Summary
/** zemismart
* Tuya Window Shade (v.0.1.0) Hubitat v1
* Copyright 2020 iquix
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
This DTH is coded based on iquix's tuya-window-shade DTH.
https://github.com/iquix/Smartthings/blob/master/devicetypes/iquix/tuya-window-shade.src/tuya-window-shade.groovy
import groovy.json.JsonOutput
//mc // import physicalgraph.zigbee.zcl.DataType
import hubitat.zigbee.zcl.DataType
import hubitat.helper.HexUtils
metadata {
definition(name: "ZemiSmart Zigbee Blind", namespace: "ShinJjang", author: "ShinJjang-iquix", ocfDeviceType: "oic.d.blind", vid: "generic-shade") {
capability "Actuator"
capability "Configuration"
capability "Window Shade"
// mc not supported in HE capability "Window Shade Preset"
capability "Switch Level"
command "pause"
command "presetPosition"
attribute "Direction", "enum", ["Reverse","Forward"]
fingerprint endpointId: "01", profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006", outClusters: "0019", manufacturer: "_TYST11_wmcdj3aq", model: "mcdj3aq", deviceJoinName: "Zemismart Zigbee Blind"
//mc changeed endpointId from 0x01 to 01
preferences {
input "preset", "number", title: "Preset position", description: "Set the window shade preset position", defaultValue: 50, range: "0..100", required: false, displayDuringSetup: false
input name: "Direction", type: "enum", title: "Direction Set", defaultValue: "00", options:["01": "Reverse", "00": "Forward"], displayDuringSetup: true
// removed tiles section as not used in Hubitat
private getCLUSTER_TUYA() { 0xEF00 }
private getSETDATA() { 0x00 }
// Parse incoming device messages to generate events
if (description?.startsWith('catchall:') || description?.startsWith('read attr -')) {
Map descMap = zigbee.parseDescriptionAsMap(description)
if (descMap?.clusterInt==CLUSTER_TUYA) {
log.debug descMap
if ( descMap?.command == "01" || descMap?.command == "02" ) {
def dp = zigbee.convertHexToInt(descMap?.data[3]+descMap?.data[2])
log.debug "dp = " + dp
switch (dp) {
case 1025: // 0x04 0x01: Confirm opening/closing/stopping (triggered from Zigbee)
def data = descMap.data[6]
if (descMap.data[6] == "00") {
log.debug "parsed opening"
levelEventMoving(100)
} else if (descMap.data[6] == "02") {
log.debug "parsed closing"
levelEventMoving(0)
else {log.debug "parsed else stoping $data"}
break
case 1031: // 0x04 0x07: Confirm opening/closing/stopping (triggered from remote)
if (descMap.data[6] == "01") {
log.debug "closing"
levelEventMoving(0)
} else if (descMap.data[6] == "00") {
log.debug "opening"
break
case 514: // 0x02 0x02: Started moving to position (triggered from Zigbee)
def pos = zigbee.convertHexToInt(descMap.data[9])
log.debug "moving to position :"+pos
levelEventMoving(pos)
break
case 515: // 0x02 0x03: Arrived at position
log.debug "arrived at position :"+pos
levelEventArrived(pos)
break
private levelEventMoving(currentLevel) {
def lastLevel = device.currentValue("level")
log.debug "levelEventMoving - currentLevel: ${currentLevel} lastLevel: ${lastLevel}"
if (lastLevel == "undefined" || currentLevel == lastLevel) { //Ignore invalid reports
log.debug "Ignore invalid reports"
} else {
if (lastLevel < currentLevel) {
sendEvent([name:"windowShade", value: "opening"])
} else if (lastLevel > currentLevel) {
sendEvent([name:"windowShade", value: "closing"])
private levelEventArrived(level) {
if (level == 0) {
sendEvent(name: "windowShade", value: "closed")
} else if (level == 100) {
sendEvent(name: "windowShade", value: "open")
} else if (level > 0 && level < 100) {
sendEvent(name: "windowShade", value: "partially open")
} else {
sendEvent(name: "windowShade", value: "unknown")
return
sendEvent(name: "level", value: (level))
//mc added
sendEvent(name: "position", value: (level))
//mc
def close() {
log.info "close()"
def currentLevel = device.currentValue("level")
if (currentLevel == 0) {
log.debug "if closed"
return
sendTuyaCommand("0104", "00", "0102")
def open() {
log.info "open()"
if (currentLevel == 100) {
return
sendTuyaCommand("0104", "00", "0100")
def pause() {
log.info "pause()"
sendTuyaCommand("0104", "00", "0101")
def setLevel(data, rate = null) {
log.info "setLevel("+data+")"
if (currentLevel == data) {
sendEvent(name: "level", value: currentLevel)
//mc added
//mc
return
//sendTuyaCommand("0202", "00", "04000000"+zigbee.convertToHexString(data, 2))
//sendTuyaCommand("0202", "00", "04000000"+convertToHexString(data.intValue(), 2))
sendTuyaCommand("0202", "00", "04000000"+HexUtils.integerToHexString(data.intValue(), 2))
//mc new for HE Commands
def setPosition(position){
log.info "setPos to $position"
//setLevel(data = position, rate = null)
setLevel(position, null)
//mc
//custom command
def presetPosition() {
setLevel(preset ?: 50)
def installed() {
sendEvent(name: "supportedWindowShadeCommands", value: JsonOutput.toJson(["open", "close", "pause"]), displayed: false)
def updated() {
def val = Direction
sendEvent([name:"Direction", value: (val == "00" ? "Forward" : "Reverse")])
DirectionSet(val)
def DirectionSet(Dval) {
log.info "Dset(${Dval})"
//sendHubCommand(zigbee.command(CLUSTER_TUYA, SETDATA, "00" + zigbee.convertToHexString(rand(256), 2) + "05040001" + Dval))
def configure() {
log.info "configure()"
private sendTuyaCommand(dp, fn, data) {
log.info "send tuya command ${dp},${fn},${data}"
zigbee.command(CLUSTER_TUYA, SETDATA, "00" + zigbee.convertToHexString(rand(256), 2) + dp + fn + data)
// if issue use this
//sendHubCommand(zigbee.command(CLUSTER_TUYA, SETDATA, "00" + zigbee.convertToHexString(rand(256), 2) + dp + fn + data))
private rand(n) {
return (new Random().nextInt(n))
