Trying to make a dashboard tile for the Fingerbot. In the driver, both push and switch in āFingerbot Modeā have been tried. For the tile, button, momentary, and switch have all been tried. I can actuate the Fingerbot from its device page so it does work.
What am I missing?
Is it a built-in driver?
Are you using this driver by @kkossev ?
I will add a 'Momentary' capability to the driver this weekend, it will allow controlling the fingerbot from HE dashboard push button.
@TomG meanwhile you can experiment with a virtual button and a simple rule - when the virtual button is pushed, send 'on' command to the fingerbot device.
Yes
When you are in the code, can you enable battery reporting provided it is reliable?
According to the capabilities, battery is listed.
Thanks!
I have updated the driver - you can try the new version :
