Interesting.... Are there any differences ? For instance BT2 does not support tamper events does yours ?
It doesnāt, however; if there is enough call for it then it can be added.
Message Central has a big release coming up soon so once that is done and everything is settled down Iāll look at the feature list again.
Iām currently updating 19 apps so donāt have a lot of time to do anything.
Andy
fair enough
I haven't read this whole thread, but just installed Message Central as I have notifications in RM and HSM. First one I tested using pushover, I want to have a message that shows:
"Dog Door is open - 11/29/2018 7:32 pm"
What I get is all lowercase and the date is spelled out:
"dog door is open - the 29th of november 7 30 pm"
Any chance of having different date/time formats, and having it follow the case that I entered in the app?
I'd also be interested in having a "contact closed too long" option, as well as a periodic reminder when a contact is left open or closed. Not sure if those are on your radar but consider them requested
Unfortunately, converting everything to lowercase is currently essential to be able to match any case of the variables.
This may change but will inevitably cause problems when people donāt use the correct case for the variable.
Converting the date format to English is so that it speaks it properly when using voice.
I donāt want my dates read out as 29 11 2018
I'll look at making this optional but it may take a while as I'm busy with other things right now
Can you give me a use case for āclosed too longā
I canāt think when that would be used
Andy
Ok no worries, I realize this is intended primarily for speech devices rather than text notifications.
The closed too long thing is for a dog door, it's normally open but sometimes we close it and forget it's closed.
Don't worry about my requests, they are probably edge cases anyway, and I already have everything running the way I want in RM. Was really just looking for a way to split off and group the notification stuff together.
2 questions:
- Can I get a message to be repeat every 15 min? example: I leave the garage door open when I get home, can I repeat the message every 15 min until I close it.
- Can I get a message on a temperature comparison: If outside temp> inside temp and front door is open, send a message?
Thanks,
Craig
There is currently no 'repeat' feature in MC.
However; I like the idea and can work on that for a future release.
Not at this time
I am trying to delay my garage door message by 15 min when I get home.
but it plays immediately
app:12332018-12-06 04:30:04.072 pm debugGARAGE_DOOR_IS_OPEN (App Version: 13.5.0) - Enable switch is NOT used. Switch is: null - Continue..
app:12332018-12-06 04:30:04.070 pm debugGARAGE_DOOR_IS_OPEN (App Version: 13.5.0) - Initialising defaults...
app:12332018-12-06 04:30:01.803 pm debugGARAGE_DOOR_IS_OPEN (App Version: 13.5.0) - trigger is Contact
app:12332018-12-06 04:30:01.793 pm debugGARAGE_DOOR_IS_OPEN (App Version: 13.5.0) - Enabled by parent - Disable app = false
app:12332018-12-06 04:29:29.250 pm debugGARAGE_DOOR_IS_OPEN (App Version: 13.5.0) - Timer 1 reset - state.timer1 = true - Messages allowed
app:12332018-12-06 04:29:29.128 pm debugGARAGE_DOOR_IS_OPEN (App Version: 13.5.0) - Waiting for 0 seconds before resetting timer1 to allow further messages
app:12332018-12-06 04:29:29.124 pm debugGARAGE_DOOR_IS_OPEN (App Version: 13.5.0) - state.msgDelay = 0
app:12332018-12-06 04:29:28.848 pm debugGARAGE_DOOR_IS_OPEN (App Version: 13.5.0) - Compiled Message = the garage door is open
app:12332018-12-06 04:29:28.846 pm debugGARAGE_DOOR_IS_OPEN (App Version: 13.5.0) - 2nd Stage Compile (Post weather processing) = the garage door is open
app:12332018-12-06 04:29:28.845 pm debugGARAGE_DOOR_IS_OPEN (App Version: 13.5.0) - Running convertWeatherMessage... Converting weather message to English (If weather requested)...
app:12332018-12-06 04:29:28.843 pm debugGARAGE_DOOR_IS_OPEN (App Version: 13.5.0) - 1st Stage Compile (Pre weather processing) = the garage door is open
Wrong setup? Also if I close the door after the delay, will that cancel the TTS?
I've just had a quick look at the code.
The code for the delay after trigger but before message is missing on speech synth
It's there on the musicplayer but I must have missed it off on the speechsynth (which was added at a later date - the original being musicplayer)
It's almost midnight here so I'll have a look at adding it tomorrow for you.
Do you mean close it before the 15 mins is up?
Andy
BTW
the sonos also works as a musicplayer and give you more options if you select it as that
(Like volume settings for the TTS and individual volumes for multiple speakers)
Yeah, If I close the garage, I'd like to cancel the message.
Craig
As I have given the option to have a message on open or close then closing the door would only send a second message (unless close message is blank)
It will not cancel the 1st message
If I can think of a way to code it then I'll add it to the feature list... maybe a 'cancel on close' switch option.
I'll think about that one for a while
Andy
Any chance of adding Sunset/Sunrise rather than just a hard time? I am interested in MC telling me the garage door is open at Sunset, among other uses
Thanks in advance
Rick
This is a bit vague for a feature request
You can already restrict by sunset/sunrise with offset.
Iām guessing you mean the ātime if contact openā trigger??
You want me to create a sunset/sunrise trigger but only if the contact is open??
Is this what you are looking for?
Andy
Sorry Andy for not providing more info
I would like to setup MC to tell me when the garage door is open at Sunset. When using "Time if Contact Open", I seem to be able to only select a hard time, not Sunset. I also tried Time but again, no Sunset option
Rick
Now Iāve got you!
Ok.
I have been thinking that MC is getting HUGE now..
Iām concerned that if it gets too big, then it will start slowing the hub down..
So.. I may only respond to bug fixes for while..
I may well split this into āmodulesā when I get some serious time so people can load whatever module they are using
Andy
@Cobra message central threw an error today on an contact open too long child:
app:53732018-12-12 03:49:03.049 pm errorjava.lang.NullPointerException: Cannot invoke method intValue() on null object on line 3055 (openContactSpeak)
This was the only error in log
Thanks for the report Mark,
The error log tells me where to look
Iāll have a look in the morning.
(Itās almost 1.00 am here now)
Andy
