Tuya vibration sensor and HSM
Hi
Is there anyway to get this to work in HSM 's Away, Home, Night modes properly?
It works in the custom monitoring rules, but would like it to work in the above modes.
Data
  • endpointId: 01
  • application: 41
  • manufacturer: _TZ3000_bmfw9ykl
  • model: TS0210
Another one I would like for it to work in the above modes is the Aeotec Multipurpose Sensor's vibration/Acceleration part . The contact sensor works ok but not the vibration/Acceleration part.
thanks
Are you using this driver with the Tuya vibration sensor?
yes
I don’t remember whether Hubitat Safety Monitor can trigger an alert based on acceleration… probably if the driver simulates Motion event will do the job.
a Custom Monitoring Rule works but not the normal rules.
