Unable to arm HSM after update to 2.2.0.121
Just updated to latest firmware and hub shows no action when selecting to re-arm the Hubitat Safety Monitor. Nothings shows in the logs. HSM remains showing "All Monitoring Disarmed".
I can confirm I have the same behavior, disarmed smoke, water, then unable to rearm.
Funny thing is release notes do not mention HSM changes
Tagging @bobbyD
Well, they do mention a change in HSM... So there was at least some change made in the code.
  • Hubitat Safety Monitor: Fixed disarm after disarmAll issue.
Whether this is related to that or not is unknown by me, though.
For the record, I see the same bug on my HSM. I was planning on moving my last HSM functionality (smoke alert) to Node-RED anyway. Guess I will today.
I'm seeing the same problem.
I rolled back to 2.1.9.117 still cannot re-arm HSM. :pensive:
I just updated to 2.2.0.122 and issue remains. Cannot arm HSM.
Not sure why rolling back didnt do the trick. Now am getting scared... :grimacing:
correct you are, sorry about that. Next time I need to read slower
I ran a routine to arm HSM for night mode and then HSM correctly armed for night intrusion. Ran a routine for un-arming HSM night intrusion and that also worked. Then I tried clicking on the re-arm HSM Smoke & Water and it worked this time. No longer have the "All Monitoring Disarmed" message.
Just FYI.
So it's now working for you?
It appears so...
I disabled leak detection yesterday when I was messing with a water Sensor driver and now I can’t re-arm it. It’s the only thing I use HSM for.
I’m running 2.2.0.125
FWIW, if I disable HSM manually I can never manually re-arm it again. Running on latest 125 as well. HSM only arms and disarms through my routines now.
same here
I also disabled HSM in the app and was unable to rearm. I restored a recent backup to get it going again.
Just curious - has anyone talked to support about this, or informed @bravenel ?
Hopefully they already know about it and are working on a fix, but we shouldn't assume.
Nope, havent talked to anyone other than post here.
@bbrannon, I tried restoring from backup but probably didn't do one far enough back.
We will get this fixed....
This problem has been fixed in latest 2.2.0.126 release.
But now my HSM status on a tile in Dashboard reports Disarmed even though it is Armed. Can someone check into this?
I dont use dashboard, just Apple Home App and from what I can see it's back to normal for me.
