Here's the app that controls the thermostats for my Heating Zone 1
* Zone1 Boiler Control
* Copyright 2018 Simon Burke
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
name: "Boiler Control Zone1",
namespace: "SJB",
author: "Simon Burke",
description: "Control Zone1 Boiler based on Thermostat Zones",
category: "Convenience",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png"
preferences {
section("Turn on/off this Z-Wave Boiler Switch") {
input "theswitch", "capability.switch", required: true
section("Boiler Boost Switch") {
input "Booster", "capability.switch", required: true
section("Thermostat") {
input "thermo", "capability.thermostat", title: "SRT321 Thermostats", multiple: true, required: true
section("Temperature Sensor") {
input "temperatureSensor", "capability.temperatureMeasurement", title: "Temperature Sensor", required: false
section("Temperature Trigger Level") {
input "temperatureTrigger", "number", title: "Temperature", required:true, multiple:false
def updated() {
log.debug "Updated with settings: ${settings}"
unsubscribe()
unschedule()
initialize()
def initialize() {
subscribe(thermo, "thermostatMode", thermostatMode)
runEvery5Minutes('TemperatureHandler')
thermo?.each {
if (it.currentValue('battery') < 2) {
log.debug "Zone1 - $it.displayName battery too low - disabled"
if (it.currentThermostatMode.contains('heat')) and (it.currentValue('battery') > 1) {
theswitch.on()
log.debug "Zone1 - Boiler switched on... ${it.displayName} needs heat"
def thermostatMode(evt) {
if (evt.value.contains('heat')) {
theswitch.on()
log.debug "Zone1 - Boiler switched on... ${evt.displayName} called for heat"
def TemperatureHandler(evt) {
def CurrentTemp = temperatureSensor.latestValue("temperature")
def KnockOnOff = 0
def BatteryPerCent = 0
if (CurrentTemp>temperatureTrigger-1) {
log.debug "Zone1 - Temp is $CurrentTemp - at or above $temperatureTrigger"
KnockOnOff = 0
} else {
log.debug "Zone1 - Temp is $CurrentTemp - too cold - Switching Boiler On"
KnockOnOff = 1
thermo?.each {
BatteryPerCent = it.currentValue('battery')
log.debug "Zone1 - $it.displayName current mode is $it.currentThermostatMode Battery is $BatteryPerCent"
if (it.currentThermostatMode.contains('heat')) {
if (it.currentValue('battery') > 1) {
log.debug "Zone1 - $it.displayName needs heat..."
KnockOnOff = 1
if ("off" == Booster.currentSwitch ) {
log.debug "Zone1 - Booster is Off"
} else {
log.debug "Zone1 - Booster is On"
KnockOnOff = 1
if (KnockOnOff == 1) {
theswitch.on()
log.debug "Zone1 - Boiler switched on..."
} else {
theswitch.off()
log.debug "Zone1 - Boiler switched off..."
