Double tap? Hold to brighten and hold to dim? Or only on/off?
Lutron Diva is a line of hardwired dimmers and switches, not battery powered remotes. If you are talking about the Pico Paddle remote, which is a closer match for the Diva style (as opposed to the CasΓ©ta style), the answer is the same as the last time you asked:
To summarize: it should support everything any other Pico does (just with fewer buttons than most since you only have two on this device).
Brain injury, I forget what I asked already, thanks
