I was first just using the Humidity and was getting the double % like yours is showing. I also noticed that the value was wrong. Started digging around and found the attribute option and all is good now.
HE-weathertile-options
Hope this helps.
That’s a nice find!!
I’ve noticed the values were wrong too, but I’m also seeing that it may be due to the differing refresh times. If there are two ā€œdevicesā€ with refresh commands timers and cacheing, there will be some differences. If I refresh both the WU and the dashboard, then I get a correct entry. Now sometimes I have to refresh a few times to sync things.
Guys
I’ve 'tweaked’ the driver to try and get rid of the double percentage
Not sure if it will work
If it doesn’t please let me know and I’ll look again
Uploaded new files to github (same version number)
Andy
This error relates to the max polling time… ā€œpoll interval limitā€ do you have a figure in there?
Andy
@homeauto2112
Thank you SO much for your donation (far too much)
I really appreciate it
Andy
lol…I think you earned it just in putting up with me and my SmartTiles woes. You are very welcome!
I do not. I didn't get any errors in saving the current config even though that field is labeled as "required: true"
I have no idea how you managed to save it :slight_smile:
Ok… any figure in there should stop the error
Andy
Guys
thanks to @Matthew on another thread I should have fixed the double % issue
I didn’t realise that the dashboards were putting their own % sign in… so we have to strip it off the data returned from WU
This fix has been applied now, but only to the lowercase sendEvent as it is needed for the uppercase version for WS
Driver version: 2.0.0
Please let me know if this doesn’t work (it should do!)
Andy
