It is because CSS doesn't by default override what is set in the "style" property, but there is a work around:
add "!important" to your CSS, so
#tile-2 .tile-primary {
font-size: 40px !important;
Here is a working example:
Yeah I've been doing the same thing, but it's a PITA. Hopefully others can chime in.
That worked perfectly, thank you!
That's pretty cool !!
Thanks, learn something new everyday from the community!
How would you modify the below temp reading tile to increase the font side?
"rowSpan": 1,
"template": "temperature",
"col": 7,
"colSpan": 1,
"id": 33,
"row": 2,
"device": "527",
"templateExtra": null
Figured it out....this is what I needed to add.
"customCSS": "#tile-32 .tile-primary {\nfont-size: 43px !important;\n}",
OK this is weird, one temp tile work just fine but I want to do more than one, lets say 2 this is what I am having a problem with.
In CCS of the dashboard edit window I enter;
font-size: 42px !important;
#tile-34 .tile-primary {
I then hit save CSS and go to the layout window and see this all the way at the bottom;
"customCSS": "#tile-32 .tile-primary {\nfont-size: 42px !important;\n}\n#tile-34 .tile-primary {\nfont-size: 42px !important;\n}",
When I hit save Layout JSON it reverts back to just one tile that I first tried to mod. Am I doing something wrong? How do you get it to stick with modding more than one tile at a time.
Never mind figured it out again.......dont hit save Layout JSON,
Save CSS is enough to make it stick.
Working on increasing the font size for @bptworld Life360 tile using CSS.
Can't seem to get it to work. Per the below image you can see in google (right click) inspect elements that I have found the path and can temp modify it in google by adding (font-size: 30px;) in google. None of my attempt to write the proper CSS works, any ideas?
Is it possible to replace the icon (not the background) of a tile with a .png from a URL?
Maybe, if you can use this per @rocketwiz
#tile-63 .tile-secondary {
visibility: hidden;
#tile-63 .tile-secondary:after {
content: 'My Front Door';
to hide it and then add a link to the new one.
Been working on CSS editing in my dashboard. I am still trying to understand the Hierarchy of data in a tile and how it has to be written to work.
I was trying to move the temp number and deg F closer together in the tile. It works in Google by adding (margin-left: -20px;) in the google page per the below picture, but going back to CSS in the Hikvision dashboard I can't figure it out.
Here is the Hierarchy in google. (I think)
#tile-33 .tile-primary {
element.style
.small
How do you write it in the Hikvision dashboard CSS to make it work.
Sorry haven't had to do this, hopefully someone will come up with an answer.
I've also updated post#2 above to include useful tips posted by others in this thread and some new stuff I've come across.
Just to let you all know, I figured it out....lot of guessing but here is what moved it over.
#tile-34 .small {
margin-left: -20px;
Here is a list of some of my CSS code on some of my tiles on my dashboard.
Depending on the tile they can be all over the place on modifying a tile. Google inspect will give you the clues and then it was kind of a guessing game.
font-size: 74px !important;
position: relative;
bottom: 22px;
right: -3px;
#tile-36 .tile-title {
position: absolute;
bottom: -10px;
color: #3affff;
font-size: 30px;
#tile-32 .small {
margin-left: -20px;
#tile-50.tile.button {
background-color: hsla(0,0%,50.2%,0)!important;
#tile-36 .tile-primary a {
font-size: 30px !important;
color: #00ff37;
#tile-42.tile.button {
color: #e4ff00;
Further edit to post #2. It seems we can add units to an attribute tile using CSS even if the device driver doesn't support it.
Noob question... I assume the group "Label" tile you are using (IE: Front, Living Room, etc) are "Text" tiles? If so, how are you making them 1/2 or 1/4 height? If not using a standard Text tile, can you share the CSS that your are using for these?
Thank you in advance!
See posts #1 and #2. You can either change the font size (in points) or also probably scale the element.
EDIT: Ahh sorry, misread your post. I did the same as @anon81541053 to get them to fit on a tablet screen and each tile for me also ended up being the same 3H x 1L ! Go figure!
Seeing this thread I thought I'd share a snippet that works universally for me to replace tile-title:
.tile-title:after {
visibility: visible;
position: absolute;
left: 50%;
top: 50%;
transform: translate(-50%, -50%);
overflow: hidden;
white-space: nowrap !important;
#tile-94 .tile-title {
visibility: hidden;
#tile-94 .tile-title:after {
content: 'A very long title to crop';
This should work with any tile-size and layout for replacing tile-title, or any other div with some modification. Hope it is of help to someone. No need to change percentages...
EDIT: Do not use this, there is a better approach in a later post.
