According to their doc, this is the reset procedure.
5.2 FACTORY RESET
User can press power button for few seconds at booting time. There is more information in detail about procedure in user manual document. This operation will reset node Id in association groups and the setting about protection command class.
Yet, the diagram of the plug, points to the reset being the bottom button.
Press and hold the power button while plugging the PowerNode into an electrical outlet.
Keep the power button pressed for five seconds until all bars turn green for five seconds, indicating that
the factory reset process has completed. Your PowerNode is now free of its former association, and you
can perform an inclusion process to include it in your GreenWave Reality energy management system
(refer to the âNetwork Inclusion Processâ section above).
If all bars did not turn green for five seconds, then the PowerNode was not previously included.
Out of interest, what is the wheel set to when attempting this?
I know it can be locked by that, maybe thats an issue?
And ST is off now, and the plug removed from there?
I don't recall doing anything out of the ordinary to pair mine, apart from button pushing etc.
Have you ever seen these just stop working?
I had one that was set for a fan in the summer so hasn't been used for a few months but now it doesn't work.
@philpugh - thanks for the reply! When you say not reliably .. what device driver did you get energy readings from ? The generic z wave driver doesnât seem to provide energy readings at all for me
I actually don't remember exactly as it was a while ago, I may not have got any reading at all. Which is a shame as they worked well with ST.
I've just ordered another 2 salus plugs to replace the last 2 greenwaves I have on ST...
I'll use the greenwaves as simple on/off switches, but only ones that can be hidden due to the flashing leds
@Royski Thank you for that got my Greenwaves working - just need to figure out, how, in Hubitat do I send a param 1=255 to each Greenwave to force the 'I'm lost' green flashing for 255 minutes and then force a poll every 3 hours or so
