I am using @thebearmay's [Resurrected] Advanced Honeywell T6 Pro Z-Wave Thermostat Driver for my thermostat and that seems to be working fine. I wanted to use the TC app to control it so I could use the additional features that the TC app provides. I am not sure if I missed a configuration step or somehow have caused this issue, but anytime the tstat is running, I get events generated every couple of seconds, causing alerts on the hub.
Here is the events from the controller tstat while the heat is running, reaches temp and goes idle:
Here are the events from the controlled tstat:
Here are the logs from the TC app:
Here is the configuration of the TC app:
Here is the TC app details:
What do I need to do to get the volume of events under control?
