Definitely was wrong at the thermostat too, I noticed because it kicked on when it shouldn't have needed to.
Here's the relevant snippets from the relevant logs that I can find... IF I am interpreting them correctly the situation is:
- at 8:35pm mode manager declared it night time based on sunset
- at 8:35pm the app says the setpoint should be switched to 78F
- at 9:03 the system logs report the setpoint is still at 75F, and the cooling kicks on which caught my attention
- at ~9:07pm I start looking at the app page as pasted above, the app logs that the settings should be 78F
- at 9:08pm I click through to the setting and out without changing anything, and the system finally get's the thermostat set.
I've had this happen multiple times with multiple thermostats and thought maybe it was coincidence at first. This definitely seems to be a case of "to look at it is to change it" IRL.
Logs:
System Event saw it turned to Night mode at 8:35pm:
mode |
Ana Lark Center is now in Night mode |
Night |
LOCATION_MODE_CHANGE |
2019-07-13 08:35:00.274 PM CDT |
sunsetTime |
2019-07-15T01:34:00.000Z |
API |
2019-07-13 08:35:00.170 PM CDT |
sunset |
true |
API |
2019-07-13 08:35:00.049 PM CDT |
The app log shows reports at 8:35 before I checked with the correct settings, but the thermostat doesn't actually get it until later when I look around 9:07:
ThermoScheduler |
Mode Schedule: Night |
Cooling Setpoint 78.0 |
2019-07-13 09:35:08.015 PM CDT |
ThermoScheduler |
Heating Setpoint 65.0 |
2019-07-13 09:35:07.990 PM CDT |
ThermoScheduler |
2019-07-13 09:08:42.772 PM CDT |
ThermoScheduler |
2019-07-13 09:08:42.747 PM CDT |
ThermoScheduler |
2019-07-13 09:08:35.696 PM CDT |
ThermoScheduler |
2019-07-13 09:08:35.675 PM CDT |
ThermoScheduler |
2019-07-13 09:07:00.183 PM CDT |
ThermoScheduler |
2019-07-13 09:07:00.160 PM CDT |
ThermoScheduler |
2019-07-13 08:35:00.812 PM CDT |
ThermoScheduler |
2019-07-13 08:35:00.673 PM CDT |
ThermoScheduler |
Mode Schedule: Evening |
Cooling Setpoint 75.0 |
2019-07-13 06:44:52.750 PM CDT |
The logs show the setpoint was still 74.9F at 9:03pm here....
dev:3862019-07-13 09:08:37.085 pm infoThermostat - Lobby coolingSetpoint was set to 78.0°F
dev:3862019-07-13 09:08:37.029 pm infoThermostat - Lobby heatingSetpoint was set to 65.0°F
dev:3862019-07-13 09:03:30.606 pm infoThermostat - Lobby thermostatSetpoint was set to 74.9°F
dev:3862019-07-13 09:03:30.579 pm infoThermostat - Lobby thermostatOperatingState is cooling
dev:3862019-07-13 09:03:30.052 pm infoThermostat - Lobby thermostatSetpoint was set to 74.9°F
dev:3862019-07-13 09:03:30.018 pm infoThermostat - Lobby thermostatOperatingState is pending cool
dev:3862019-07-13 08:31:29.562 pm infoThermostat - Lobby thermostatOperatingState is idle
dev:3862019-07-13 08:31:15.027 pm infoThermostat - Lobby thermostatOperatingState is fan only
dev:3862019-07-13 08:15:56.313 pm infoThermostat - Lobby thermostatSetpoint was set to 74.9°F
dev:3862019-07-13 08:15:56.267 pm infoThermostat - Lobby thermostatOperatingState is cooling
dev:3862019-07-13 08:15:55.234 pm infoThermostat - Lobby thermostatSetpoint was set to 74.9°F
dev:3862019-07-13 08:15:55.155 pm infoThermostat - Lobby thermostatOperatingState is pending cool
