This also works. It's a virtual contact sensor that acts a switch on hubitat. I use it quite often
- Virtual Motion Sensor with Switch
- Copyright 2020 Ernie Miller
- Permission is hereby granted, free of charge, to any person obtaining a copy
- of this software and associated documentation files (the "Software"), to deal
- in the Software without restriction, including without limitation the rights
- to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
- copies of the Software, and to permit persons to whom the Software is
- furnished to do so, subject to the following conditions:
- The above copyright notice and this permission notice shall be included in
- all copies or substantial portions of the Software.
- THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
- AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
- OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
- SOFTWARE.
metadata {
definition(name: "Virtual Motion Sensor with Switch", namespace: "ernie",
author: "Ernie Miller") {
capability "Actuator"
capability "Motion Sensor"
capability "Sensor"
capability "Switch"
preferences {
input name: "inactiveSeconds", type: "number",
title: "Inactive Delay",
description: "Seconds until switch/motion toggles off (1 - 120, 0 = disable)",
range: "0..120", defaultValue: 10, required: true
input name: "logEnable", type: "bool", title: "Enable Logging",
defaultValue: false
def installed() {
off()
def on() {
if (logEnable) { log.info "$device.displayName active" }
sendEvent(name: "motion", value: "active")
sendEvent(name: "switch", value: "on")
if (inactiveSeconds > 0) { runIn(inactiveSeconds, "off") }
def off() {
if (logEnable) { log.info "$device.displayName inactive" }
sendEvent(name: "motion", value: "inactive")
sendEvent(name: "switch", value: "off")
