%greeting% ,, Here is your weather for today,,, %wnow%,, With a high of around %high% degrees ,, and a low of around %low% degrees. , Temperature is currently, %temp% degrees. , Humidity is currently, %hum% % . Wind, is from the %wdir% at %wspeed% mph, with gusts up to %wgust%. , and,, %rain%
I have not created the weather summary for the weewx driver (which is the one I'm using)
I have a couple of rules for my fishtanks to alert me when the power drops and the pumps are running. I was thinking of combining them into Message Central. So, if the power came on, one thing would happen and if the power drops, another would. I get I could do with with two messages. I was just thinking optimally.
Well when i wake up, i turn off a switch named "sleep state" with a button and then after i get up, motion will be detected and i want a weather report or maybe other things. Could also use the mode change and motion but i only want a message when there is motion because i might lay in bed longer
