Ok thanks for the quick response!
Have the parts of the rest980 that were depricated been addressed? I had this up and running a while back but ran into some silly issues and I was going to do a fresh install from scratch today.
Any specific functionality you're concerned about? From my perspective everything is fully supported. If you run into trouble, feel free to post here or log a ticket in GitHub
Is there a way to trigger specific rooms to clean with this app?
I have this integrated and working for 2 different roombas (i7 and i8 on different floors of the house)
I have all the scheduling configured in the irobot app and it works great. My goal is to use this integration to control adhoc cleanings., or stop/dock the robot during a cleaning cycle without having to pull out the phone.
I currently use sharptools and webcore. This makes it easy to trigger specific rooms or controls through a dashboard mounted on the wall, then have webcore trigger the right command to clean a specific room.
If I look at the device in Hubitat it has a "clean room" option, but it looks like it's a Json input not text. I'm not sure how to use it. I tried checking the "cleaning map" in the app but it's blank.
Is there a way to trigger a specific room?
The JSON follows the same format used directly in the dorita980 nodejs app: GitHub - koalazak/dorita980: Unofficial iRobot Roomba and Braava (i7/i7+, 980, 960, 900, e5, 690,
As mentioned, there is some work required to start a job from the app, query the state, and identify the required args for each map/room -- pmap_id, user_pmapv_id, and regions (an array of one or more region_id)
App update (version 1.5.0) tonight adds a preferences toggle (defaults to True) to enable/disable scheduling entirely. If you simply want to manually control your iRobot device from Hubitat, and control any scheduling via Rule Machine or other mechanisms, you can toggle this Off and then click Done to save the app preferences.
**Disclaimer: I haven't tested whether other functions (such as dock on presence) continue to work with the schedule disabled -- but the changes are minimal so I don't expect an impact. As always, if you notice something not working as expected after this update, please post logs here and/or open an issue in GitHub
The last two weeks all my scheduled cleanings stopped working. The logs show the start command is triggered but no cleaning happens. If I manually click the on command on the robot device it works perfectly though. Weβre there any recent changes?
Nope, that's odd - until last night, the last change was July 17.
There was a firmware update from iRobot in early September... I haven't been running mine the last few weeks (so no data to compare on my end). Not sure why that would impact scheduling but not manual runs, though.
If you post some logs (debug would be best) from a "non-startee" scheduled run, I can take a look at what might be happening.
Will do. Yeah the firmware was my first suspect, especially since I've read people saying the new j7 won't work with dorita (very disappointing ) but if I go to the device page, all the commands work so it seems like it can communicate.
Here are the logs:
I found the problem I just don't know how this happened. The statrt command is commented out! It's not like that on your repo though... hmm.
case "on":
if(roombaOn=="cleanRoom") {
log.info("triggering 'cleanRoom' from 'on'")
//device.cleanRoom()
} else {
log.info("triggering 'start' from 'on'")
//device.start()
break
Edit: Actually it was a bug in your code, https://github.com/dkilgore90/iRobot/commit/84106c60fde9dda2dfcc5f341ef167a0872ae56e#diff-57d86db9aea085ead55ed258017a66f4b1d1ceadc4b500a2195345c34f028e99 guess I only updated to that version a few weeks ago.
Sorry about that! Yeah, I accidentally committed that temporary comment-out and pushed it - thought I had rolled it back, though... Since I added the preferences toggle, that shouldn't happen again!
You did roll it back. I must have updated at the wrong moment
I'm having a tough time -- wondering if any linux/rpi experts could weigh in.
I just installed this amazing app on a brand new pi4. On the surface, everything appears to be working: when I pull up [my-pi-IP-address]:3000 in Chrome, I get the expected result. Same for the map. When I go into the Roomba device in HE, I seem to be able to start, stop, and doc my robot (it's a braava, fwiw) without a problem. At first, I thought it was smooth sailing.
Then I noticed some stuff not working: the Roomba tile doesn't show up in the dashboard or in the device details page. Next to RoombaTile under Current States, it's just a blank space with "Charging Battery: 100%". When I go to the HE log, everything looks normal, EXCEPT for "Rest980 Server Not Available: org.apache,http.conn.ConnectTimeoutException..." repeatedly. Sure enough, when I use the suggestion above to make sure all is okay with Rest980, I get no response from a browser.
Then I thought back to the installation process, I remember being surprised that the terminal window gave me ZERO feedback to the commands to enable and then start roomba.service. Is that normal?
The only other odd behavior was when issuing the "sudo cp -R * /usr/local/", I got an error message, "cp: cannot create regular file '/usr/local/bin/node': Text file busy".
Any advice? I don't really understand how rest980 could be hosed and yet my HE device mostly works?
Hmm, definitely some odd behavior.
On the RPi, you can check the output of sudo systemctl status roomba.service
, and the contents of /var/log/syslog
for any errors related to rest980.
Not sure about the recursive copy you ran - sudo cp -R
... which instructions did that come from?
Here's what I see. Not sure what it tells me specifically, other than I clearly have problems -- any ideas?
roomba.service - Roomba Service
Loaded: loaded (/etc/systemd/system/roomba.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2021-10-01 22:51:23 CDT; 7s ago
Process: 5030 ExecStart=/usr/local/bin/npm start (code=exited, status=200/CHDIR)
Main PID: 5030 (code=exited, status=200/CHDIR)
Oct 01 22:51:23 raspberrypi systemd[1]: roomba.service: Service RestartSec=100ms expired, scheduling restart.
Oct 01 22:51:23 raspberrypi systemd[1]: roomba.service: Scheduled restart job, restart counter is at 5.
Oct 01 22:51:23 raspberrypi systemd[1]: Stopped Roomba Service.
Oct 01 22:51:23 raspberrypi systemd[1]: roomba.service: Start request repeated too quickly.
Oct 01 22:51:23 raspberrypi systemd[1]: roomba.service: Failed with result 'exit-code'.
Oct 01 22:51:23 raspberrypi systemd[1]: Failed to start Roomba Service.
Here's the log. Don't see anything obvious but I'm no pi expert
Oct 1 00:00:27 raspberrypi rsyslogd: [origin software="rsyslogd" swVersion="8.1901.0" x-pid="410" x-info="https://www.rsyslog.com"] rsyslogd was HUPed
Oct 1 00:00:27 raspberrypi systemd[1]: logrotate.service: Succeeded.
Oct 1 00:00:27 raspberrypi systemd[1]: Started Rotate log files.
Oct 1 00:00:28 raspberrypi systemd[1]: man-db.service: Succeeded.
Oct 1 00:00:28 raspberrypi systemd[1]: Started Daily man-db regeneration.
Oct 1 00:17:02 raspberrypi CRON[1225]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 00:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 80064
Oct 1 00:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 33824
Oct 1 00:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 33824
Oct 1 00:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 4
Oct 1 00:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 00:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 00:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 00:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 00:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 00:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 00:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=312.204; max=550.517)Kibits/s
Oct 1 00:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=9.894; max=14.638)Mibits/s
Oct 1 00:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 00:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 00:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 00:26:25 raspberrypi kernel: [ 3735.461305] ieee80211 phy0: brcmf_run_escan: error (-52)
Oct 1 00:26:25 raspberrypi kernel: [ 3735.461328] ieee80211 phy0: brcmf_cfg80211_scan: scan error (-52)
Oct 1 01:17:01 raspberrypi CRON[1307]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 01:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 120064
Oct 1 01:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 63584
Oct 1 01:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 63584
Oct 1 01:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 6
Oct 1 01:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 01:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 01:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 01:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 01:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 01:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 01:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=364.940; max=551.279)Kibits/s
Oct 1 01:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=10.642; max=14.638)Mibits/s
Oct 1 01:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 01:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 01:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 02:17:01 raspberrypi CRON[1395]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 02:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 140064
Oct 1 02:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 93824
Oct 1 02:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 93824
Oct 1 02:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 7
Oct 1 02:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 02:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 02:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 02:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 02:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 02:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 02:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=383.418; max=551.279)Kibits/s
Oct 1 02:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=10.880; max=14.638)Mibits/s
Oct 1 02:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 02:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 02:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 03:17:01 raspberrypi CRON[1479]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 03:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 180064
Oct 1 03:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 123584
Oct 1 03:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 123584
Oct 1 03:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 9
Oct 1 03:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 03:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 03:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 03:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 03:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 03:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 03:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=411.194; max=551.279)Kibits/s
Oct 1 03:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=11.211; max=14.638)Mibits/s
Oct 1 03:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 03:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 03:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 04:17:01 raspberrypi CRON[1565]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 04:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 200064
Oct 1 04:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 153824
Oct 1 04:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 153824
Oct 1 04:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 10
Oct 1 04:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 04:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 04:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 04:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 04:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 04:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 04:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=421.882; max=551.279)Kibits/s
Oct 1 04:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=11.330; max=14.638)Mibits/s
Oct 1 04:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 04:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 04:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 05:12:25 raspberrypi kernel: [20895.931720] ieee80211 phy0: brcmf_run_escan: error (-52)
Oct 1 05:12:25 raspberrypi kernel: [20895.931744] ieee80211 phy0: brcmf_cfg80211_scan: scan error (-52)
Oct 1 05:17:01 raspberrypi CRON[1652]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 05:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 240064
Oct 1 05:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 183584
Oct 1 05:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 183584
Oct 1 05:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 12
Oct 1 05:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 05:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 05:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 05:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 05:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 05:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 05:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=438.988; max=551.279)Kibits/s
Oct 1 05:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=11.514; max=14.638)Mibits/s
Oct 1 05:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 05:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 05:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 06:17:01 raspberrypi CRON[1736]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 06:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 260064
Oct 1 06:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 213824
Oct 1 06:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 213824
Oct 1 06:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 13
Oct 1 06:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 06:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 06:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 06:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 06:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 06:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 06:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=445.961; max=551.279)Kibits/s
Oct 1 06:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=11.569; max=14.638)Mibits/s
Oct 1 06:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 06:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 06:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 06:25:01 raspberrypi CRON[1755]: (root) CMD (test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily ))
Oct 1 06:52:01 raspberrypi CRON[1839]: (root) CMD (test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly ))
Oct 1 06:57:17 raspberrypi systemd[1]: Starting Daily apt upgrade and clean activities...
Oct 1 06:57:19 raspberrypi systemd[1]: apt-daily-upgrade.service: Succeeded.
Oct 1 06:57:19 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Oct 1 07:17:01 raspberrypi CRON[1925]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 07:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 300064
Oct 1 07:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 243584
Oct 1 07:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 243584
Oct 1 07:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 15
Oct 1 07:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 07:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 07:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 07:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 07:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 07:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 07:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=457.568; max=551.279)Kibits/s
Oct 1 07:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=11.691; max=14.638)Mibits/s
Oct 1 07:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 07:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 07:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 08:17:01 raspberrypi CRON[2009]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 08:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 320064
Oct 1 08:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 273824
Oct 1 08:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 273824
Oct 1 08:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 16
Oct 1 08:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 08:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 08:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 08:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 08:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 08:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 08:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=462.454; max=551.279)Kibits/s
Oct 1 08:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=11.738; max=14.638)Mibits/s
Oct 1 08:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 08:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 08:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 09:09:16 raspberrypi dhcpcd[467]: wlan0: carrier lost
Oct 1 09:09:16 raspberrypi dhcpcd[467]: wlan0: deleting address fe80::a13a:9a29:4610:62e8
Oct 1 09:09:16 raspberrypi avahi-daemon[377]: Withdrawing address record for fe80::a13a:9a29:4610:62e8 on wlan0.
Oct 1 09:09:16 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 09:09:16 raspberrypi avahi-daemon[377]: Interface wlan0.IPv6 no longer relevant for mDNS.
Oct 1 09:09:16 raspberrypi avahi-daemon[377]: Withdrawing address record for 10.0.0.73 on wlan0.
Oct 1 09:09:16 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 10.0.0.73.
Oct 1 09:09:16 raspberrypi avahi-daemon[377]: Interface wlan0.IPv4 no longer relevant for mDNS.
Oct 1 09:09:16 raspberrypi dhcpcd[467]: wlan0: deleting route to 10.0.0.0/24
Oct 1 09:09:16 raspberrypi dhcpcd[467]: wlan0: deleting default route via 10.0.0.1
Oct 1 09:09:16 raspberrypi dhcpcd[467]: wlan0: carrier acquired
Oct 1 09:09:16 raspberrypi dhcpcd[467]: wlan0: IAID 01:2f:95:69
Oct 1 09:09:16 raspberrypi dhcpcd[467]: wlan0: adding address fe80::a13a:9a29:4610:62e8
Oct 1 09:09:16 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 09:09:16 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv6 for mDNS.
Oct 1 09:09:16 raspberrypi avahi-daemon[377]: Registering new address record for fe80::a13a:9a29:4610:62e8 on wlan0..
Oct 1 09:09:16 raspberrypi dhcpcd[467]: wlan0: rebinding lease of 10.0.0.73
Oct 1 09:09:17 raspberrypi dhcpcd[467]: wlan0: soliciting an IPv6 router
Oct 1 09:09:21 raspberrypi dhcpcd[467]: wlan0: probing for an IPv4LL address
Oct 1 09:09:21 raspberrypi dhcpcd[467]: wlan0: DHCP lease expired
Oct 1 09:09:21 raspberrypi dhcpcd[467]: wlan0: soliciting a DHCP lease
Oct 1 09:09:26 raspberrypi dhcpcd[467]: wlan0: using IPv4LL address 169.254.70.61
Oct 1 09:09:26 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv4 with address 169.254.70.61.
Oct 1 09:09:26 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv4 for mDNS.
Oct 1 09:09:26 raspberrypi dhcpcd[467]: wlan0: adding route to 169.254.0.0/16
Oct 1 09:09:26 raspberrypi avahi-daemon[377]: Registering new address record for 169.254.70.61 on wlan0.IPv4.
Oct 1 09:09:26 raspberrypi dhcpcd[467]: wlan0: adding default route
Oct 1 09:09:30 raspberrypi dhcpcd[467]: wlan0: no IPv6 Routers available
Oct 1 09:11:15 raspberrypi dhcpcd[467]: wlan0: carrier lost
Oct 1 09:11:15 raspberrypi dhcpcd[467]: wlan0: deleting address fe80::a13a:9a29:4610:62e8
Oct 1 09:11:15 raspberrypi avahi-daemon[377]: Withdrawing address record for fe80::a13a:9a29:4610:62e8 on wlan0.
Oct 1 09:11:15 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 09:11:15 raspberrypi avahi-daemon[377]: Interface wlan0.IPv6 no longer relevant for mDNS.
Oct 1 09:11:15 raspberrypi avahi-daemon[377]: Withdrawing address record for 169.254.70.61 on wlan0.
Oct 1 09:11:15 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 169.254.70.61.
Oct 1 09:11:15 raspberrypi avahi-daemon[377]: Interface wlan0.IPv4 no longer relevant for mDNS.
Oct 1 09:11:15 raspberrypi dhcpcd[467]: wlan0: deleting route to 169.254.0.0/16
Oct 1 09:11:15 raspberrypi dhcpcd[467]: wlan0: deleting default route
Oct 1 09:11:18 raspberrypi dhcpcd[467]: wlan0: carrier acquired
Oct 1 09:11:18 raspberrypi dhcpcd[467]: wlan0: IAID 01:2f:95:69
Oct 1 09:11:18 raspberrypi dhcpcd[467]: wlan0: adding address fe80::a13a:9a29:4610:62e8
Oct 1 09:11:18 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 09:11:18 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv6 for mDNS.
Oct 1 09:11:18 raspberrypi avahi-daemon[377]: Registering new address record for fe80::a13a:9a29:4610:62e8 on wlan0..
Oct 1 09:11:18 raspberrypi dhcpcd[467]: wlan0: soliciting an IPv6 router
Oct 1 09:11:19 raspberrypi dhcpcd[467]: wlan0: soliciting a DHCP lease
Oct 1 09:11:19 raspberrypi dhcpcd[467]: wlan0: offered 10.0.0.73 from 10.0.0.1
Oct 1 09:11:19 raspberrypi dhcpcd[467]: wlan0: probing address 10.0.0.73/24
Oct 1 09:11:25 raspberrypi dhcpcd[467]: wlan0: leased 10.0.0.73 for 86400 seconds
Oct 1 09:11:25 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.0.0.73.
Oct 1 09:11:25 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv4 for mDNS.
Oct 1 09:11:25 raspberrypi dhcpcd[467]: wlan0: adding route to 10.0.0.0/24
Oct 1 09:11:25 raspberrypi dhcpcd[467]: wlan0: adding default route via 10.0.0.1
Oct 1 09:11:25 raspberrypi avahi-daemon[377]: Registering new address record for 10.0.0.73 on wlan0.IPv4.
Oct 1 09:11:32 raspberrypi dhcpcd[467]: wlan0: no IPv6 Routers available
Oct 1 09:12:16 raspberrypi dhcpcd[467]: wlan0: carrier lost
Oct 1 09:12:16 raspberrypi dhcpcd[467]: wlan0: deleting address fe80::a13a:9a29:4610:62e8
Oct 1 09:12:16 raspberrypi avahi-daemon[377]: Withdrawing address record for fe80::a13a:9a29:4610:62e8 on wlan0.
Oct 1 09:12:16 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 09:12:16 raspberrypi avahi-daemon[377]: Interface wlan0.IPv6 no longer relevant for mDNS.
Oct 1 09:12:16 raspberrypi avahi-daemon[377]: Withdrawing address record for 10.0.0.73 on wlan0.
Oct 1 09:12:16 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 10.0.0.73.
Oct 1 09:12:16 raspberrypi avahi-daemon[377]: Interface wlan0.IPv4 no longer relevant for mDNS.
Oct 1 09:12:16 raspberrypi dhcpcd[467]: wlan0: deleting route to 10.0.0.0/24
Oct 1 09:12:16 raspberrypi dhcpcd[467]: wlan0: deleting default route via 10.0.0.1
Oct 1 09:12:16 raspberrypi dhcpcd[467]: wlan0: carrier acquired
Oct 1 09:12:16 raspberrypi dhcpcd[467]: wlan0: IAID 01:2f:95:69
Oct 1 09:12:16 raspberrypi dhcpcd[467]: wlan0: adding address fe80::a13a:9a29:4610:62e8
Oct 1 09:12:16 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 09:12:16 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv6 for mDNS.
Oct 1 09:12:16 raspberrypi avahi-daemon[377]: Registering new address record for fe80::a13a:9a29:4610:62e8 on wlan0..
Oct 1 09:12:17 raspberrypi dhcpcd[467]: wlan0: soliciting an IPv6 router
Oct 1 09:12:17 raspberrypi dhcpcd[467]: wlan0: rebinding lease of 10.0.0.73
Oct 1 09:12:22 raspberrypi dhcpcd[467]: wlan0: probing for an IPv4LL address
Oct 1 09:12:22 raspberrypi dhcpcd[467]: wlan0: DHCP lease expired
Oct 1 09:12:22 raspberrypi dhcpcd[467]: wlan0: soliciting a DHCP lease
Oct 1 09:12:27 raspberrypi dhcpcd[467]: wlan0: using IPv4LL address 169.254.70.61
Oct 1 09:12:27 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv4 with address 169.254.70.61.
Oct 1 09:12:27 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv4 for mDNS.
Oct 1 09:12:27 raspberrypi dhcpcd[467]: wlan0: adding route to 169.254.0.0/16
Oct 1 09:12:27 raspberrypi avahi-daemon[377]: Registering new address record for 169.254.70.61 on wlan0.IPv4.
Oct 1 09:12:27 raspberrypi dhcpcd[467]: wlan0: adding default route
Oct 1 09:12:30 raspberrypi dhcpcd[467]: wlan0: no IPv6 Routers available
Oct 1 09:12:37 raspberrypi colord[1121]: failed to get session [pid 1192]: No data available
Oct 1 09:17:01 raspberrypi CRON[2302]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 09:17:16 raspberrypi dhcpcd[467]: wlan0: carrier lost
Oct 1 09:17:16 raspberrypi dhcpcd[467]: wlan0: deleting address fe80::a13a:9a29:4610:62e8
Oct 1 09:17:16 raspberrypi avahi-daemon[377]: Withdrawing address record for fe80::a13a:9a29:4610:62e8 on wlan0.
Oct 1 09:17:16 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 09:17:16 raspberrypi avahi-daemon[377]: Interface wlan0.IPv6 no longer relevant for mDNS.
Oct 1 09:17:16 raspberrypi avahi-daemon[377]: Withdrawing address record for 169.254.70.61 on wlan0.
Oct 1 09:17:16 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 169.254.70.61.
Oct 1 09:17:16 raspberrypi avahi-daemon[377]: Interface wlan0.IPv4 no longer relevant for mDNS.
Oct 1 09:17:16 raspberrypi dhcpcd[467]: wlan0: deleting route to 169.254.0.0/16
Oct 1 09:17:16 raspberrypi dhcpcd[467]: wlan0: deleting default route
Oct 1 09:17:19 raspberrypi dhcpcd[467]: wlan0: carrier acquired
Oct 1 09:17:19 raspberrypi dhcpcd[467]: wlan0: IAID 01:2f:95:69
Oct 1 09:17:19 raspberrypi dhcpcd[467]: wlan0: adding address fe80::a13a:9a29:4610:62e8
Oct 1 09:17:19 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 09:17:19 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv6 for mDNS.
Oct 1 09:17:19 raspberrypi avahi-daemon[377]: Registering new address record for fe80::a13a:9a29:4610:62e8 on wlan0..
Oct 1 09:17:20 raspberrypi dhcpcd[467]: wlan0: soliciting an IPv6 router
Oct 1 09:17:20 raspberrypi dhcpcd[467]: wlan0: soliciting a DHCP lease
Oct 1 09:17:21 raspberrypi dhcpcd[467]: wlan0: offered 10.0.0.73 from 10.0.0.1
Oct 1 09:17:21 raspberrypi dhcpcd[467]: wlan0: probing address 10.0.0.73/24
Oct 1 09:17:25 raspberrypi dhcpcd[467]: wlan0: leased 10.0.0.73 for 86400 seconds
Oct 1 09:17:25 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.0.0.73.
Oct 1 09:17:25 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv4 for mDNS.
Oct 1 09:17:25 raspberrypi avahi-daemon[377]: Registering new address record for 10.0.0.73 on wlan0.IPv4.
Oct 1 09:17:25 raspberrypi dhcpcd[467]: wlan0: adding route to 10.0.0.0/24
Oct 1 09:17:25 raspberrypi dhcpcd[467]: wlan0: adding default route via 10.0.0.1
Oct 1 09:17:33 raspberrypi dhcpcd[467]: wlan0: no IPv6 Routers available
Oct 1 09:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 360064
Oct 1 09:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 303584
Oct 1 09:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 303584
Oct 1 09:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 18
Oct 1 09:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 09:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 09:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 09:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 09:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 09:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 09:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=460.949; max=551.279)Kibits/s
Oct 1 09:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=11.980; max=16.746)Mibits/s
Oct 1 09:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 09:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 09:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 09:28:10 raspberrypi dhcpcd[467]: wlan0: carrier lost
Oct 1 09:28:10 raspberrypi dhcpcd[467]: wlan0: deleting address fe80::a13a:9a29:4610:62e8
Oct 1 09:28:10 raspberrypi avahi-daemon[377]: Withdrawing address record for fe80::a13a:9a29:4610:62e8 on wlan0.
Oct 1 09:28:10 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 09:28:10 raspberrypi avahi-daemon[377]: Interface wlan0.IPv6 no longer relevant for mDNS.
Oct 1 09:28:10 raspberrypi avahi-daemon[377]: Withdrawing address record for 10.0.0.73 on wlan0.
Oct 1 09:28:10 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 10.0.0.73.
Oct 1 09:28:10 raspberrypi avahi-daemon[377]: Interface wlan0.IPv4 no longer relevant for mDNS.
Oct 1 09:28:10 raspberrypi dhcpcd[467]: wlan0: deleting route to 10.0.0.0/24
Oct 1 09:28:10 raspberrypi dhcpcd[467]: wlan0: deleting default route via 10.0.0.1
Oct 1 09:28:10 raspberrypi dhcpcd[467]: wlan0: carrier acquired
Oct 1 09:28:10 raspberrypi dhcpcd[467]: wlan0: IAID 01:2f:95:69
Oct 1 09:28:10 raspberrypi dhcpcd[467]: wlan0: adding address fe80::a13a:9a29:4610:62e8
Oct 1 09:28:10 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 09:28:10 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv6 for mDNS.
Oct 1 09:28:10 raspberrypi avahi-daemon[377]: Registering new address record for fe80::a13a:9a29:4610:62e8 on wlan0..
Oct 1 09:28:10 raspberrypi dhcpcd[467]: wlan0: rebinding lease of 10.0.0.73
Oct 1 09:28:10 raspberrypi dhcpcd[467]: wlan0: soliciting an IPv6 router
Oct 1 09:28:15 raspberrypi dhcpcd[467]: wlan0: probing for an IPv4LL address
Oct 1 09:28:15 raspberrypi dhcpcd[467]: wlan0: DHCP lease expired
Oct 1 09:28:15 raspberrypi dhcpcd[467]: wlan0: soliciting a DHCP lease
Oct 1 09:28:20 raspberrypi dhcpcd[467]: wlan0: using IPv4LL address 169.254.70.61
Oct 1 09:28:20 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv4 with address 169.254.70.61.
Oct 1 09:28:20 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv4 for mDNS.
Oct 1 09:28:20 raspberrypi avahi-daemon[377]: Registering new address record for 169.254.70.61 on wlan0.IPv4.
Oct 1 09:28:20 raspberrypi dhcpcd[467]: wlan0: adding route to 169.254.0.0/16
Oct 1 09:28:20 raspberrypi dhcpcd[467]: wlan0: adding default route
Oct 1 09:28:23 raspberrypi dhcpcd[467]: wlan0: no IPv6 Routers available
Oct 1 09:28:29 raspberrypi dhcpcd[467]: wlan0: offered 10.0.0.73 from 10.0.0.1
Oct 1 09:28:29 raspberrypi dhcpcd[467]: wlan0: probing address 10.0.0.73/24
Oct 1 09:28:34 raspberrypi dhcpcd[467]: wlan0: leased 10.0.0.73 for 86400 seconds
Oct 1 09:28:34 raspberrypi avahi-daemon[377]: Registering new address record for 10.0.0.73 on wlan0.IPv4.
Oct 1 09:28:34 raspberrypi dhcpcd[467]: wlan0: adding route to 10.0.0.0/24
Oct 1 09:28:34 raspberrypi dhcpcd[467]: wlan0: changing default route via 10.0.0.1
Oct 1 09:28:35 raspberrypi avahi-daemon[377]: Withdrawing address record for 169.254.70.61 on wlan0.
Oct 1 09:28:35 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 169.254.70.61.
Oct 1 09:28:35 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.0.0.73.
Oct 1 09:28:35 raspberrypi dhcpcd[467]: wlan0: deleting route to 169.254.0.0/16
Oct 1 09:28:35 raspberrypi dhcpcd[467]: wlan0: pid 467 deleted default route via 10.0.0.1
Oct 1 09:30:00 raspberrypi dhcpcd[467]: wlan0: carrier lost
Oct 1 09:30:00 raspberrypi dhcpcd[467]: wlan0: deleting address fe80::a13a:9a29:4610:62e8
Oct 1 09:30:00 raspberrypi avahi-daemon[377]: Withdrawing address record for fe80::a13a:9a29:4610:62e8 on wlan0.
Oct 1 09:30:00 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 09:30:00 raspberrypi avahi-daemon[377]: Interface wlan0.IPv6 no longer relevant for mDNS.
Oct 1 09:30:00 raspberrypi avahi-daemon[377]: Withdrawing address record for 10.0.0.73 on wlan0.
Oct 1 09:30:00 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 10.0.0.73.
Oct 1 09:30:00 raspberrypi avahi-daemon[377]: Interface wlan0.IPv4 no longer relevant for mDNS.
Oct 1 09:30:00 raspberrypi dhcpcd[467]: wlan0: deleting route to 10.0.0.0/24
Oct 1 09:30:01 raspberrypi dhcpcd[467]: wlan0: carrier acquired
Oct 1 09:30:01 raspberrypi dhcpcd[467]: wlan0: IAID 01:2f:95:69
Oct 1 09:30:01 raspberrypi dhcpcd[467]: wlan0: adding address fe80::a13a:9a29:4610:62e8
Oct 1 09:30:01 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 09:30:01 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv6 for mDNS.
Oct 1 09:30:01 raspberrypi avahi-daemon[377]: Registering new address record for fe80::a13a:9a29:4610:62e8 on wlan0..
Oct 1 09:30:01 raspberrypi dhcpcd[467]: wlan0: soliciting an IPv6 router
Oct 1 09:30:02 raspberrypi dhcpcd[467]: wlan0: rebinding lease of 10.0.0.73
Oct 1 09:30:02 raspberrypi dhcpcd[467]: wlan0: probing address 10.0.0.73/24
Oct 1 09:30:08 raspberrypi dhcpcd[467]: wlan0: leased 10.0.0.73 for 86400 seconds
Oct 1 09:30:08 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.0.0.73.
Oct 1 09:30:08 raspberrypi dhcpcd[467]: wlan0: adding route to 10.0.0.0/24
Oct 1 09:30:08 raspberrypi dhcpcd[467]: wlan0: adding default route via 10.0.0.1
Oct 1 09:30:08 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv4 for mDNS.
Oct 1 09:30:08 raspberrypi avahi-daemon[377]: Registering new address record for 10.0.0.73 on wlan0.IPv4.
Oct 1 09:30:14 raspberrypi dhcpcd[467]: wlan0: no IPv6 Routers available
Oct 1 10:17:01 raspberrypi CRON[2683]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 10:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 380064
Oct 1 10:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 333824
Oct 1 10:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 333824
Oct 1 10:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 19
Oct 1 10:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 10:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 10:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 10:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 10:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 10:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 10:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=464.965; max=551.434)Kibits/s
Oct 1 10:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=12.008; max=16.746)Mibits/s
Oct 1 10:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 10:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 10:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 11:13:38 raspberrypi dhcpcd[467]: wlan0: carrier lost
Oct 1 11:13:39 raspberrypi dhcpcd[467]: wlan0: deleting address fe80::a13a:9a29:4610:62e8
Oct 1 11:13:39 raspberrypi avahi-daemon[377]: Withdrawing address record for fe80::a13a:9a29:4610:62e8 on wlan0.
Oct 1 11:13:39 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 11:13:39 raspberrypi avahi-daemon[377]: Interface wlan0.IPv6 no longer relevant for mDNS.
Oct 1 11:13:39 raspberrypi avahi-daemon[377]: Withdrawing address record for 10.0.0.73 on wlan0.
Oct 1 11:13:39 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 10.0.0.73.
Oct 1 11:13:39 raspberrypi avahi-daemon[377]: Interface wlan0.IPv4 no longer relevant for mDNS.
Oct 1 11:13:39 raspberrypi dhcpcd[467]: wlan0: deleting route to 10.0.0.0/24
Oct 1 11:13:39 raspberrypi dhcpcd[467]: wlan0: deleting default route via 10.0.0.1
Oct 1 11:13:39 raspberrypi dhcpcd[467]: wlan0: carrier acquired
Oct 1 11:13:39 raspberrypi dhcpcd[467]: wlan0: IAID 01:2f:95:69
Oct 1 11:13:39 raspberrypi dhcpcd[467]: wlan0: adding address fe80::a13a:9a29:4610:62e8
Oct 1 11:13:39 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 11:13:39 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv6 for mDNS.
Oct 1 11:13:39 raspberrypi avahi-daemon[377]: Registering new address record for fe80::a13a:9a29:4610:62e8 on wlan0..
Oct 1 11:13:39 raspberrypi dhcpcd[467]: wlan0: rebinding lease of 10.0.0.73
Oct 1 11:13:39 raspberrypi dhcpcd[467]: wlan0: soliciting an IPv6 router
Oct 1 11:13:44 raspberrypi dhcpcd[467]: wlan0: probing for an IPv4LL address
Oct 1 11:13:44 raspberrypi dhcpcd[467]: wlan0: DHCP lease expired
Oct 1 11:13:44 raspberrypi dhcpcd[467]: wlan0: soliciting a DHCP lease
Oct 1 11:13:49 raspberrypi dhcpcd[467]: wlan0: using IPv4LL address 169.254.70.61
Oct 1 11:13:49 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv4 with address 169.254.70.61.
Oct 1 11:13:49 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv4 for mDNS.
Oct 1 11:13:49 raspberrypi dhcpcd[467]: wlan0: adding route to 169.254.0.0/16
Oct 1 11:13:49 raspberrypi avahi-daemon[377]: Registering new address record for 169.254.70.61 on wlan0.IPv4.
Oct 1 11:13:49 raspberrypi dhcpcd[467]: wlan0: adding default route
Oct 1 11:13:52 raspberrypi dhcpcd[467]: wlan0: no IPv6 Routers available
Oct 1 11:14:05 raspberrypi dhcpcd[467]: wlan0: carrier lost
Oct 1 11:14:05 raspberrypi dhcpcd[467]: wlan0: deleting address fe80::a13a:9a29:4610:62e8
Oct 1 11:14:05 raspberrypi avahi-daemon[377]: Withdrawing address record for fe80::a13a:9a29:4610:62e8 on wlan0.
Oct 1 11:14:05 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 11:14:05 raspberrypi avahi-daemon[377]: Interface wlan0.IPv6 no longer relevant for mDNS.
Oct 1 11:14:05 raspberrypi avahi-daemon[377]: Withdrawing address record for 169.254.70.61 on wlan0.
Oct 1 11:14:05 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 169.254.70.61.
Oct 1 11:14:05 raspberrypi avahi-daemon[377]: Interface wlan0.IPv4 no longer relevant for mDNS.
Oct 1 11:14:05 raspberrypi dhcpcd[467]: wlan0: deleting route to 169.254.0.0/16
Oct 1 11:14:05 raspberrypi dhcpcd[467]: wlan0: deleting default route
Oct 1 11:14:08 raspberrypi dhcpcd[467]: wlan0: carrier acquired
Oct 1 11:14:08 raspberrypi dhcpcd[467]: wlan0: IAID 01:2f:95:69
Oct 1 11:14:08 raspberrypi dhcpcd[467]: wlan0: adding address fe80::a13a:9a29:4610:62e8
Oct 1 11:14:08 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 11:14:08 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv6 for mDNS.
Oct 1 11:14:08 raspberrypi avahi-daemon[377]: Registering new address record for fe80::a13a:9a29:4610:62e8 on wlan0..
Oct 1 11:14:08 raspberrypi dhcpcd[467]: wlan0: soliciting a DHCP lease
Oct 1 11:14:08 raspberrypi dhcpcd[467]: wlan0: soliciting an IPv6 router
Oct 1 11:14:09 raspberrypi dhcpcd[467]: wlan0: offered 10.0.0.73 from 10.0.0.1
Oct 1 11:14:09 raspberrypi dhcpcd[467]: wlan0: probing address 10.0.0.73/24
Oct 1 11:14:14 raspberrypi dhcpcd[467]: wlan0: leased 10.0.0.73 for 86400 seconds
Oct 1 11:14:14 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.0.0.73.
Oct 1 11:14:14 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv4 for mDNS.
Oct 1 11:14:14 raspberrypi dhcpcd[467]: wlan0: adding route to 10.0.0.0/24
Oct 1 11:14:14 raspberrypi avahi-daemon[377]: Registering new address record for 10.0.0.73 on wlan0.IPv4.
Oct 1 11:14:14 raspberrypi dhcpcd[467]: wlan0: adding default route via 10.0.0.1
Oct 1 11:14:21 raspberrypi dhcpcd[467]: wlan0: no IPv6 Routers available
Oct 1 11:17:01 raspberrypi CRON[2907]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 11:21:44 raspberrypi dhcpcd[467]: wlan0: carrier lost
Oct 1 11:21:44 raspberrypi dhcpcd[467]: wlan0: deleting address fe80::a13a:9a29:4610:62e8
Oct 1 11:21:44 raspberrypi avahi-daemon[377]: Withdrawing address record for fe80::a13a:9a29:4610:62e8 on wlan0.
Oct 1 11:21:44 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 11:21:44 raspberrypi avahi-daemon[377]: Interface wlan0.IPv6 no longer relevant for mDNS.
Oct 1 11:21:44 raspberrypi avahi-daemon[377]: Withdrawing address record for 10.0.0.73 on wlan0.
Oct 1 11:21:44 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 10.0.0.73.
Oct 1 11:21:44 raspberrypi avahi-daemon[377]: Interface wlan0.IPv4 no longer relevant for mDNS.
Oct 1 11:21:44 raspberrypi dhcpcd[467]: wlan0: deleting route to 10.0.0.0/24
Oct 1 11:21:44 raspberrypi dhcpcd[467]: wlan0: deleting default route via 10.0.0.1
Oct 1 11:21:44 raspberrypi dhcpcd[467]: wlan0: carrier acquired
Oct 1 11:21:44 raspberrypi dhcpcd[467]: wlan0: IAID 01:2f:95:69
Oct 1 11:21:44 raspberrypi dhcpcd[467]: wlan0: adding address fe80::a13a:9a29:4610:62e8
Oct 1 11:21:44 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 11:21:44 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv6 for mDNS.
Oct 1 11:21:44 raspberrypi avahi-daemon[377]: Registering new address record for fe80::a13a:9a29:4610:62e8 on wlan0..
Oct 1 11:21:44 raspberrypi dhcpcd[467]: wlan0: rebinding lease of 10.0.0.73
Oct 1 11:21:45 raspberrypi dhcpcd[467]: wlan0: soliciting an IPv6 router
Oct 1 11:21:49 raspberrypi dhcpcd[467]: wlan0: probing for an IPv4LL address
Oct 1 11:21:49 raspberrypi dhcpcd[467]: wlan0: DHCP lease expired
Oct 1 11:21:49 raspberrypi dhcpcd[467]: wlan0: soliciting a DHCP lease
Oct 1 11:21:55 raspberrypi dhcpcd[467]: wlan0: using IPv4LL address 169.254.70.61
Oct 1 11:21:55 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv4 with address 169.254.70.61.
Oct 1 11:21:55 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv4 for mDNS.
Oct 1 11:21:55 raspberrypi avahi-daemon[377]: Registering new address record for 169.254.70.61 on wlan0.IPv4.
Oct 1 11:21:55 raspberrypi dhcpcd[467]: wlan0: adding route to 169.254.0.0/16
Oct 1 11:21:55 raspberrypi dhcpcd[467]: wlan0: adding default route
Oct 1 11:21:58 raspberrypi dhcpcd[467]: wlan0: no IPv6 Routers available
Oct 1 11:21:58 raspberrypi dhcpcd[467]: wlan0: carrier lost
Oct 1 11:21:58 raspberrypi dhcpcd[467]: wlan0: deleting address fe80::a13a:9a29:4610:62e8
Oct 1 11:21:58 raspberrypi avahi-daemon[377]: Withdrawing address record for fe80::a13a:9a29:4610:62e8 on wlan0.
Oct 1 11:21:58 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 11:21:58 raspberrypi avahi-daemon[377]: Interface wlan0.IPv6 no longer relevant for mDNS.
Oct 1 11:21:58 raspberrypi avahi-daemon[377]: Withdrawing address record for 169.254.70.61 on wlan0.
Oct 1 11:21:58 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 169.254.70.61.
Oct 1 11:21:58 raspberrypi avahi-daemon[377]: Interface wlan0.IPv4 no longer relevant for mDNS.
Oct 1 11:21:58 raspberrypi dhcpcd[467]: wlan0: deleting route to 169.254.0.0/16
Oct 1 11:21:58 raspberrypi dhcpcd[467]: wlan0: deleting default route
Oct 1 11:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 420064
Oct 1 11:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 363584
Oct 1 11:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 363584
Oct 1 11:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 21
Oct 1 11:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 11:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 11:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 11:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 11:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 11:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 11:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=471.970; max=551.434)Kibits/s
Oct 1 11:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=12.197; max=16.746)Mibits/s
Oct 1 11:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 11:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 11:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 11:27:11 raspberrypi dhcpcd[467]: wlan0: carrier acquired
Oct 1 11:27:11 raspberrypi dhcpcd[467]: wlan0: IAID 01:2f:95:69
Oct 1 11:27:11 raspberrypi dhcpcd[467]: wlan0: adding address fe80::a13a:9a29:4610:62e8
Oct 1 11:27:11 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 11:27:11 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv6 for mDNS.
Oct 1 11:27:11 raspberrypi avahi-daemon[377]: Registering new address record for fe80::a13a:9a29:4610:62e8 on wlan0..
Oct 1 11:27:12 raspberrypi dhcpcd[467]: wlan0: soliciting a DHCP lease
Oct 1 11:27:12 raspberrypi dhcpcd[467]: wlan0: soliciting an IPv6 router
Oct 1 11:27:12 raspberrypi dhcpcd[467]: wlan0: offered 10.0.0.73 from 10.0.0.1
Oct 1 11:27:12 raspberrypi dhcpcd[467]: wlan0: probing address 10.0.0.73/24
Oct 1 11:27:18 raspberrypi dhcpcd[467]: wlan0: leased 10.0.0.73 for 86400 seconds
Oct 1 11:27:18 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.0.0.73.
Oct 1 11:27:18 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv4 for mDNS.
Oct 1 11:27:18 raspberrypi dhcpcd[467]: wlan0: adding route to 10.0.0.0/24
Oct 1 11:27:18 raspberrypi avahi-daemon[377]: Registering new address record for 10.0.0.73 on wlan0.IPv4.
Oct 1 11:27:18 raspberrypi dhcpcd[467]: wlan0: adding default route via 10.0.0.1
Oct 1 11:27:24 raspberrypi dhcpcd[467]: wlan0: no IPv6 Routers available
Oct 1 11:31:49 raspberrypi dhcpcd[467]: wlan0: carrier lost
Oct 1 11:31:49 raspberrypi dhcpcd[467]: wlan0: deleting address fe80::a13a:9a29:4610:62e8
Oct 1 11:31:49 raspberrypi avahi-daemon[377]: Withdrawing address record for fe80::a13a:9a29:4610:62e8 on wlan0.
Oct 1 11:31:49 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 11:31:49 raspberrypi avahi-daemon[377]: Interface wlan0.IPv6 no longer relevant for mDNS.
Oct 1 11:31:49 raspberrypi avahi-daemon[377]: Withdrawing address record for 10.0.0.73 on wlan0.
Oct 1 11:31:49 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 10.0.0.73.
Oct 1 11:31:49 raspberrypi avahi-daemon[377]: Interface wlan0.IPv4 no longer relevant for mDNS.
Oct 1 11:31:49 raspberrypi dhcpcd[467]: wlan0: deleting route to 10.0.0.0/24
Oct 1 11:31:49 raspberrypi dhcpcd[467]: wlan0: deleting default route via 10.0.0.1
Oct 1 11:31:49 raspberrypi dhcpcd[467]: wlan0: carrier acquired
Oct 1 11:31:49 raspberrypi dhcpcd[467]: wlan0: IAID 01:2f:95:69
Oct 1 11:31:49 raspberrypi dhcpcd[467]: wlan0: adding address fe80::a13a:9a29:4610:62e8
Oct 1 11:31:49 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 11:31:49 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv6 for mDNS.
Oct 1 11:31:49 raspberrypi avahi-daemon[377]: Registering new address record for fe80::a13a:9a29:4610:62e8 on wlan0..
Oct 1 11:31:49 raspberrypi dhcpcd[467]: wlan0: soliciting an IPv6 router
Oct 1 11:31:50 raspberrypi dhcpcd[467]: wlan0: rebinding lease of 10.0.0.73
Oct 1 11:31:55 raspberrypi dhcpcd[467]: wlan0: probing for an IPv4LL address
Oct 1 11:31:55 raspberrypi dhcpcd[467]: wlan0: DHCP lease expired
Oct 1 11:31:55 raspberrypi dhcpcd[467]: wlan0: soliciting a DHCP lease
Oct 1 11:32:00 raspberrypi dhcpcd[467]: wlan0: using IPv4LL address 169.254.70.61
Oct 1 11:32:00 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv4 with address 169.254.70.61.
Oct 1 11:32:00 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv4 for mDNS.
Oct 1 11:32:00 raspberrypi avahi-daemon[377]: Registering new address record for 169.254.70.61 on wlan0.IPv4.
Oct 1 11:32:00 raspberrypi dhcpcd[467]: wlan0: adding route to 169.254.0.0/16
Oct 1 11:32:00 raspberrypi dhcpcd[467]: wlan0: adding default route
Oct 1 11:32:02 raspberrypi dhcpcd[467]: wlan0: no IPv6 Routers available
Oct 1 11:32:05 raspberrypi dhcpcd[467]: wlan0: carrier lost
Oct 1 11:32:05 raspberrypi dhcpcd[467]: wlan0: deleting address fe80::a13a:9a29:4610:62e8
Oct 1 11:32:05 raspberrypi avahi-daemon[377]: Withdrawing address record for fe80::a13a:9a29:4610:62e8 on wlan0.
Oct 1 11:32:05 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 11:32:05 raspberrypi avahi-daemon[377]: Interface wlan0.IPv6 no longer relevant for mDNS.
Oct 1 11:32:05 raspberrypi avahi-daemon[377]: Withdrawing address record for 169.254.70.61 on wlan0.
Oct 1 11:32:05 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 169.254.70.61.
Oct 1 11:32:05 raspberrypi avahi-daemon[377]: Interface wlan0.IPv4 no longer relevant for mDNS.
Oct 1 11:32:05 raspberrypi dhcpcd[467]: wlan0: deleting route to 169.254.0.0/16
Oct 1 11:32:05 raspberrypi dhcpcd[467]: wlan0: deleting default route
Oct 1 11:32:08 raspberrypi dhcpcd[467]: wlan0: carrier acquired
Oct 1 11:32:08 raspberrypi dhcpcd[467]: wlan0: IAID 01:2f:95:69
Oct 1 11:32:08 raspberrypi dhcpcd[467]: wlan0: adding address fe80::a13a:9a29:4610:62e8
Oct 1 11:32:08 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 11:32:08 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv6 for mDNS.
Oct 1 11:32:08 raspberrypi avahi-daemon[377]: Registering new address record for fe80::a13a:9a29:4610:62e8 on wlan0..
Oct 1 11:32:09 raspberrypi dhcpcd[467]: wlan0: soliciting an IPv6 router
Oct 1 11:32:09 raspberrypi dhcpcd[467]: wlan0: soliciting a DHCP lease
Oct 1 11:32:09 raspberrypi dhcpcd[467]: wlan0: offered 10.0.0.73 from 10.0.0.1
Oct 1 11:32:09 raspberrypi dhcpcd[467]: wlan0: probing address 10.0.0.73/24
Oct 1 11:32:14 raspberrypi dhcpcd[467]: wlan0: leased 10.0.0.73 for 86400 seconds
Oct 1 11:32:14 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.0.0.73.
Oct 1 11:32:14 raspberrypi dhcpcd[467]: wlan0: adding route to 10.0.0.0/24
Oct 1 11:32:14 raspberrypi dhcpcd[467]: wlan0: adding default route via 10.0.0.1
Oct 1 11:32:14 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv4 for mDNS.
Oct 1 11:32:14 raspberrypi avahi-daemon[377]: Registering new address record for 10.0.0.73 on wlan0.IPv4.
Oct 1 11:32:22 raspberrypi dhcpcd[467]: wlan0: no IPv6 Routers available
Oct 1 12:17:01 raspberrypi CRON[3267]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 12:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 440064
Oct 1 12:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 393824
Oct 1 12:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 393824
Oct 1 12:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 22
Oct 1 12:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 12:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 12:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 12:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 12:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 12:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 12:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=475.056; max=551.434)Kibits/s
Oct 1 12:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=12.211; max=16.746)Mibits/s
Oct 1 12:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 12:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 12:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 12:46:17 raspberrypi systemd[1]: Starting Daily apt download activities...
Oct 1 12:46:18 raspberrypi systemd[1]: apt-daily.service: Succeeded.
Oct 1 12:46:18 raspberrypi systemd[1]: Started Daily apt download activities.
Oct 1 12:47:25 raspberrypi kernel: [48196.643797] ieee80211 phy0: brcmf_run_escan: error (-52)
Oct 1 12:47:25 raspberrypi kernel: [48196.643821] ieee80211 phy0: brcmf_cfg80211_scan: scan error (-52)
Oct 1 12:52:25 raspberrypi kernel: [48496.651642] ieee80211 phy0: brcmf_run_escan: error (-52)
Oct 1 12:52:25 raspberrypi kernel: [48496.651666] ieee80211 phy0: brcmf_cfg80211_scan: scan error (-52)
Oct 1 13:17:01 raspberrypi CRON[3402]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 13:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 480064
Oct 1 13:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 423584
Oct 1 13:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 423584
Oct 1 13:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 24
Oct 1 13:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 13:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 13:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 13:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 13:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 13:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 13:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=480.581; max=551.434)Kibits/s
Oct 1 13:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=12.240; max=16.746)Mibits/s
Oct 1 13:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 13:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 13:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 14:17:01 raspberrypi CRON[3492]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 14:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 500064
Oct 1 14:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 453824
Oct 1 14:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 453824
Oct 1 14:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 25
Oct 1 14:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 14:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 14:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 14:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 14:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 14:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 14:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=483.044; max=551.434)Kibits/s
Oct 1 14:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=12.242; max=16.746)Mibits/s
Oct 1 14:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 14:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 14:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 15:17:01 raspberrypi CRON[3585]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 15:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 540064
Oct 1 15:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 483584
Oct 1 15:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 483584
Oct 1 15:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 27
Oct 1 15:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 15:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 15:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 15:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 15:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 15:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 15:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=487.507; max=551.434)Kibits/s
Oct 1 15:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=12.264; max=16.746)Mibits/s
Oct 1 15:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 15:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 15:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 16:17:01 raspberrypi CRON[3671]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 16:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 560064
Oct 1 16:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 513824
Oct 1 16:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 513824
Oct 1 16:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 28
Oct 1 16:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 16:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 16:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 16:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 16:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 16:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 16:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=489.523; max=551.434)Kibits/s
Oct 1 16:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=12.268; max=16.746)Mibits/s
Oct 1 16:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 16:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 16:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 17:03:26 raspberrypi kernel: [63557.065349] ieee80211 phy0: brcmf_run_escan: error (-52)
Oct 1 17:03:26 raspberrypi kernel: [63557.065372] ieee80211 phy0: brcmf_cfg80211_scan: scan error (-52)
Oct 1 17:08:26 raspberrypi kernel: [63857.069874] ieee80211 phy0: brcmf_run_escan: error (-52)
Oct 1 17:08:26 raspberrypi kernel: [63857.069898] ieee80211 phy0: brcmf_cfg80211_scan: scan error (-52)
Oct 1 17:17:01 raspberrypi CRON[3762]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Oct 1 17:24:17 raspberrypi rngd[369]: stats: bits received from HRNG source: 600064
Oct 1 17:24:17 raspberrypi rngd[369]: stats: bits sent to kernel pool: 543072
Oct 1 17:24:17 raspberrypi rngd[369]: stats: entropy added to kernel pool: 543072
Oct 1 17:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 successes: 30
Oct 1 17:24:17 raspberrypi rngd[369]: stats: FIPS 140-2 failures: 0
Oct 1 17:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Monobit: 0
Oct 1 17:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Poker: 0
Oct 1 17:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Runs: 0
Oct 1 17:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Long run: 0
Oct 1 17:24:17 raspberrypi rngd[369]: stats: FIPS 140-2(2001-10-10) Continuous run: 0
Oct 1 17:24:17 raspberrypi rngd[369]: stats: HRNG source speed: (min=167.676; avg=493.186; max=551.434)Kibits/s
Oct 1 17:24:17 raspberrypi rngd[369]: stats: FIPS tests speed: (min=7.176; avg=12.378; max=16.746)Mibits/s
Oct 1 17:24:17 raspberrypi rngd[369]: stats: Lowest ready-buffers level: 2
Oct 1 17:24:17 raspberrypi rngd[369]: stats: Entropy starvations: 0
Oct 1 17:24:17 raspberrypi rngd[369]: stats: Time spent starving for entropy: (min=0; avg=0.000; max=0)us
Oct 1 18:08:07 raspberrypi dhcpcd[467]: wlan0: carrier lost
Oct 1 18:08:07 raspberrypi dhcpcd[467]: wlan0: deleting address fe80::a13a:9a29:4610:62e8
Oct 1 18:08:07 raspberrypi avahi-daemon[377]: Withdrawing address record for fe80::a13a:9a29:4610:62e8 on wlan0.
Oct 1 18:08:07 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 18:08:07 raspberrypi avahi-daemon[377]: Interface wlan0.IPv6 no longer relevant for mDNS.
Oct 1 18:08:07 raspberrypi avahi-daemon[377]: Withdrawing address record for 10.0.0.73 on wlan0.
Oct 1 18:08:07 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 10.0.0.73.
Oct 1 18:08:07 raspberrypi avahi-daemon[377]: Interface wlan0.IPv4 no longer relevant for mDNS.
Oct 1 18:08:07 raspberrypi dhcpcd[467]: wlan0: deleting route to 10.0.0.0/24
Oct 1 18:08:07 raspberrypi dhcpcd[467]: wlan0: deleting default route via 10.0.0.1
Oct 1 18:08:07 raspberrypi dhcpcd[467]: wlan0: carrier acquired
Oct 1 18:08:07 raspberrypi dhcpcd[467]: wlan0: IAID 01:2f:95:69
Oct 1 18:08:07 raspberrypi dhcpcd[467]: wlan0: adding address fe80::a13a:9a29:4610:62e8
Oct 1 18:08:07 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv6 with address fe80::a13a:9a29:4610:62e8.
Oct 1 18:08:07 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv6 for mDNS.
Oct 1 18:08:07 raspberrypi avahi-daemon[377]: Registering new address record for fe80::a13a:9a29:4610:62e8 on wlan0.*.
Oct 1 18:08:07 raspberrypi dhcpcd[467]: wlan0: soliciting an IPv6 router
Oct 1 18:08:08 raspberrypi dhcpcd[467]: wlan0: rebinding lease of 10.0.0.73
Oct 1 18:08:13 raspberrypi dhcpcd[467]: wlan0: probing for an IPv4LL address
Oct 1 18:08:13 raspberrypi dhcpcd[467]: wlan0: DHCP lease expired
Oct 1 18:08:13 raspberrypi dhcpcd[467]: wlan0: soliciting a DHCP lease
Oct 1 18:08:18 raspberrypi dhcpcd[467]: wlan0: using IPv4LL address 169.254.70.61
Oct 1 18:08:18 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv4 with address 169.254.70.61.
Oct 1 18:08:18 raspberrypi avahi-daemon[377]: New relevant interface wlan0.IPv4 for mDNS.
Oct 1 18:08:18 raspberrypi avahi-daemon[377]: Registering new address record for 169.254.70.61 on wlan0.IPv4.
Oct 1 18:08:18 raspberrypi dhcpcd[467]: wlan0: adding route to 169.254.0.0/16
Oct 1 18:08:18 raspberrypi dhcpcd[467]: wlan0: adding default route
Oct 1 18:08:21 raspberrypi dhcpcd[467]: wlan0: no IPv6 Routers available
Oct 1 18:10:16 raspberrypi dhcpcd[467]: wlan0: offered 10.0.0.73 from 10.0.0.1
Oct 1 18:10:29 raspberrypi dhcpcd[467]: wlan0: probing address 10.0.0.73/24
Oct 1 18:10:34 raspberrypi dhcpcd[467]: wlan0: leased 10.0.0.73 for 86400 seconds
Oct 1 18:10:34 raspberrypi avahi-daemon[377]: Registering new address record for 10.0.0.73 on wlan0.IPv4.
Oct 1 18:10:34 raspberrypi dhcpcd[467]: wlan0: adding route to 10.0.0.0/24
Oct 1 18:10:34 raspberrypi dhcpcd[467]: wlan0: changing default route via 10.0.0.1
Oct 1 18:10:34 raspberrypi avahi-daemon[377]: Withdrawing address record for 169.254.70.61 on wlan0.
Oct 1 18:10:34 raspberrypi avahi-daemon[377]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 169.254.70.61.
Oct 1 18:10:34 raspberrypi avahi-daemon[377]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.0.0.73.
It was from @codyalanbryant's instructions for dummies right after installing nodejs -- see #169 in this thread.
Thanks in advance....
This tells me that it failed trying to change the working directory to run the process (Linux command is chdir
Can you run sudo cat /etc/systemd/system/roomba.service
- specifically interested in the WorkingDirectory line, and ls -l <directory>
to see the permissions of the directory specified?
First, I really appreciate you helping me with this troubleshooting!
WorkingDirectory=/usr/share/rest980
Not sure if I did want you asked for. I issued a "ls -l /etc/system/system/" command from terminal and got the below. Hoping it's what you wanted.
Summary
total 68
-rw-r--r-- 1 root root 1551 Jun 15 2020 autologin@.service
drwxr-xr-x 2 root root 4096 Aug 20 2020 bluetooth.target.wants
lrwxrwxrwx 1 root root 42 Aug 20 2020 dbus-fi.w1.wpa_supplicant1.service -> /lib/systemd/system/wpa_supplicant.service
lrwxrwxrwx 1 root root 37 Aug 20 2020 dbus-org.bluez.service -> /lib/systemd/system/bluetooth.service
lrwxrwxrwx 1 root root 40 Aug 20 2020 dbus-org.freedesktop.Avahi.service -> /lib/systemd/system/avahi-daemon.service
lrwxrwxrwx 1 root root 45 Aug 20 2020 dbus-org.freedesktop.timesync1.service -> /lib/systemd/system/systemd-timesyncd.service
lrwxrwxrwx 1 root root 36 Aug 20 2020 default.target -> /lib/systemd/system/graphical.target
lrwxrwxrwx 1 root root 34 Aug 20 2020 dhcpcd5.service -> /lib/systemd/system/dhcpcd.service
lrwxrwxrwx 1 root root 35 Aug 20 2020 display-manager.service -> /lib/systemd/system/lightdm.service
drwxr-xr-x 2 root root 4096 Aug 20 2020 getty.target.wants
drwxr-xr-x 2 root root 4096 Aug 20 2020 getty@tty1.service.d
drwxr-xr-x 2 root root 4096 Aug 20 2020 graphical.target.wants
drwxr-xr-x 2 root root 4096 Aug 20 2020 halt.target.wants
drwxr-xr-x 2 root root 4096 Sep 29 23:04 multi-user.target.wants
drwxr-xr-x 2 root root 4096 Aug 20 2020 network-online.target.wants
drwxr-xr-x 2 root root 4096 Aug 20 2020 poweroff.target.wants
drwxr-xr-x 2 root root 4096 Sep 29 21:53 printer.target.wants
drwxr-xr-x 2 root root 4096 Aug 20 2020 rc-local.service.d
drwxr-xr-x 2 root root 4096 Aug 20 2020 reboot.target.wants
drwxr-xr-x 2 root root 4096 Aug 20 2020 remote-fs.target.wants
-rw-r--r-- 1 root root 202 Sep 30 22:46 roomba.service
lrwxrwxrwx 1 root root 9 Sep 29 22:00 samba-ad-dc.service -> /dev/null
drwxr-xr-x 2 root root 4096 Sep 29 21:53 sockets.target.wants
drwxr-xr-x 2 root root 4096 Aug 20 2020 sysinit.target.wants
lrwxrwxrwx 1 root root 35 Aug 20 2020 syslog.service -> /lib/systemd/system/rsyslog.service
drwxr-xr-x 2 root root 4096 Aug 20 2020 timers.target.wants
Think he probably needs to see
ls -l /usr/share/rest980
@thebearmay is right - ls -l /usr/share/rest980
- since the service file specifies to run as user pi
, we need to double-check that the user has permission to access/read this directory.
duh sorry, that's my pi-gnorance.
Turns out that folder doesn't exist -- "No such file or directory". I had been using a combination of the OP's README as well as the long-form instructions by @codyalanbryant, which turned into a playground for my stupidity. Anyway, I solved the rest980 issue as soon as I got the folder structure worked out for Working-Directory.
For anyone who follows me: the advice of using "sudo systemctrl status roomba.service" to make sure rest980 services were working allowed me to pinpoint the problem.
The one issue I still have is with the dashboard. I can't get the Roomba Tile to show up. It doesn't even show up in device details. I'm using v1.2.1 of the driver via HPM, so should be good there. The log is clean. The device starts, stops, messages, etc., as expected. Under "Current States", in the device details screen, there are five bullets. The second bullet is RoombaTile which shows a blank box with text for status and battery underneath no matter which client device I'm using to access my hub. Same thing shows up if I look at it through a dashboard tile.
Ideas & speculation.....
I wonder if it could be related to the fact that I'm using a Braava mop, not a Roomba vac?
In the Notification section of the app, if I flip "Notify when Roomba starts cleaning" or "Notify when Roomba finishes cleaning", does that literally mean "Roomba" or can I use those switches for Braava notifications as well?
There is a Braava option, but it looks like that is only for people with a Roomba and a Braava, so I left that alone. Right move?
Also, I noticed there is a switch for "Use Local Images" under Dashboards. I have it set to on, since I only access my dashboards locally (or via OpenVPN when out), but I'm not actually sure what that option does.
Finally, I noticed that rest980 server and password are not required, so I didn't supply those fields. Could that be a problem?
Again, super appreciate the assistance. This community is the best.
