@Royski Fantastic - keep Alive Time set to 255 minutes - how in Hubitat do I do a refresh every 200 minutes?
I can see a Refresh button in the device but no associated Timer function.
Oh and Merry Christmas!!
I updated the driver to perform a refresh every two mins. When I’m next at my PC I’ll send you the link
Which one do you have, the 5 or 6 node?
Just the Singles
Ah right!!
Ok, I’ll port over what I did for my strip
Hey Roy can you send me the updated 6 plug version?
Here's the driver with refresh. Turn on the Auto poll, then set the duration.
I no longer have the single plugs, so cant test it, but once saved you should see the auto poll set in the bottom of the device page
Same link to update the Parent with Auto poll
PERFECT Thanks!!!
Very much appreciated.
I have about 20 Greenwave Singles, got them all dirt cheap when they were being EOL'd
For the moment I have set the the initial test one on Hubitat to Param 1=255 so gives Hubitat 255 minutes to do a Poll, I have set mine to to the max Poll every 5 mins and when I have more courage will play with the Driver and see if I can add in an option for an hourly poll, to reduce work load on HE when/if I move all the Greenwaves across.
Again thank you so much for helping with this - very much appreciated!!
Looks like you're missing a { somewhere
@royski - not critical - easily fixed with some masking tape.
The Greenwave starts flashing green after the current param 1=255 (minutes) even with the driver above and Auto Poll set to 5 mins and Enable Auto Poll set.
Manually sending a Poll resets the 255 minute timer to 0.
Mike
Crikey, you must have been too quick grabbing that, I fixed it shortly after
The prefs should read like this.
preferences {
// input name:"updateLight", type:"number", title:"After how many minutes the GreenWave device should start flashing if the controller didn't communicate with this device", defaultValue:255
input "autoPoll", "bool", required: false, title: "Enable Auto Poll"
if(autoPoll){
input "pollInterval", "enum", title: "Auto Poll Interval:", required: false, defaultValue: "2 Minutes",
options: ["1 Minute", "2 Minutes", "3 Minutes", "4 Minutes", "5 Minutes"]}
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
input name: "txtEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: true
Updated Sorry I hadn't fixed the 6 node parent, only the 5. I now have
Yeah this is the issue with them. So if they don't hear from the hub within 120 seconds, they will flash until they do. So if set to 5 mins, then when it gets to the end of the 255, they will flash until the 5 min refresh happens, then after 2 mins, they will flash for 3 mins (if you see what I mean?).
I just set to 2 mins, and bye bye flash
I am having fun getting everything setup - thanks again
Have pasted that into the right place of the driver and trying the 2 min Auto Poll first
On the HA I am using right now, set the param 1=255 and set Poll to run every hour, never had them flash.
My understanding was each time they received a poll it reset the timer again to the Param 1 setting.
Yeah, that should have worked, unless the param didn't take to 255?
And param 1 should be correct.
Short version:
Maybe try setting param 4 to 0?
These are fw 4.23 so won't play with Param 4
I'll try to work out how logs work in HE and see if I can actually see a Poll going out to it
