Trouble Pairing New devices
They don't need to be paired as LR. Also use just classic pairing (devices>>add devices>> zwave>> Start z-wave inclusion when adding (door locks are the only ones that require encryption). Also you will have to either factory reset or exclude your devices after the hub reset. Take a look at this post. It will help you avoid some gotchas. Pay close attention to the z-wave section. If you have a failed pairing at any time, stop! Check for a ghost in z-wave details and remove it before proceeding.
