what are your logs reporting for 6702 (converted from hex)
when i first started this driver it was - [68, 13, 103, 2, 0, 4, 0, 0, 0, 35] i thought 3.5 volt?
but looking today - [126, 162, 103, 2, 0, 4, 0, 0, 0, 30] 3 volts??
I took the plunge and purchased one of these from Amazon with mixed results although not unsuccessful e.g. most things appear to work
The puzzling thing is the thermostat modes - these are defined as 0 = off, auto =1 and 2 = heat/manual in the driver. But on this device I consistently get 0 = heat/manual, 1 = 0ff, and 2 = auto based on the icons showing on the TVR display.
Am I doing something wrong, or could you check with your TCP Smart TVR?
Thanks for all the great work
P.S.
Using the icons on the TRV display as a test, I've managed to add in child lock enable/disable and window detection enable disable commands to the driver.
Also edited the capabilities to remove all the fan gubbins
update with battery reporting (dev) and low battery reporting
https://raw.githubusercontent.com/Mark-C-uk/Hubitat/master/Zigbee-Tuya-TRV
I'll put the command's I've decoded here later today. It may be that the TCP is a little different to the Tuya valve and might need 2 drivers.
Here is a list of sniffed data for the TCP valve;
Response sent from TRV when going from Eco to Manual mode
Data: 0101000101
Set AUTO mode - this is not used for offline applications. It tells the TRV to use Tuya servers for scheduled temperatures
Data: 0404000102
Set ECO mode (Also known as frost protection)
Data: 0404000101
Set Manual mode (Normal operation)
Data:0404000100
Set TRV to OFF
Data: 0101000100
Set TRV to ON
Data: 0101000101
Set temperature calibration to 0 degrees
Data: 00146d02000400000000
Set temperature calibration to -5 degrees
Data: 00156d020004fffffffb
Set temperature calibration to +5 degrees
Data: 00136d02000400000005
Child lock OFF
Data: 0701000100
Child lock ON
Data: 0701000101
Report set-temp of 16.0
Data: 02020004000000a0
Report room temperature
Data: 03020004000000c0
Report set-temp of 20.5
Data: 02020004000000cd
Set Window detection to OFF
Data: 1201000100
Set Window detection to ON
Data: 1201000101
Out of interest, Koen Kanters has done a lot of work on Zigbee2MQTT, and this file lists a lot of common Tuya commands, with some of the exceptions;
That’s great, and the values for the modes tally with my testing. I assume the other model of TRV agrees with the mode values in the driver?
I will packet sniff the Tuya TZ valve later today. It's currently on my Hubitat network, so I'll have to join it to Tuya first.
I'm doing a capture for the TZ Tuya valve now on the Hubitat network. I'll let it run for a while and see what I get
I’m not sure what the set temperature calibration data refers to, either in the driver or on the device interface? Can you clarify please.
@mark.cockcroft 6702 stays at Hex 23 / Dec 35 whatever batteries I install .
@malcolmcdobson On the TCP valve, it's an offset. So if the TRV is not showing the real temperature, you can adjust it's reported temp. E.g. Real room temp is 20 degrees, TCP reports 18 degrees. You can adjust the reported temp by 2 degrees (not sure if you would use a + or - adjustment though)
@mark.cockcroft I suggest we split this thread. There seems to be subtle differences between the Tuya TS0601 and the TCP/Siterwell GS361.
Topic split. I found this webpage, and this says that the TS0601 only exposes a low battery warning. I'm still running a packet capture on wireshark, and will analyse the data after 24 hours
TS0601 commands sent from TRV over 24 hours (Quite chatty, so I've just included the data and the type of command)
| Data | Type |
| 0004000000c3 | 0202 |
| 0004000000a0 | 0202 |
| 0004000000be | 0202 |
| 0004000000b9 | 0202 |
| 0004000000b4 | 0202 |
| 0004000000be | 0302 |
| 0004000000b9 | 0302 |
| 0004000000b4 | 0302 |
| 0004000000af | 0302 |
| 0004000000aa | 0302 |
| 0004000000a5 | 0302 |
| 0004000000c3 | 0302 |
| 0004000000cd | 0302 |
| 0004000000d2 | 0302 |
| 0004000000c8 | 0302 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000102 | 0404 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0701 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 000100 | 0d05 |
| 0004fffffff6 | 2c02 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 3010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00100 | 4010 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00102 | 4040 |
| 00400000000 | 5020 |
| 00400000000 | 6020 |
| 000400000005 | 6602 |
| 000400000023 | 6702 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 000300050a | 6800 |
| 00040000012c | 6902 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000100 | 6a04 |
| 000400000014 | 6b02 |
| 00040000000f | 6c02 |
| 000400000005 | 6d02 |
| 00040000000a | 6d02 |
| 00040000000f | 6d02 |
| 000400000014 | 6d02 |
| 000400000019 | 6d02 |
| 00040000001e | 6d02 |
| 000400000023 | 6d02 |
| 000400000028 | 6d02 |
| 000400000000 | 6d02 |
| 00040000002d | 6d02 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6e01 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 000100 | 6f04 |
| 001206001408000f0b1e0f0c1e0f111e1216000f | 7000 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00100 | 7010 |
| 00400000000 | 7020 |
| 001286001408000f0b1e0f0c1e0f111e1416000f | 7100 |
| 00040000000f | 7202 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7301 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000100 | 7401 |
| 000400000001 | 7502 |
@mark.cockcroft I had a Siterwell original valve delivered, and the battery code you have written in this driver reported correctly.
Good to know it works for someone, mine still.100% I think I'll have to put some old batteries in
There seems to be valves that only report good/bad and some that report % levels. Firmware seems to vary between manufacturers.
I have possibly interesting news for you. I have TRV "SEA-TR", probably from "Saswell" company, model "SEA801" that identifies itself as TS0601, but with manufacter info (_TZE200_c88teujp) and looks that it partialy working with your driver. During attempt to use it, I discovered that it reports temperature changes set manually on TRV as... battery level.
Manufacturer: _TZE200_c88teujp
Product Name:
Model Number: TS0601
deviceTypeId: 128
manufacturer : _TZE200_c88teujp
idAsInt : 1
inClusters : 0000,0004,0005,EF00
endpointId : 01
profileId : 0104
application : 55
outClusters : 0019,000A
initialized : true
model : TS0601
stage : 4
Found smarthings driver that could be usefull for Tuya TRV implementation in hubitat, link below:
Smartthings/tuya-thermostat.groovy at master · iquix/Smartthings · GitHub
