Hi, I've just approved it.
Although you'll receive a mail saying "use your existing password", enter your username on the site, then hit "forgot password", you'll be sent another.
Thanks a lot! Will have a play tomorrow, but this is already looking pretty good!
@Royski - I suspect it's something basic that I'm missing, but I seem to be getting 'null' values for all the attributes that I pick.
EDIT: Ignore, turns out I just had to be a bit patient and wait for a refresh...
Hi there! Thanks for all your amazing work and contributions @cobra and @Royski!!!!
I am loving Supertile... however I have a question... I uploaded icons and images to my hub set up my icons and image urls locally using http:// and they work great but only locally... Am I doing it wrong? I can t see them in my dashboard via cloud...
Thanks for any help!
If you want to see them from ‘the cloud’ then the images need to also be hosted in ‘the cloud’
This is because local images are not available To view from the internet
Andy
Thank U! Your reply was lightning fast!!!
Oh wow ok I misunderstood! I thought the key was to have them local on the hub! So Is best practice to host them perhaps on my site and just point it to that? Or to open a port to a local machine ? I would assume the latter would be less safe but in theory more “local”
It would be awesome to be able to have a different url for local and different one for cloud!
Created an account on cobra-apps.co.uk several days ago - anyone know how long does it typically takes to get approved?
Cheers Nic
@lazarus you should now have received a mail. If the password doesn’t work, fill in your username and hit the forgot password link. You’ll be sent a new one, once received, simply activate it, and you’ll be in.
Apologies for the system missing you
Is anyone else having trouble getting to some of the pages on cobra-apps.co.uk @Royski or @Cobra ?
Can you tell me which pages, I’ll take a look.
Using the left hand menu, choosing apps, the first three selections in the popup menu don't work. The fourth 'Dashboards' the first choice sonos does work, but the second super tile, does not. There are others.
Some give a message about too many redirections others just show a broken document.
Many thanks I’ll take a look as soon as I can.
Awesome. Thank you for the very quick response.
Ok, seems we had some small issue.
I've resolved the Apps, but will need to do the drivers tomorrow.
But many thanks for raising this, I had no idea
I'm new to the site, so I thought I was doing something wrong.
Thanks for looking into it.
Er, uh, @Royski Could you please take a look at the 'Contact Us' page, I found a problem to report.
Naturally, the new guy goes in and screws stuff up. Naturally.
Correction, two problems. They're both the same though, just different places.
Is there any ways (likely outside the super tiles app capabilities) to display a variable on a super tile that has say 10 decimal points, to only show one or two decimal points.. I realise I could make an extra variable defined as an integer to equal the decimal variable. But that would mean either I display 10 decimal points or none..
Edit. I guess I can assign a integer variable to equal 10x the decimal variable I want to display.. Then assign a decimal variable to equal the integer variable divided by 10. That would give one decimal point (not rounded, but it's only for display purposes on a tile)... But to do that for multiple variables is sure creating a lot of extra variables that only get used for formatting purposes.
