Just bought these blinds and the company has sent me the DH they have made for ST, could some one (ive no zigbee driver experience) give it the once over and let me know if it should work as is or needs modifications
code
/** zemismart
* Tuya Window Shade (v.0.1.0)
* Copyright 2020 iquix
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
This DTH is coded based on iquix's tuya-window-shade DTH.
https://github.com/iquix/Smartthings/blob/master/devicetypes/iquix/tuya-window-shade.src/tuya-window-shade.groovy
import groovy.json.JsonOutput
import physicalgraph.zigbee.zcl.DataType
metadata {
definition(name: "ZemiSmart Zigbee Blind", namespace: "ShinJjang", author: "ShinJjang-iquix", ocfDeviceType: "oic.d.blind", vid: "generic-shade") {
capability "Actuator"
capability "Configuration"
capability "Window Shade"
capability "Window Shade Preset"
capability "Switch Level"
command "pause"
attribute "Direction", "enum", ["Reverse","Forward"]
fingerprint endpointId: "0x01", profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006", outClusters: "0019", manufacturer: "_TYST11_wmcdj3aq", model: "mcdj3aq", deviceJoinName: "Zemismart Zigbee Blind"
preferences {
input "preset", "number", title: "Preset position", description: "Set the window shade preset position", defaultValue: 50, range: "0..100", required: false, displayDuringSetup: false
input name: "Direction", type: "enum", title: "Direction Set", defaultValue: "00", options:["01": "Reverse", "00": "Forward"], displayDuringSetup: true
tiles(scale: 2) {
multiAttributeTile(name:"windowShade", type: "generic", width: 6, height: 4) {
tileAttribute("device.windowShade", key: "PRIMARY_CONTROL") {
attributeState "open", label: 'Open', action: "close", icon: "http://www.ezex.co.kr/img/st/window_open.png", backgroundColor: "#00A0DC", nextState: "closing"
attributeState "closed", label: 'Closed', action: "open", icon: "http://www.ezex.co.kr/img/st/window_close.png", backgroundColor: "#ffffff", nextState: "opening"
attributeState "partially open", label: 'Partially open', action: "close", icon: "http://www.ezex.co.kr/img/st/window_open.png", backgroundColor: "#d45614", nextState: "closing"
attributeState "opening", label: 'Opening', action: "colse", icon: "http://www.ezex.co.kr/img/st/window_open.png", backgroundColor: "#00A0DC", nextState: "closing"
attributeState "closing", label: 'Closing', action: "open", icon: "http://www.ezex.co.kr/img/st/window_close.png", backgroundColor: "#ffffff", nextState: "opening"
standardTile("contPause", "device.switch", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "pause", label:"", icon:'st.sonos.pause-btn', action:'pause', backgroundColor:"#cccccc"
standardTile("presetPosition", "device.presetPosition", width: 2, height: 2, decoration: "flat") {
state "default", label: "Preset", action:"presetPosition", icon:"st.Home.home2"
standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 1) {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
valueTile("shadeLevel", "device.level", width: 4, height: 1) {
state "level", label: 'Shade is ${currentValue}% up', defaultState: true
controlTile("levelSliderControl", "device.level", "slider", width:2, height: 1, inactiveLabel: false) {
state "level", action:"switch level.setLevel"
main "windowShade"
details(["windowShade", "contPause", "presetPosition", "shadeLevel", "levelSliderControl", "refresh"])
private getCLUSTER_TUYA() { 0xEF00 }
private getSETDATA() { 0x00 }
// Parse incoming device messages to generate events
if (description?.startsWith('catchall:') || description?.startsWith('read attr -')) {
Map descMap = zigbee.parseDescriptionAsMap(description)
if (descMap?.clusterInt==CLUSTER_TUYA) {
log.debug descMap
if ( descMap?.command == "01" || descMap?.command == "02" ) {
def dp = zigbee.convertHexToInt(descMap?.data[3]+descMap?.data[2])
log.debug "dp = " + dp
switch (dp) {
case 1025: // 0x04 0x01: Confirm opening/closing/stopping (triggered from Zigbee)
def data = descMap.data[6]
if (descMap.data[6] == "00") {
log.debug "opening"
levelEventMoving(100)
} else if (descMap.data[6] == "02") {
log.debug "colsing"
levelEventMoving(0)
break
case 1031: // 0x04 0x07: Confirm opening/closing/stopping (triggered from remote)
if (descMap.data[6] == "01") {
log.debug "closing"
levelEventMoving(0)
} else if (descMap.data[6] == "00") {
log.debug "opening"
break
case 514: // 0x02 0x02: Started moving to position (triggered from Zigbee)
def pos = zigbee.convertHexToInt(descMap.data[9])
log.debug "moving to position :"+pos
levelEventMoving(pos)
break
case 515: // 0x02 0x03: Arrived at position
log.debug "arrived at position :"+pos
levelEventArrived(pos)
break
private levelEventMoving(currentLevel) {
def lastLevel = device.currentValue("level")
log.debug "levelEventMoving - currentLevel: ${currentLevel} lastLevel: ${lastLevel}"
if (lastLevel == "undefined" || currentLevel == lastLevel) { //Ignore invalid reports
log.debug "Ignore invalid reports"
} else {
if (lastLevel < currentLevel) {
sendEvent([name:"windowShade", value: "opening"])
} else if (lastLevel > currentLevel) {
sendEvent([name:"windowShade", value: "closing"])
private levelEventArrived(level) {
if (level == 0) {
sendEvent(name: "windowShade", value: "closed")
} else if (level == 100) {
sendEvent(name: "windowShade", value: "open")
} else if (level > 0 && level < 100) {
sendEvent(name: "windowShade", value: "partially open")
} else {
sendEvent(name: "windowShade", value: "unknown")
return
sendEvent(name: "level", value: (level))
def close() {
log.info "close()"
def currentLevel = device.currentValue("level")
if (currentLevel == 0) {
return
sendTuyaCommand("0104", "00", "0102")
def open() {
log.info "open()"
if (currentLevel == 100) {
return
sendTuyaCommand("0104", "00", "0100")
def pause() {
log.info "pause()"
sendTuyaCommand("0104", "00", "0101")
def setLevel(data, rate = null) {
log.info "setLevel("+data+")"
if (currentLevel == data) {
sendEvent(name: "level", value: currentLevel)
return
sendTuyaCommand("0202", "00", "04000000"+zigbee.convertToHexString(data, 2))
def presetPosition() {
setLevel(preset ?: 50)
def installed() {
sendEvent(name: "supportedWindowShadeCommands", value: JsonOutput.toJson(["open", "close", "pause"]), displayed: false)
def updated() {
def val = Direction
sendEvent([name:"Direction", value: (val == "00" ? "Forward" : "Reverse")])
DirectionSet(val)
def DirectionSet(Dval) {
log.info "Dset(${Dval})"
sendHubCommand(zigbee.command(CLUSTER_TUYA, SETDATA, "00" + zigbee.convertToHexString(rand(256), 2) + "05040001" + Dval))
def configure() {
log.info "configure()"
private sendTuyaCommand(dp, fn, data) {
log.info "${dp},${fn},${data}"
zigbee.command(CLUSTER_TUYA, SETDATA, "00" + zigbee.convertToHexString(rand(256), 2) + dp + fn + data)
private rand(n) {
return (new Random().nextInt(n))
