Tuya Zigbee Scene Switch - Intermittent Double Event
I've held off reporting this due to the intermittent nature of it and also some wider things going on with my lights via cocohue. But I think this issue is separate due to seeing the double event (from single button presses) in the logs many times over weeks.
I'm getting double events from this device TS0042 _TZ3000_5e235jpa using this driver. Its a Moes device MOES ZigBee Wireless Scene Switch Push Button Controller, Tuya/MOES Zigbee Hub Required, Smart Life & Tuya Remote Control,2 Gang : Amazon.co.uk: DIY & Tools
Can someone confirm if there is a better driver to use (or experiment with) and if there is anything I can try to improve the reliability? Or if a change might be needed to the driver itself?
The device itself is reporting twice, has it always been this way?, or is this a recent change?
Hi Mike - It hasn't always done it but I cannot attribute the issue to specific versions of HE. Apologies.
This is a known problem with some of the Tuya scene switches.
You can use this driver : Tuya Scene Switch TS004F driver (w/ healthStatus) :
Turn on the 'Advanced Options' and click Save.
Then, a 'Force debounce' option will appear - enable it and click on the Save button again:
