Sorry if im not giving you all the correct info.
Im extremely new to all of this.
No worries, you just had the bad luck to receive a very new device, it is not supported by any other home automation system not based on the Tuya platform yet.
OK, let's leave it for today, we are in the same time zone, so we can continue tomorrow.
Thank you for all your efforts.
I follow your other threads and you are amazing.
Thank you.
I will need more logs to understand what may be wrong with this switch.
Can you try again to copy the logs as text, not as a screenshot?
Good morning.
Will have to pick this back up tomorrow as i wont be around switch today.
Hope you are available tomorrow.
Thanks for coming back.
Have you succeed to make it working with HE?
Hello, not yet. I havent been able to get to work on this switch yet. Have to wait till switch available again.
Hello All,
I just added the same device and followed the steps in here, but my 3-gang switch still doesnt work. Can someone help me out?
Gr Tay
Please use the latest version of this driver :
https://raw.githubusercontent.com/martinkura-svk/Hubitat/main/Moes%20ZigBee%20Wall%20Switch
its working
You are welcome.
Hi - I think this post (by me) is asking about the same family of switches:
Does this driver support different switch press types....?
Thanks!
No - different switches.
Also, the in-wall relays that you are asking about only support on/off (with any hub - not just Hubitat).
Ah - OK - my confusion in that case.
Yes, I know they only support on/off - the idea was to use them simply as powered buttons using the in-wall face plate of my choice - they are cheaper than battery powered buttons (which in any case don't match my decor) and have the huge bonus of not needing to have batteries changed...
Are the switches I've linked to supported in this way by any drivers you know of...?
If the switches that you could receive today are the same as those that have been sold from the same store just a few months ago - yes, these ( _TZ3000_bvrlqyj7 ) are supported by this driver: Zemismart Zigbee 1/2/3/4 gang light switches - #36 by kkossev Although, with AliExpress sellers you never know. If not in a hurry, it may be a good idea to purchase only one pcs, test and if it works buy more.
These devices send back to HE the on/off status of the physical switch connected to the module, so yes - you could use them as just a remote switch/button without wiring and controlling directly any bulbs.
You can experiment also with these : Tuya Smart ZigBee Switch Kinetic Self Powered Wireless Switch (no battery)
Ah - now that's very interesting - I have a similar one in use that doesn't talk anything other than its local protocol between the Rx and Tx parts - thanks for pointing it out!
Not useful everywhere (can't use different face plates specifically), but there are at least two places I can think of in my house at least that it will be a help.
The kinetic switch is of a push type, when pressed it simply toggles the electronic module status On or Off. The clicking sound is not higher than other similar mechanical switches. You can control the actual electronic switch from HE at the same time.
Hi @kkossev
I have purchased this zigbee module:
Here is my pairing device info:
I hoped your Zemismart ZigBee Wall Switch Multi-Gang driver will work. But I am not able to manage to get child device. Always end up on one gang like this
Unit was deleted, and repaired to HE few times... no success
Can you please advice if the driver is compatible? If so, how do I initialise parent device?
Hi Lubomir,
I've just published a modified version of Markus's drivers - can you try this one :
