Hi I am trying to connect to my hun via the WireGuard VPN provided by my Firewalla Purple router.
I can ping the Hub but my browser will not open the page, I can access other IPs on my LAN such as my Shelly switch so I am confident my VPN is working okay.
Has anyone else come across this problem?
I am using a iPhone 15 with latest iOS and safari browser.
I realise I can use the dashboard for most things but it would be handy to be able to access the hub itself when I am away from home should there be any issues.
This sounds similar to a problem I've been having. I have a remote site linked via Wireguard site to site VPN on Ubiquiti UDMs. I can view the web pages of some remote devices, but not all. All remote devices can be pinged, but no data is received. This includes a remote Hubitat hub. I have tried other types of VPN (IPSec, OpenVPN) makes no difference. I have also tried a server/client VPN - no difference. I have started to get the impression that it is something to do with MTU settings (I finally got data returned from my remote Synology NAS after reducing the MTU in the NAS settings). But the remote Hubitat and most remote cameras - no dice!
I donβt have any difficulty reaching my hub (or other devices on my LAN) when remotely connected to the wiregaurd server running on my UniFi UXG-Pro.
Sharing a screenshot of the wireguard tunnel configuration might be helpful as well.
I've got WG running on my ER12, and I have never had any problems connecting to my hub which is on my IoT VLAN on the ER via Ethernet. MTU settings can affect the hub, but typically if you're running Jumbo Frames w/their high MTU settings the hub will keep getting bumped off the network, but it doesn't sound like that's happending to you. In any case you will get best results w/standard 1500 MTU settings for routers/switches/APs that the hub is connected to.
I am using Wireguard with Firewalla and am having no issues with the website typing in the numerical hub IP. If you are trying to use "hubitat.local" that is something that has never worked for me in a browser.
Also, if you are using the phone app, instead of using "Connect to Hub" on the tools page, you will want to use "Registered Hubs" and then click on the "Connect To Hub" button while on your VPN over cellular. This is also a good way to verify you are typing in the correct IP address as it is shown on that page.
*** Edited to add that I am on Firewalla Gold, not Purple
Also, adding a silly question, are you trying to connect through VPN over cellular? Or WIfi? Because I have had issues when on a hotel Wifi where they had the same IP range as my home router and that created IP conflicts trying to access devices on my home router. This is why I carry my travel router now after I changed my IP range on my home router.... that was a pain with all my reservations and shortcuts.
I have a quick update on my issue. I have changed the MTU setting on my client to automatic and this has cured a problem I was having accessing my my DVR server via the app. The change to the MTU has fixed the access problem for this.
Unfortunately I still cannot access the Hubitat Hub.
I haven't read the earlier posts.... But found I could not access hubs via one method in the app due to what I expected was a DNS difference between the VPN compared to being on the local LAN. If I used a method that used IP addresses while I was on the VPN I could access the HE hub. Could this be the issue?
