Please add 2 more features to this app - restrictions, if possible.
1/ Contact sensor restriction - together with "turn thermostats off when restricted", this would allow to shut thermostat off when window is open.
2/ Switch restriction - please allow to invert this condition. In my room, there is wall with windows, then heater, and then smart curtain. I want to shut thermostat off when window is open (previous point), or when the curtain is closed, as there is no point of having heater to heat air between window and heavy curtain. The problem is, the curtain has "switch capability", but it reports off when closed, and on when open. I'd need to be able to restrict thermostat to work only when switch is on, so instead of "Select switch device to disable thermostat scheduler", I'd need something like "select switch device to enable thermostat scheduler".
Thank you
Maybe this would work for the 2nd part:
