ThirdReality Smart Plug too many events in log
I updated my ThirdReality Smart Plugs to the new driver and am now getting ‘too many events’ (over 500) and saw this in the log.
dev:24912024-09-23 01:42:01.341 PMwarnDryer zigbee received unknown Electrical Measurement cluster attribute 0x0510 (value 51)
dev:24912024-09-23 01:41:56.316 PMwarnDryer zigbee received unknown Electrical Measurement cluster attribute 0x0510 (value 48)
dev:24912024-09-23 01:39:31.363 PMwarnDryer zigbee received unknown Electrical Measurement cluster attribute 0x0510 (value 32)
dev:24912024-09-23 01:39:06.327 PMwarnDryer zigbee received unknown Electrical Measurement cluster attribute 0x0510 (value 52)
dev:24912024-09-23 01:39:01.279 PMwarnDryer zigbee received unknown Electrical Measurement cluster attribute 0x0510 (value 4C)
This is in the log for each ThirdReality Smart Plug. Only the name has changed from Dryer to Washer
If I switch to the generic Zigbee driver, the error isn’t there.
It would be helpful if you'd clarify what "new driver" you are using.
My mistake. New firmware. The driver is the ‘Third Reality Power Meter Plug’
I don't see that available as a native driver -- if it's a community driver, you'll likely get better results by posting in its corresponding thread.
I know the driver you mentioned. Did you hit configure or initialize after switching to the community driver?
I did find the driver, I was mistaken. I think you may mean this one: hubitat-public/ThirdReality at main · bradsjm/hubitat-public · GitHub
Let me try and see if I get the same result. Yep.
In one of the threads about these plugs (perhaps this one: New: Third Reality Power monitoring plug) there is a note that there are two versions, a V1 without power monitoring and a V2 with it.
I expect mine is a V1
endpointId: 01
application: 13
firmwareMT: 1233-D3A6-10013058
manufacturer: Third Reality, Inc
model: 3RSP019BZ
powerCluster: none
softwareBuild: v1.00.88
Note the "powerCluster : none"
Upon rereading mine throws an "unknown attribute error" rather than the "Unkown Electrical Measurement" error yours is throwing!
S
I seem to have the v2
IMG_0474
Ah. Then try hitting configure after changing the driver. Otherwise try hitting up Jonathan in the other thread. Perhaps they added some clusters in the new firmware.
S.
I've got (different) plugs that are running both drivers and don't have any issues. All my plugs have more cluster info than your device data. I'd suggest trying to reset and re-pair the plug. You don't need to delete the device in Hubitat.
You can also try switching temporarily to the HE inbuilt‘Device’ driver and click on the ‘Get Info’ button. Then refresh the web page - this should update the device Data section.
Check the last post in the thread regarding that driver:
If you installed via HPM run a repair to pull down the newest code, he may not have updated the package file.
Looking at github the package file didn't receive an update after he merged.
I just directly linked the driver though the raw path
https://raw.githubusercontent.com/bradsjm/hubitat-public/refs/heads/main/ThirdReality/ThirdRealityPowerMonitorPlug.groovy
HPM did not find any updates. I updated the driver from this link. So far, no extraneous reporting. Thanks for the help.
As I said, you would have to run a REPAIR in HPM to force it to pull the newest code, but you did that manually so same effect.
