ogiewon:
Has anybody tested using the Hubitat IOS lately to determine if the app still pairs devices to the Apple thread network rather than the Hubitat network?
ogiewon:
I have not tested it recently. However, @mike.maxwell has mentioned in a few posts above that the this is not a high priority right now for Hubitat Mobile App development process (IIRC
Found it...
and
Ok thanks. I will continue to use the web interface.
Not sure if youâre aware⌠If you use the Hubitat web interface via a web browser on a smartphone, when pairing Matter devices, youâre given the option to use the phoneâs camera to scan the Matter QR code during the pairing/commissioning process. Very handy!
Ogiewon:
I'm old fashioned. I think I can still manage to type 11 numbers. If I make a mistake the check digit will tell me.
True that, but not all Matter devices have the setup code on the device itself.
There is an advantage to using the QR code since it includes information that determines how to specifically commission the device, ie WiFi/lan/bluetooth. The numeric code does not include this data, so matter ends up trying each one until it succeeds. You can see these gyrations in the matter log when using the numeric code vs the qr
Thx! - I didn't know that - Did a bit of digging, and: Matter QR codes explained: What happens when you scan one? | Matter Alpha
Mike:
Does entering the QR text in the Matter add device web page accomplish the same thing as scanning the QR code? I'm referring to the long QR text,,, not the 11 digit setup code. I have carefully avoided using my iPhone app AT ALL because of the problem of adding the device to the Apple Homekit thread network rather than the Hubitat network.
Mike:
I decided to test entering the QR text instead of scanning the QR code or entering the 11 digit setup code. I chose a Matter/wifi device I had laying around as the test device.
I have a hunch this option is seldom (if ever) used. I pasted this code: MT:MVAA0EDB00ILO44CF10 into the Add Matter device dialog. I DID NOT paste where the setup is entered but into the Hubitat QR Scanner page. I got an invalid code message that is the same message one receives if the 11 digit setup code is fat fingered. The Verhoeff check digit shuts down the transaction quickly.
But the code I entered is legitimate. I asked ChatGPT to decipher it. AI did decipher it and spit out data that includes the correct 11 digit setup code. I think the Hubitat QR Scanner dialog may be interpreting the QR text as a setup code.
Agreed. This is a good idea to prevent MoT devices from being added to the wrong TBR.
Was this just a technical curiosity you're trying to solve? If so, please ignore the rest. ![]()
If not, did you try my suggestion of simply using a web browser on your mobile phone to open the Hubitat Hub's "add a Matter device" page? Doing so lets the user use the phone's camera to scan the QR code on the MoT device. This method avoids using the Hubitat Mobile App altogether, and thus ensures the MoT device you're pairing/commissioning uses the Hubitat C8ProT hub's TBR.
Yes it was technical curiosity. I don't plan on adding enough thread devices to require a streamlined procedure for adding them.
I did a test of using the QR text string (not the setup code) to add a device. See my post this morning to Mike Maxwell. I couldn't get it to work.
@bobbyD ,
Have you Hubitat guys seen the Sonoff Dongle-PMG24?
You can flash the Open Thread Firmware with a tool provided by Sonoff:
Could it be a solution for implementing Thread Border Router with HE?
The C8-Pro-T is a TBR, are you thinking as an add on device or ??
It's a dongle, like Hubitat used to use in the past - it would be used as a RCP (Radio Co-Processor).
So - if I'm not mistaken - Hubitat "just" had to develop the module to talk to it from the HE.
Actually, there're free tools of TBR. I configured it in a Raspberry Pi 400 and so far, so good - kind of. My Nuki lock has been behaving strangely and it's not talking correctly to the Pi.
Any chance of a "trade-up credit" for the standard C8 Pro? I was hoping they could get Thread working on the standard one because I have no use for Zigbee.
Connecting my Nuki Thread/Matter lock to the HE was a ugly fight ... and I was beaten all the way.
Until I found the Aqara Hub M100. It's a stick that can be connected to an USB-A port (for power) and it implements a Thread Border Router - and more.
The configuration was a breeze and now my lock is accessible by the HE!
And it's cheap (~33 USD).
Hope it helps.
Let's be sure we are clear since the thread title (no pun intended) is Thread comes to Hubitat. Using the Aqara Hub M100, you aren't connecting devices as Thread devices, but as Matter over wi-fi. You've still got a dependency on your wi-fi network. Correct?
I'm certainly not saying that this isn't a viable approach; I think it is. But it does not relate directly to a Hubitat model now having a Thread radio.
Hi @HAL9000 (love Space Odissey too ...),
You're absolutely right - the Aqara actas as a Thread Border Router and makes viable connect Thread devices through it.
I was frustrated since I couldn't connect my Nuki lock to HE because I needed a TBR. And also frustrated that it wasn't available yet with HE without giving up the Zigbee radio.
Buying an expensive device like an Apple TV just to be a TBR was out of the picture. So, I've tried using the Sonoff dongle PMG24 and Raspberry Pi and it got quite time consuming that I put it aside - for now ...
Then I found the Aqara and it was cheap an straightforward - so I decided to share my "discovery" with the community, hoping it could help someone with similar "frustration".
