I'm was running 2.3.3.134 and just updated to 2.3.3.140 to see if it fixed it (it doesnt) although i dont see anything in the release notes about this problem.
I've noticed that Thermostat Scheduler isnt changing the setpoint at the selected time. For example, here's my dining room schedule:
if i look at the logs for the device, i see this. i've stripped out many duplicate lines but kept the lines around the times of scheduled changes - you can see that there is no event relating to schedule change:
dev:112022-11-14 12:46:06.338debugRefresh - Temperature is: 19.7 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-14 12:41:06.430debugRefresh - Temperature is: 19.7 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-14 12:36:06.324debugRefresh - Temperature is: 19.8 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-14 09:11:07.029debugRefresh - Temperature is: 19.3 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-14 09:06:06.427debugRefresh - Temperature is: 19.4 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-14 06:36:06.634debugRefresh - Temperature is: 20.1 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-14 06:31:06.542debugRefresh - Temperature is: 20.2 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-14 06:26:07.191debugRefresh - Temperature is: 20.2 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-14 06:21:07.148debugRefresh - Temperature is: 20.2 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-13 23:36:06.739debugRefresh - Temperature is: 20.4 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-13 23:31:07.035debugRefresh - Temperature is: 20.5 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-13 23:26:06.634debugRefresh - Temperature is: 20.5 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-13 23:21:06.684debugRefresh - Temperature is: 20.4 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-13 20:06:07.135debugRefresh - Temperature is: 20.1 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-13 20:01:07.289debugRefresh - Temperature is: 20.1 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-13 19:56:06.790debugRefresh - Temperature is: 20.1 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-13 19:51:06.837debugRefresh - Temperature is: 20.2 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-13 10:06:06.334debugRefresh - Temperature is: 19.7 - Setpoint is: 18.0 - Calling for heat? false
dev:112022-11-13 10:01:06.523debugRefresh - Temperature is: 19.8 - Setpoint is: 18.0 - Calling for heat? false
What's interesting is:
a) I dont have an 18 degree temperature set. I did, but i changed it at around 7am this morning, well before the trigger to move to 'daytime'. It shoudl have gone to 16 degrees at 9am.
b) it didnt go to 16 degrees at 9am.
I see a similar thing on other schedulers e.g. lounge, although it did switch last night and this morning:
dev:152022-11-14 12:48:04.325debugRefresh - Temperature is: 19.9 - Setpoint is: 20.0 - Calling for heat? false
dev:152022-11-14 12:43:05.127debugRefresh - Temperature is: 19.9 - Setpoint is: 20.0 - Calling for heat? false
dev:152022-11-14 09:08:05.025debugRefresh - Temperature is: 19.9 - Setpoint is: 20.0 - Calling for heat? false
dev:152022-11-14 09:03:04.421debugRefresh - Temperature is: 20.0 - Setpoint is: 20.0 - Calling for heat? false
dev:152022-11-14 08:58:04.422debugRefresh - Temperature is: 20.0 - Setpoint is: 20.0 - Calling for heat? false
dev:152022-11-14 08:53:04.626debugRefresh - Temperature is: 20.1 - Setpoint is: 20.0 - Calling for heat? false
dev:152022-11-14 06:38:04.952debugRefresh - Temperature is: 20.5 - Setpoint is: 20.0 - Calling for heat? false
dev:152022-11-14 06:33:04.640debugRefresh - Temperature is: 20.5 - Setpoint is: 20.0 - Calling for heat? false
dev:152022-11-14 06:30:08.063debugRefreshing thermostat data from parent
dev:152022-11-14 06:30:03.582debugsuccess on last command: [result:temperature was set]
dev:152022-11-14 06:30:03.436debugsuccess on last command: [result:temperature was set]
dev:152022-11-14 06:30:03.151debugsuccess on last command: [result:temperature was set]
dev:152022-11-14 06:29:13.348debugRefresh - Temperature is: 20.6 - Setpoint is: 20.5 - Calling for heat? false
dev:152022-11-14 06:24:13.376debugRefresh - Temperature is: 20.7 - Setpoint is: 20.5 - Calling for heat? false
dev:152022-11-13 23:39:13.743debugRefresh - Temperature is: 20.3 - Setpoint is: 20.5 - Calling for heat? true
dev:152022-11-13 23:34:14.035debugRefresh - Temperature is: 20.1 - Setpoint is: 20.5 - Calling for heat? true
dev:152022-11-13 23:29:13.528debugRefresh - Temperature is: 20.0 - Setpoint is: 20.5 - Calling for heat? true
dev:152022-11-13 23:24:13.740debugRefresh - Temperature is: 20.0 - Setpoint is: 20.5 - Calling for heat? true
dev:152022-11-13 17:04:14.241debugRefresh - Temperature is: 20.1 - Setpoint is: 20.5 - Calling for heat? false
dev:152022-11-13 17:00:06.694debugRefresh - Temperature is: 20.1 - Setpoint is: 20.5 - Calling for heat? false
dev:152022-11-13 17:00:06.282debugRefreshing thermostat data from parent
dev:152022-11-13 17:00:01.428debugsuccess on last command: [result:temperature was set]
dev:152022-11-13 16:55:30.685debugRefresh - Temperature is: 20.1 - Setpoint is: 20.0 - Calling for heat? false
dev:152022-11-13 16:50:30.831debugRefresh - Temperature is: 20.1 - Setpoint is: 20.0 - Calling for heat? false
r
